Ir sender and reciver
At 09:26 AM 1/9/03 -0800, max powell wrote:
>HI STAMPERS
>WAS WONDERING IF ANYBODY KNOWS OF A GOOD I-R XMIT RECIVER THAT I COULD
>USE TO XMIT A COUNT BY BLINKS FROM A STATION TO A ROBOT AND HAVE THE
>ROBOT XMIT BACK TO THE STATION TO VERFIY THE COUNT. THE STATION WILL BE
>APPROX. 8 TO 10" FROM THE ROBOT AND I WOULD LIKE IT IN A ASSEMBLED UNIT
>AND COMPATABLE WITH STAMP [noparse][[/noparse]5 VOLT LOGIC]
>THANKS IN ADVANCE FOR ANY INFO
>MAX POWELL
Max -
You may want to check this web site and check out all the nifty infrared TX
and RX devices they offer: http://www.rentron.com/
If you need any assistance with anything there, I'm sure Bruce Reynolds
will be happy to help.
Just as an aside, please use both upper and lower case in your messaging.
In message list circles all caps is considered shouting, and I'm sure you
didn't mean that with your message.
Hope that gets you started.
Bruce Bates
>[noparse][[/noparse]Non-text portions of this message have been removed]
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>HI STAMPERS
>MAX POWELL
Max -
Bruce Bates
mpowell@t... writes:
> WAS WONDERING IF ANYBODY KNOWS OF A GOOD I-R XMIT RECIVER THAT I COULD USE
> TO XMIT A COUNT BY BLINKS FROM A STATION TO A ROBOT AND HAVE THE ROBOT
> XMIT BACK TO THE STATION TO VERFIY THE COUNT. THE STATION WILL BE APPROX. 8
> TO 10" FROM THE ROBOT AND I WOULD LIKE IT IN A ASSEMBLED UNIT AND
> MAX POWELL
Take a look at the Tx-IR chip, the TSAL6100 IR LED and the PNA detector at
www.rentron.com. Have one installed and it works beautifully. Chip
generates IR frequency so it doesn't tie up a Stamp I/O port.
Sid Weaver
W4EKQ
Port Richey, FL
and forth between two Stamps. It comes in a pair with BASIC Stamp
documentation and source code ready to run.
-- Jon Williams
-- Parallax
Here's a direct link:
<A
HREF="http://www.parallax.com/detail.asp?product_id=28016">http://www.parallax.c\
om/detail.asp?product_id=28016</A>
In a message dated 1/9/2003 8:32:51 AM Central Standard Time,
> HI STAMPERS
> MAX POWELL
WAS WONDERING IF ANYBODY KNOWS OF A GOOD I-R XMIT RECIVER THAT I COULD USE TO
XMIT A COUNT BY BLINKS FROM A STATION TO A ROBOT AND HAVE THE ROBOT XMIT BACK
TO THE STATION TO VERFIY THE COUNT. THE STATION WILL BE APPROX. 8 TO 10" FROM
THE ROBOT AND I WOULD LIKE IT IN A ASSEMBLED UNIT AND COMPATABLE WITH STAMP [noparse][[/noparse]5
VOLT LOGIC]
MAX POWELL
