Problem communicating PC VB6 - BS2
I trie to communicate with Visual Basic mscomms with the BS2 standard sin en
sout pins
Many settings changed but always return the same problem or i get worse.
I have to send twice the string
mscomm.output = "DA02" & vbCR ' to get a return
then the bs2 react but i think there is stil sometihing in his buffer the first
2 characters are scrumbled.
In the debug window of parallax it does the wright thing.
Does anybody recognize this or has a sollution.
Regards
Pieter
sout pins
Regards
Pieter
sender. This is a matter of hardware and cannot be turned off. What you
must do when using VB is keep track of how many bytes you send, then filter
that many bytes out of the VB input stream as they are the echoed characters.
And keep in mind that the BASIC Stamp does not have a serial buffer -- except
the variable(s) you use in a SERIN statement. If you're not sitting on a
SERIN when VB sends its characters, the Stamp will miss them.
-- Jon Williams
-- Parallax
In a message dated 1/9/2003 4:04:53 AM Central Standard Time, pso@t...
writes:
> sout pins
> mscomm.output = "DA02" &vbCR ' to get a return
> first 2 characters are scrumbled.
> Regards
> Pieter
Access database also run in VB)
Since the BS2 don't have ram buffer, it's understanding that the
stamp must have charge over the communication. When ever the stamp
is interesting to ask for information from the PC, I just use the
line "Serin 16,16468,1000,Nodata,[noparse][[/noparse]DataIN]" Then the PC has one
second to answer or else the BS2-program go to the label "NoData"
When Pc is sending serial onfo, this info is send back as an echo
from the stamp.. Just ignore this in your vb-program or put the info
in a Com_log or something.
Remember not to turn you're VB Comm off on the PC, when using the
serial cable to the BS2. This will restart you're Stamp.
I have some difficulty splitting the incoming serial info into
several variables. Maybe you have some good BS2-code for this.
Stein_frostad at mailcity dot com
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> The BS2 programming port hardware echoes anything received back to
the
What you
then filter
characters.
buffer -- except
sitting on a
> -- Jon Williams
> -- Parallax
pso@t...
> writes:
standard sin en
> > sout pins
get worse.
buffer the
> > Regards
> > Pieter
