Pin burnout!
Archiver
I have a strange problem. In an exhibit I developed, I have several
switches wired to the stamp. All switches are wired in an active-
low configuration. I am using a 10k resistor between Vdd and the
switch/pin, while the other end of the switch is tied to Vcc. All
except one switch are working fine. The one that has given me
trouble works well for a few hundred times and then the pin remains
in a low state even if the switch is disconnected. What can cause
that? The 10k resistor is supposed to protect the pin from too much
current dissipation! Now when I read the switch I constantly get
0. This is the second BS2 that I burn Pin0 on, and the second one
with both pins 0 and 1 burned out!
Please give me some clues...
Al najjar
Al najjar
output high and you're getting a direct short to ground when the button is
pressed. You can protect the Stamp by connect a 1K resistor in series with
the Stamp input pin. That way, even if a programming error causes a given
pin to go high when you have a button pressed (connecting the pin to ground),
you limit the current to 5 milliamps and do no fry the pin.
-- Jon Williams
-- Parallax
PS: You can download Column #81 ("A Tale of Two Stamps") from this link:
<A
HREF="http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Download\
s_V3.asp">
http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Downloads_V3.
asp</A>
for details on the "safe" input circuit that I describe above.
In a message dated 1/7/2003 2:50:18 PM Central Standard Time,
brownstamp@y... writes:
> Al najjar
> Al najjar
The way you have it wired, there is no current protection into the stamp pin
(that is if I correctly understand your setup). If your pin is an output at
any time, outputs a low with the switch pressed (Vcc connected to the input)
you will burn out that channel/pin.
is this your current setup?
Vdd XXXXXXXX a______b Vcc
That is XXX = 10k resistor, pin "a" of the switch to the stamp and pin "b" of
the switch to vdd (+5v)?
I would to the following.....
A safe approach is to do the following..using the same schematic
configuration as above...
Vdd XXXX10kXXXXX stamp pin XXXXX 1K XXXXX a______b Vcc
In this configuration, you will not need to change the software (input is low
without pressing the switch) and you will read a valid logic high (4.54
volts) when the switch is pressed and the stamp pin will will be protected
from over current, regardless of the pin output state.
writes:
> It's likely that something in your program is causing Pin0 to become an
> ground),
> -- Jon Williams
> -- Parallax
> <A
s_V3.asp">
> asp</A>
Correct me if I am wrong, isn't vdd ground and vcc +5?
The user has 10k to ground and a switch to +5....therefore if the pin is an
output low with the switch pressed, you will then burn out the channel??????
Am I wrong or confused?
However, the 1k in SERIES to the stamp input pin will solve any logic problem
that will cause an over current situation. This solution by Jon is slightly
different from my earlier posting....
Both should work.
Stamp pin to ground (Vss) is through a 1K resistor. I prefer the series
approach because it's easier to remember -- regardless of whether you want to
switch active-low or active-high.
-- Jon Williams
In a message dated 1/7/2003 4:04:23 PM Central Standard Time,
smartdim@a... writes:
> channel??????
> problem
> Both should work.
writes:
> Yes, both solutions provide the same protection because the path from the
> to
> -- Jon Williams
As usual, Jon is 100% correct. The series method is a "no brainer."
250 of the 1.9 manual does not suggest this simple protective
measure!
Al Najjar
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> Yes, bot solutions provide the same protection because the path
from the
series
you want to
> -- Jon Williams
the pin is an
> > channel??????
logic
> > problem
is slightly
> > Both should work.
is written for the hardware and doesn't change -- the world of the
experimenter is very "dynamic" while the manual is very standard. That said,
I will suggest the update to our staff as the new compiler will necessitate
updating the manual.
-- Jon Williams
-- Parallax
In a message dated 1/7/2003 6:43:22 PM Central Standard Time,
> Thanks Jon. It makes perfect sense but I find it curious that page
> measure!
> Al Najjar
you many ways how not to fry your stamp, like the series resistor on
the input pins (though he uses 270 Ohm in his example, not 1 k). I
recommend getting this book, and don't lend it out because you won't
get it back.
