simple code
Hi, I'm having a bit of trouble with my A level project. I have two
stamps that are linked together via a transmitter and receiver. I
wish the stamp to have 6 different functions using six different
output pins.
I wish to send a code so that an input on one of the pins on the
receiving stamp will result in an output from the corresponding pin
on the output stamp when the signal has been received. Any help would
be gratefully received. Jon
output pins.
I take it that the information is input on the xmit side and the output on
the recive side. The code to send the information depends on the device used
to transmit the information, so we need to know what devices are being used.
And what kind of information is being sent. If you can send details I am
sure folks can help. If by any chance you are using a RWS/TWS-434 unit, I
have almost finished a project using them would be happy to send you my
code.
Jonathan
Sent: Tuesday, January 07, 2003 2:23 AM
Subject: [noparse][[/noparse]basicstamps] simple code
> output pins.
> output pins.
Jon
It seems to me that the receiving stamp is the output stamp.
What have you tried so far.
Fred
