repost of the repost, I don''t know what went wrong....Clock Help
I think you are almost there. The number modifiers have to
coordinate at the two ends of the transmission. If you use this
syntax to receive the data:
> SERIN 3\12, 16468, [noparse][[/noparse] hours]
> SERIN 3\12, 16468, [noparse][[/noparse] minutes]
> SERIN 3\12, 16468, [noparse][[/noparse] day]
then on the transmit end, you would use
SEROUT 3\12, 16468, [noparse][[/noparse]HEX $15]
SEROUT 3\12, 16468, [noparse][[/noparse]HEX $00]
SEROUT 3\12, 16468, [noparse][[/noparse]HEX $02]
to transmit the example numbers. The receive end then would program
the DX1302 for 3:00 pm on day 2.
On the transmit end, you will probably have variables for the hours,
minutes, and day? If they are already in hex (=BCD) format (as they
might be if you are having someone enter them at a keyboard), then
you would use
SEROUT 3\12, 16468, [noparse][[/noparse]hours]
SEROUT 3\12, 16468, [noparse][[/noparse]minutes]
SEROUT 3\12, 16468, [noparse][[/noparse]day]
but if they are not already in hex (BCD) format, then on the transmit side use
SEROUT 3\12, 16468, [noparse][[/noparse]HEX hours]
SEROUT 3\12, 16468, [noparse][[/noparse]HEX minutes]
SEROUT 3\12, 16468, [noparse][[/noparse]HEX day]
Play around with it, and one or the other of those options on the
transmit end should work.
-- Tracy
>The DS1302 real time clock sourse code from the app notes sets the
>clock using this code:-
>Day = $02 'Monday
>Month = $05 'May
>Date = $18 '18th
>Year = $98 '1998
>Hours = $15 '3:00 PM (in 24-hour mode)
>Minutes = $00
>Seconds = $00
>'GOSUB SetTimeAndDate
>I want to set the time from a separate bs2 set up as a programmer,
>using serin command.
>My code looks like this :-
>'hours = $13
>'minutes = $14
>'day = $7
>Month = $12
>Date = $03
>Year = $02
>Seconds = $00
>and it doesn't work.
>I have noticed that the original code makes the time for the clock
>setting a HEX number by preceding the constants with a $ sign,
>so i tried the following :-
>SERIN 3\12, 16468, [noparse][[/noparse]HEX hours]
>SERIN 3\12, 16468, [noparse][[/noparse]HEX minutes]
>SERIN 3\12, 16468, [noparse][[/noparse]HEX day]
>'hours = $13
>'minutes = $14
>'day = $7
>Month = $12
>Date = $03
>Year = $02
>Seconds = $00
>I also tried this at the serout end.
>Nothing Works [noparse]:([/noparse]
>Can anybody help me
>Regards,
>Dwain.
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
you would use
-- Tracy
>Day = $02 'Monday
>Month = $05 'May
>Date = $18 '18th
>Year = $98 '1998
>Minutes = $00
>Seconds = $00
>'hours = $13
>'minutes = $14
>'day = $7
>Month = $12
>Date = $03
>Year = $02
>Seconds = $00
>'hours = $13
>'minutes = $14
>'day = $7
>Month = $12
>Date = $03
>Year = $02
>Seconds = $00
>Can anybody help me
>Regards,
>Dwain.
