LCD have KS0066 — Parallax Forums
LCD have KS0066
edited 2003-01-05 19:42 in General Discussion
Hello,
Dose any one has a program which demonstrates the basic functions of LCD
with built-in Samsung KS0066 controller.
Thank You
Mohamed Refky
_________________________________________________________________
The new MSN 8 is here: Try it free* for 2 months
http://join.msn.com/?page=dept/dialup
    edited 2003-01-05 18:32
    I believe that controller is HD44780-compatible; so LCD programs you find for
    BASIC Stamps should work fine. I did a quick search (using Google) and found
    docs for LCDs using that controller -- the instruction set looked just like
    the HD44780.
    -- Jon Williams
    -- Parallax
    In a message dated 1/5/2003 11:22:28 AM Central Standard Time,
    refky@h... writes:
    If it's HD44780 based, here's a 4 bit interface for the BS2 followed
    by an example for the BS2p that has the lcd commands built-in...
    '{$STAMP BS2}
    ' Interface to the Hitachi 44780 based LCD devices
    ' for Basic Stamp uControllers.
    ' Wiring; p4-p7 on the stamp to db4 to db7 on the 44780
    ' p1 to the enable (E) line on the 44780.
    ' pull this down to Vss with a 10k ohm resistor
    ' p2 to the R/W line on the 44780
    ' p3 to the RS line on the 44780
    ' db0-db3 on the 44780 to Vss to support 4bit mode
    ' Use a 10K pot across Vcc/Vss to connect Vee to
    ' control LCD contrast.
    pulstime con 500 'pulsout time interval
    'changes based on stamp
    model
    'see "pulsout" command for
    'timing details.
    ' Some command constants based on the Hitachi 44780 spec
    WakeUp con %00110000 'Wake up
    FourBitMode con %00100000 'Set to 4 bit mode
    OneLine5x8Font con %00100000 '1 line 5x8 font
    OneLine5x10Font con %00100100 '1 line 5x10 fnt
    TwoLine5x8Font con %00101000 '2 line 5x8
    TwoLine5x10Font con %00101100 '2 line 5x10
    DisplayOff con %00001000 'Display off
    DisplayOn con %00001100 'Display on, no cursor
    DisplayOnULCrsr con %00001110 'Display on, underline cursor
    DisplayOnBLCrsr con %00001101 'Display on, blink cursor
    IncCrsr con %00000110 'Auto-increment cursor no
    display shift
    IncCrsrShift con %00000111 'Auto-increment display.
    shift display left
    DecCrsr con %00000100 'Decrement cursor. No
    display shift
    DecCrsrShift con %00000101 'Decrement cursor with
    display shift
    ClearDisplay con %00000001 'clear display
    HomeDisplay con %00000010 'Cursor to home
    ScrollLeft con %00011000 'Scroll to left
    ScrollRight con %00010100 'Scroll right
    CrsrLeft con %00010000 'Cursor to left
    CrsrRight con %00010100 'Cursoft right
    MoveCrsr con %10000000 'Move cursor to position
    MoveToCGRAM con %01000000 'Move to CGRAM position
    e con 1 'enable
    rw con 2 'read/write
    rs con 3 'register select
    'outb is data bus for lcd (p4-p7)
    x var byte 'scratchpad var
    cmd var byte 'command to sendcmd sub
    ch var byte 'character to sendchr sub
    temp var nib 'temp scratchpad
    index var byte 'index to eeprom
    ' Some eeprom data to display
    data "This is a test",255
    Init:
    dirl = %11111110 'p1-p7 outputs
    low e 'put
    low rw ' control lines
    low rs ' in initial state
    pause 500 'wait til vcc stable
    gosub InitLCD 'initialize LCD
    index = 0
    Display:
    read index,ch 'read data from eeprom
    if ch = 255 then Terminate 'sentinal?
    gosub sendchr 'send to lcd
    index = index + 1 'increment eeprom addr
    goto Display
    Terminate:
    stop
    ' Initialize LCD according to specifications for the HD44780
    InitLCD:
    for x=1 to 3 'spec said to do three times
    outb = WakeUp>>4 'send wakeup call
    pulsout e,pulstime 'send command
    pause 5
    next
    outb = FourBitMode>>4 'go to 4 but mode
    pulsout e,pulstime 'send it
    pause 1
    ' Initialization command sequence...
    cmd = FourBitMode
    gosub sendcmd
    cmd = TwoLine5x8Font
    gosub sendcmd
    cmd = DisplayOff
    gosub sendcmd
    cmd = DisplayOnBLCrsr
    gosub sendcmd
    cmd = IncCrsr
    gosub sendcmd
    cmd = ClearDisplay
    gosub sendcmd
    cmd = HomeDisplay
    gosub sendcmd
    return
    ' send character to ddram on lcd
    sendchr:
    gosub busychk 'wait til lcd not busy
    outb = ch.highnib 'upper part first
    high rs 'rs high
    low rs 'reset rs
    gosub busychk 'wait again
    outb = ch.lownib 'lower nibble
    high rs 'rs high
    low rs 'reset rs
    return
    ' Send command in the var "cmd" to the lcd
    sendcmd:
    outb = cmd.highnib 'upper cmd first
    outb = cmd.lownib 'lower nibble
    return
    ' waits til the lcd is no longer busy and then returns
    ' uses the var "temp"
    busychk:
    dirl = %00001110 'make lcd databus input
    high rw 'were reading
    busyloop:
    high e 'enable
    temp = inb 'get data from lcd
    low e 'toggle back enable
    pulsout e,pulstime 'because were in 4bit mode
    (two reads of 4 bits)
    temp = temp & $80 'mask all but busy flag (db7
    from lcd)
    if temp <> 0 then busyloop 'loop until not busy
    low rw 'back to write
    dirl = %11111110 'reset databus back to output
    return
    And here's a BS2p version...
    '{$STAMP BS2p}
    WakeUp CON %00110000 'Wake up
    ForBitMode CON %00100000 'Set to 4 bit mode
    OneLine5x8Font CON %00100000 '1 line 5x8 font
    OneLine5x10Font CON %00100100 '1 line 5x10 fnt
    TwoLine5x8Font CON %00101000 '2 line 5x8
    TwoLine5x10Font CON %00101100 '2 line 5x10
    DisplayOff CON %00001000 'Display off
    DisplayOn CON %00001100 'Display on, no cursor
    DisplayOnULCrsr CON %00001110 'Display on, underline cursor
    DisplayOnBLCrsr CON %00001101 'Display on, blink cursor
    IncCrsr CON %00000110 'Auto-increment cursor no
    display shift
    IncCrsrShift CON %00000111 'Auto-increment display.
    shift display left
    DecCrsr CON %00000100 'Decrement cursor. No
    display shift
    DecCrsrShift CON %00000101 'Decrement cursor with
    display shift
    ClearDisplay CON %00000001 'clear display
    HomeDisplay CON %00000010 'Cursot to home
    ScrollLeft CON %00011000 'Scroll to left
    ScrollRight CON %00010100 'Scroll right
    CrsrLeft CON %00010000 'Cursor to left
    CrsrRight CON %00010100 'Cursoft right
    MoveCrsr CON %10000000 'Move cursor to position
    MoveToCGRAM CON %01000000 'Move to CGRAM position
    result var word
    btnWork var byte
    Init:
    pause 1000
    gosub InitLCD
    Start:
    high 8
    pause 1
    rctime 8,1,result
    lcdcmd 1,ClearDisplay
    lcdout 1,MoveCrsr+0,[noparse][[/noparse]DEC result]
    'sleep 1
    nap 3
    button 0,1,255,0,btnWork,1,doMessage
    goto Start
    doMessage:
    lcdout 1,MoveCrsr+0,[noparse][[/noparse]"Button"]
    lcdout 1,MoveCrsr+64,[noparse][[/noparse]"Pressed"]
    sleep 1
    goto Start
    InitLCD:
    lcdcmd 1,WakeUp
    pause 10
    lcdcmd 1,WakeUp
    pause 1
    lcdcmd 1,WakeUp
    pause 1
    lcdcmd 1,ForBitMode
    lcdcmd 1,TwoLine5x8Font
    lcdcmd 1,DisplayOff
    lcdcmd 1,DisplayOn
    lcdcmd 1,IncCrsr
    return
    you find for
    Google) and found
    just like
    > the HD44780.
    > -- Jon Williams
    > -- Parallax
    > refky@h... writes:
    functions of LCD
