Frequency Measurement
I'm currently using a BS2 and PULSIN to measure the output frequency
of a magnetic hall sensor (speed and direction) – well, I'm actually
monitoring 2 hall sensors, but they do the same thing. I need to
know when there is no speed (no frequency), and when there is speed
(is frequency).
My problem is this... When there is no speed (no frequency), the BS2
is frozen at the PULSIN instruction waiting for a pulse for 131 ms
before timing out and moving on to the rest of my code. This delay
is killing me. Is there some other way to go about this with a BS2,
or do I need to switch to another microcontroller? I need to know
when there is speed and when there isn't with the lowest latency
possible. [noparse]:)[/noparse]
Thanks in advance,
Chris
(is frequency).
Thanks in advance,
Chris
are measuring, but you can specify the interval to count for, such as
20mS?
-Martin
--- In basicstamps@yahoogroups.com, "crocco17 <crocco17@y...>"
frequency
actually
> (is frequency).
BS2
BS2,
> Thanks in advance,
> Chris
<martin@s...> wrote:
> Would using COUNT be a better choice? I don't know the frequency
you
as
> 20mS?
> -Martin
That might just do the trick. I'll have to think about & test it,
but it sounds workable. I just took the "advanced freq measurement"
StampWorks example and ran with it... [noparse]:)[/noparse]
Thanks Martin. [noparse]:)[/noparse]
Chris
