serious serin problems solved
Sid, All,
It is much chagrin that I report that I had mis-seen the color code on a
pulldown resistor. It was red,red,red, not red,red,orange. Makes a slight
difference, a magnitude of 10 to be exact :-P. Guess I ought to wear my
glasses more when I work, heh.
Works much better now ;-)
Off to slap my forehead some more,
Jonathan
Sent: Friday, January 03, 2003 12:42 PM
Subject: Re: [noparse][[/noparse]basicstamps] Still having serious serin problems (HELP!!)
> Sid,
> Hmmm. I decided to just hook the two Stamps together minus the RF link.
The
> same problem occurred until I remembered to connect the grounds of both
> systems. Now it works fine, with code I have tried over and over. Now with
> the RF setup, obviously the grounds will not be tied together, but this
may
> be a clue. At least I have ruled out any editor error and operator error.
> Now I need to verify the hardware (yet again!) and see if I find problems
> there.
> Thanks for the replies,
> Jonathan
> From: <Newzed@a...>
> Sent: Friday, January 03, 2003 11:56 AM
> > In a message dated 01/03/2003 14:45:07 Eastern Standard Time,
> > jpeakall@m... writes:
> > > it does work, but with the data from "dat" still being incorrect. Is
> there
> > > any possibility this is because I am using the 1.33 editor on my RWS
> side
> > > and the 1.33b version on my TX side?
> > No, different editors has nothing to do with it. Try serouting "A"
> instead
> > of what you are using for dat. Make sure that all cons and vars are the
> same
> > in both programs. When you serin, store the incomuing byte in dat, the
> debug
> > dat. You should get the letter A without the quotes. Let me know.
> > Sid
> > [noparse][[/noparse]Non-text portions of this message have been removed]
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the Subject
and
> Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
Jonathan
> Sid,
The
may
> there.
> Jonathan
> From: <Newzed@a...>
> there
> side
> instead
> same
> debug
> > Sid
and
