OT - but may come in handy...
Hi all,
I've just removed some dead Energizer Titanium AAA size batteries from my
digital camera.
These batteries, and other batteries in the Energizer and Duracell range,
have a indicator on the side so you can see how much energy they have in
them.
Does any one know how they work?
I've just cut one off a dead battery and applied power to it to see how much
current, etc. it takes to go full scale. Figured I could use them as
indicators elsewhere...
It can draw 0.5A!!
I reckon, just by using these built in testers, you'll flatten your
battery...
Anyway, they appear to be a metalic strip, with some sort of black liquid
enclosed that goes clear upon a current going through the metalic strip.
It doesn't matter which way round the current flows, the indicator always
goes up the same way.
Is this some sort of LCD type arrangement?
http://www.lennard.net.nz/
Ben Lennard, NCEE, Dip EE
Electronics R&D - Kiwi Made, Innovative Electronics.
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
digital camera.
them.
It can draw 0.5A!!
battery...
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
that turns clear with heat. When you press the little test buttons, current
flows through the resistive film and generates heat, turning the black stuff
clear. The tapered shape of the resistive film is what makes it able to
display the percent of charge left.
> digital camera.
> them.
much
> It can draw 0.5A!!
> battery...
direction...
I just had a closer look, and yep it's tapered...
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
> From: Rodent <daweasel@s...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Thu, 02 Jan 2003 05:08:23 -0600
> Subject: Re: [noparse][[/noparse]basicstamps] OT - but may come in handy...
> The tester is a tapered piece of resistive film and some type of chemical
>> digital camera.
>> them.
> much
>> It can draw 0.5A!!
>> battery...
> of the message will be ignored.
is little current flow and only one end of the strip gets hot -- only part
of the black stuff turns clear.
Actually, the guy that invented the battery tester probably owned stock in
the company that made mood rings and liquid crystal thermometers -- he
wanted to find a use for all their unsold inventory.
> Ah yes! That explains why it works with current flowing in either
> direction...
chemical
current
stuff
my
> >> digital camera.
range,
in
> >> them.
> > much
> >> It can draw 0.5A!!
> >> battery...
liquid
strip.
always
activated and the more heat the more power the battery has left. A gimmick.
It will run the cell down very fast, but then, they want you to buy more
cells then don't they.
From: Ben [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8TbzpksbcRStvVaJp0c0HsgVKhZe_B6Wb9fMZsSi1U5edo0X3nb9DLgVqnvfFAnOk9GWyUJFR-nOlg]ben@l...[/url
Sent: Thursday, January 02, 2003 4:51 AM
To: Stamps
Subject: [noparse][[/noparse]basicstamps] OT - but may come in handy...
Hi all,
digital camera.
them.
It can draw 0.5A!!
battery...
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
The chemical (black liquid) used is similar to the "MoodRings" of a few decades
back.
