Atomic Time
Does Parallax still have an atomic time module for the Stamp? I didn't
see one on their site. If not does anyone where I could get one?
Rich
Rich
I don't know if Parallax has one, but I have a cheapie method. It depends on
if you need the actual time in data output or just synchronization. I made a
little hillbilly device for my seismic recorder, so that I can synch events
with other stations and calculate epicenter and so on. It actually goes to a
data logging program on a PC not a stamp. Anyway, I took a WWBV clock
movement, and put a photogate where the second hand passes it exactly on the
12 o'clock spot. It is perfect for my needs, as it puts a nice mark on the
data log every minute, so I can easily figure out what time an event
occurred. Very cheap, reliable and resets and synchs itself automatically,
accurate to less than a second, but only useful in some applications. I'm
also guessing you could probe the WWBV clock board and directly tie the
output to the stamp, eliminating the photogate and increasing the resolution
to near perfect. Still no data output though.
Jonathan
www.madlabs.info
Sent: Monday, December 30, 2002 1:06 PM
Subject: [noparse][[/noparse]basicstamps] Atomic Time
> Thanks,
> Rich
hoping Parallax or somebody still made or carried these modules I
remember seeing an ad for them in Nuts & Volts, of course that was
before I had a project that needed them. I am building a lighting
control panel for a customer and I would like to set it up to
automatically adjust for time changes.
Rich
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vP0OgYjUIJC4YEg8v0HqpllA4la3u_SW6sFJe8-rnFB0cn1NnShdO0Ln7JW_PZXSPo7LFBizK-r7S_Mqka258A]jpeakall@m...[/url
Sent: Monday, December 30, 2002 6:45 PM
Subject: Re: [noparse][[/noparse]basicstamps] Atomic Time
Rich,
depends on
made a
events
to a
the
the
automatically,
I'm
resolution
Jonathan
www.madlabs.info
> Thanks,
> Rich
and
The Atomic Time Clock hasn't been available from us for over a year. If my
memory serves me
correctly, the manufacturer of the product faced a discontinuance of one of the
main components and
was no longer able to make the product. The name of the manufacturer is
Ultralink, but I don't have
up to date contact information.
Erik Wood
599 Menlo Dr., Suite #100
Rocklin, CA 95765
(916) 624-8333
www.parallax.com
From: Richard Brull [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=QjEHKWEFv_IICvH9VnWX3Pt47L5FY3E15b4G1qAhX_X_niXEqShCJ0DfwVOi8lbIrryQGSfBE7wHTQU9MfELiEA]rich@c...[/url
Sent: Thursday, January 02, 2003 7:25 AM
Subject: RE: [noparse][[/noparse]basicstamps] Atomic Time
Thanks Jonathon, neat idea I may have to give it a try although I was
Rich
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=t8tBpx6dWdPoAUxrH8upi73C0LIww08uN0s73ZoBIm7jb5-rDFOXl4UFCypl_JW9uyr6r3OzZshWe-3H0yk]jpeakall@m...[/url
Rich,
depends on
made a
events
to a
the
the
automatically,
I'm
resolution
Jonathan
www.madlabs.info
> Thanks,
> Rich
and
from the same email address that you subscribed. Text in the Subject and Body
of the message will
be ignored.
I was asking Parallax at COMDEX about this and thats when I found they no
longer had the module. I have been working in my present project with
atomic clock stuff and WWVB. This is what I can tell you.
If you go to this link:
http://www.maplin.co.uk
and do a search for the following items:
MK68Y (The module)
MK72P (The antenna)
You will see what the module and antenna look like. They sell these parts
for very high prices. No thanks.
The 4 main connections on the module are power, ground, module on-off, and
digital signal.
The digital signal is the demodulated 60khz signal transmitted from WWVB in
Colorado.
There is also a place for the antenna to tack on the module as well.
You can find info on this and the transmision specs here:
http://www.boulder.nist.gov/timefreq/stations/wwvb.htm
Since the signal is so weak, it is best to use an antenna with a ferrite core.
If you go buy a cheap atomic clock (8.00 on eBay or 12.00 at WalMart) then
you can crack it
open and start mining for parts. I know its basically destroying a
perfectly good clock but
you can feel better about it justifying it in the name of science. You only
need to cannibilize
2 pieces anyway and if you are careful you could replace them back and the
clock would function
fine again anyway. (Voice of experience). The 2 parts you grab are the
ferrite antenna which is
all ready with capacitor attached and tuned to 60khz. Believe me, winding
your own is a pain in
the ***. The other part you want is the 4 connector module. It looks very
similar to the pic at
the Maplin site listed above.
You can take these pieces and slap them on a breadboard. Measure the power
at the module while
it is still in the clock if you can because it has a low operating voltage.
You can hook the
digital out to an oscilliscope and see the most unpredictible signal you
ever saw. Its not like
the pretty bit-code picture they show at the NIST site. This is because
the signal is weak and has
dropouts. Thats why some atomic clocks (radio controlled - lets get that
straight) wont even set
themselves right off the bat. The signal is much better at night. One thing
I am gonna guess at
here is the little antenna looking deal on the LCD of the clock that shows
signal strength. I dont
see anything in the clock that is a signal strength circuit, just the
module. So here is my therory:
You have you software look for the start of the WWVB signal (2 80ms
pulses). If your code is such
that it is a 'state engine', that is if you receive a pulse that is not
acceptable within the guidelines
of the NIST time code, then you must start back at the beginning state,
then the amount of acceptable pulses
that you do receive succesively will indicate a relative signal strength.
You must have a minute worth of acceptable pulses, after the start of the
time code signal, in order to
obtain all the info you need to set a clock. The signal is being
transmitted at 1 baud or 1 bit a second.
Anyway I am still working with this now and maybe I can come up with a
module to approach Parallax with
that includes the serial interface like the abandoned module did.
I havent put everything here and would answer any questions that I can from
my experience with this project.
Bob
At 08:15 AM 1/2/03 -0800, you wrote:
>Hi Rich,
my memory serves me
of the main components and
>Erik Wood
>Parallax, Inc.
>Rocklin, CA 95765
>(916) 624-8333
>www.parallax.com
>From: Richard Brull [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jaBH0J7KWzeGg8NvFRDohj-Hiq7nP3bgnnRahOnWEYYi7mhCK2XUtpf9BdrtKfQybN7sKjIJvQ313fXv-iUnGQ]rich@c...[/url
>Rich
>From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dXo6OtI1hHc1R43p4n1Ip1Ow2FNzhKVYCk7WdfSGZOyUz-C90TT-cGoz74qP5-hSSU-D5WqqVq-xOvksAx31CA]jpeakall@m...[/url
>Rich,
>depends on
>made a
>events
>to a
>the
>the
>automatically,
>I'm
>resolution
>Jonathan
>www.madlabs.info
>From: "Richard Brull" <rich@c...>
>> Thanks,
>> Rich
>and
>be ignored.
manufacturers:
http://www.boulder.nist.gov/timefreq/general/receiverlist.htm
Someone had also mentioned hacking one of those analog atomic clocks and
using the sweep hand to mark each second. I would check the documentation
carefully before buying any of these clocks -- some of the clocks without an
external antenna connection only attempt to acquire the time signal at
night, when the reception is best. The rest of the time the clock is only as
accurate as its internal timebase.
> MK68Y (The module)
> MK72P (The antenna)
> digital signal.
in
> Colorado.
core.
> you can crack it
only
> need to cannibilize
> at the module while
voltage.
> You can hook the
thing
> I am gonna guess at
from
> Bob
> >Hi Rich,
> my memory serves me
> >Erik Wood
> >Parallax, Inc.
> >Rocklin, CA 95765
> >(916) 624-8333
> >www.parallax.com
> >From: Richard Brull [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Ir6tZRKaxQlP57FyzoMe7cc1--ad17ENx2U2fdPsd31Pio_InDlN7Uv_ff3GixxoXnDMtmkqRmcQPH_xFA]rich@c...[/url
> >Rich
> >From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MuHE3jwRPTKrRWUoC_0b9GOjLRHPJDFsUya06S0ZY19cJO7Z6w0Nn81qkFKUWV2HfS1CgczNxo34UnWk-ovj]jpeakall@m...[/url
> >Rich,
> >depends on
> >made a
> >events
> >to a
> >the
> >the
> >automatically,
> >I'm
> >resolution
> >Jonathan
> >www.madlabs.info
> >> Thanks,
> >> Rich
> >and
> >be ignored.
I have one of those analog atomic time clocks and was wondering how often
does it receive the WWVB signal.
Gene
P.S. It's a hoot to watch it on the DST change twice a year!
Give me a cup of coffee without cream; sorry, you'll have to take it without
milk, we don't have cream.
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_93t_WKqrKNa3GpffDMno9G1h_EFzq-0x1DlpktpLOqd1t5u-4pvriBbX9LJoUiEvgkprEnsyoIHVMjjp70]daweasel@s...[/url
Sent: Thursday, January 02, 2003 5:02 PM
I found this while scanning the WWVB site -- a list of receiver
manufacturers:
> MK68Y (The module)
> MK72P (The antenna)
> digital signal.
in
> Colorado.
core.
> you can crack it
only
> need to cannibilize
> at the module while
voltage.
> You can hook the
thing
> I am gonna guess at
from
> Bob
> >Hi Rich,
> my memory serves me
> >Erik Wood
> >Parallax, Inc.
> >Rocklin, CA 95765
> >(916) 624-8333
> >www.parallax.com
> >From: Richard Brull [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1oslMIDvaXxDuDSdLa2POsK9QatA7iBykQglOI03PDfc21HnM32jyN9JjK1yPF2OATqQ_O_VqG-Z6pIwKvgdNdo]rich@c...[/url
> >Rich
> >From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-hfzsv8bA7RKjsHWFSA4GcP8FqkLavjAVt6AW66Drk-Q9kVLMY1WvjxdxmbsLaOLMWS-UyHBNuPK-_mzCGo]jpeakall@m...[/url
> >Rich,
> >depends on
> >made a
> >events
> >to a
> >the
> >the
> >automatically,
> >I'm
> >resolution
> >Jonathan
> >www.madlabs.info
> >> Thanks,
> >> Rich
> >and
> >be ignored.
My clocks say they receive signal 4 times a day although I can't verify it
because once
the inital sync happens, the antenna LCD pic stays full as if to indicate
lock.
If you make your own from a ready made clock and use the module, it will
continue to receive
as long as you apply the 'module on' signal.
I have looked at that receiver list from NIST before but it all came back
to the same issue
of having to saw off an arm or leg for price. I would love to get my hands
on those little
antennas that are in the wristwatch though [noparse]:)[/noparse]
Bob
At 05:07 PM 1/2/03 -0600, you wrote:
>Hi,
>Gene
>From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kacBnOYtYQef42iLm27PKjV9ha3-Wj31OgAAgJnCzd6mZp9fo8n_RCMZ4kMkn4M5tCaiHdI6Fv9Idu9iCw]daweasel@s...[/url
>manufacturers:
>> MK68Y (The module)
>> MK72P (The antenna)
>> digital signal.
>in
>> Colorado.
>core.
>> you can crack it
>only
>> need to cannibilize
>> at the module while
>voltage.
>> You can hook the
>thing
>> I am gonna guess at
>from
>> Bob
>> >Hi Rich,
>> my memory serves me
>> >Erik Wood
>> >Parallax, Inc.
>> >Rocklin, CA 95765
>> >(916) 624-8333
>> >www.parallax.com
>> >From: Richard Brull [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tzbKmyJI-SjxI1iPgg4MW7q4oqmz-sdcc-SEIgcvv7DeldlwMpLsJ581mdcDkY5ceVVD8EYlaGuH61sZ3MtfV0A]rich@c...[/url
>> >Rich
>> >From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NYU_xH5ky-494hQl9QzSmFTHr7Y3EubKEoxD2Y5hu6B9AM334iTDYNL9AnGtXRIR-A1qFbyE3qMshE0mdA]jpeakall@m...[/url
>> >Rich,
>> >depends on
>> >made a
>> >events
>> >to a
>> >the
>> >the
>> >automatically,
>> >I'm
>> >resolution
>> >Jonathan
>> >www.madlabs.info
>> >> Thanks,
>> >> Rich
>> >and
>> >be ignored.
built in. They think it's for setting the time on a PC, but there is
no reason you couldn't use this with a stamp.
Then there must be some kind of WWV receiver IC chips out there someplace.
I wonder what all the atomic clocks are using then.
From: Mphil <font_mark@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TjuHloMMnPu6KqF3LpTXKI7boIAVx8vxBVeTllYxCWvmEOJdJXBEODIuJDmKTl3ykG3lh9KeLXnTScQ]font_mark@y...[/url
Sent: Thursday, January 09, 2003 1:55 AM
Subject: [noparse][[/noparse]basicstamps] Re: Atomic Time
The folks at www.arctime.com have a wwv clock that has a serial port
From: Mphil <font_mark@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ffb6RFGQgt4sCeDdx_UGdYLVKo2bAWpckZClRXnyMuTgkZCWNTLvHfPelBEReYsPC5VIPKz0peumiQ]font_mark@y...[/url
Sent: Thursday, January 09, 2003 2:55 AM
www.galleon.eu.com that sells the OEM receivers with an rs232 output. I
will probably purchase one to try out with the Stamp.
Here is the pricing they sent me:
Antenna = 8.12
EM2s = 23.98
MCM RS232 = 26.92
All for quantities of one.
Thanks for all the help,
Rich
From: Earl Bollinger [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ookl3Q6u0zOkaekJB-dkwivL8QBNJhirOJy8rCXHzt11-KZnF1So6qB8W-ejzckIqiH7u0be5G_s0nDzfJ2U]earlwbollinger@a...[/url
Sent: Thursday, January 09, 2003 5:56 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Atomic Time
If they have all these different kinds of clocks that use WWV.
someplace.
From: Mphil <font_mark@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-k8rcO5w4qBA9nz7ptjHxVw3ZPENcd7GnRPKW7JYJfnNAKti0gLI0rMer5TkYbP13Ghly3tT7jjBCg]font_mark@y...[/url
and
got cheap atomic clocks and canibilized them. I robbed the antenna (already
tuned)
and the EM2s type module (they all have same pinouts as I have seen). Then
all you
have to do is bring the pulses into the stamp from the digital out of the
module
and measure the pulse width and match up to the time code protocol that
NIST provides.
The only thing different is that there is no RS-232, but once you get the
time in
who needs RS232?
Bob
At 08:38 AM 1/10/03 -0600, you wrote:
>After some searching on the web I did find this company
>Antenna = 8.12
>EM2s = 23.98
>MCM RS232 = 26.92
>Rich
>From: Earl Bollinger [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LWUYPymr4G2lj_PcZidod5yQou6P4GaOsOl3bR1jC25sIqBsnZvPtb6DwRljA_h3b2ja4n8kHVp7dWOF5vFDXkg]earlwbollinger@a...[/url
>someplace.
>From: Mphil <font_mark@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=a29OazT64CzeXDR0L3iY74s1uCNTCZyjIx2OXJn0xW7oLYhAlFPutm5hINPUmSwSoO9XKeGni9V7vmLz6w]font_mark@y...[/url
>and
Warren
From: tesla@i... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nT_0YJN0vkpE5QO4cw9nDGOyOY53WsfnxVuPsvRO1K2l6WBdyxuVLo_Nrdr9tMjnCnmqK54xIw]tesla@i...[/url
Sent: Friday, January 10, 2003 8:45 AM
This is what I had stated that the individual parts were so high. Thats why
I
tuned)
all you
module
NIST provides.
time in
who needs RS232?
Bob
>Antenna = 8.12
>EM2s = 23.98
>MCM RS232 = 26.92
>Rich
>From: Earl Bollinger [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ASsFoqR9WxbL8TJqDGeGdIWYpEMDWUtK1tu9FQ32FOk8uGO6xzYV5MJ2IcCK9kDOBT_GNXvZGv2ZNcR1WvwUL07K]earlwbollinger@a...[/url
>someplace.
>From: Mphil <font_mark@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-oCQvN9RjJGbBouKfl2VtjinJEA3SIamKbsuaz1R6Q91MXvBD58GORvZRdQ2i7JyEnS-9P78fstT3l-T0w]font_mark@y...[/url
>and
