Lead Acid Battery Desulfators — Parallax Forums
edited 2003-01-01 20:09 in General Discussion
If there are any folks that had wondered about the effectiveness of lead
acid battery desulfators, the following link should dispel any remaining
doubt.
http://www.exideworld.com/News/pressrelease/technology/20021105_exide_introduces\
_charging_unit.html
It seems that some battery manufacturers are beginning to see the light
and are starting to use desulfators at the retail level. I suspect that
the unit mentioned is one of the pulse charging variants of desulfators.
Pulse charging is one of many methods of desulfating a battery of lead
sulfates that are immune to removal by standard battery charging voltage
levels even at the so called equalizing levels (15V to 16V) for a 12V
battery.
As I suspect that desulfators will not be sold to the consumer through
battery outlets, those interested in DIY are invited to participate in
cobbling their own to restore your batteries.
DIY plans and early discussion of homemade desulfators can be found at,
http://shaka.com/~kalepa/desulf.htm
Current discussion of desulfation techniques and planet wide help can be
found at the BBS,
http://pub36.ezboard.com/bleadacidbatterydesulfation
The circuits shown at the links above are easily adaptable to being
controlled by a Stamp in lieu of the 555 IC used. You merely connect a
NTC thermistor to the FET and sense temperature using the RCTIME or POT
commands. A sample PRF program has been uploaded to the "Files" section
of this board.
The BASIC Stamp BS2sx has demonstrated it is a superior controller due
to it's 0.8uSec PULSOUT command. This allows for an extremely fine
grained tuning of an inductor set. When using a PWM program to keep the
inductors at or near saturation results in the most powerful and fast
running desulfator on the planet.
Any Stamp can be used. Even the BS1 works well running a program that
alters PRF in order to control heat gain.
As I get the time I'll upload some chicken scratch schematics and
programs for those interested.
    edited 2002-12-30 12:16
    Ooooooops for some reason the link did not work. Maybe this will
    www.exideworld.com/News/pressrelease/technology/20021105_exide_introduces_chargi\
    ng_unit.html
    edited 2002-12-30 21:13
    Since when was battery charging called de-sulfating? Sulfate won't form if
    you keep the battery fully charged. This looks like a fancy (more costly)
    way to sell a multi-bank (10) trickle charger. Probably useful for stores
    that have up to ten batteries and a very low turnover rate, but hard to see
    how this would be useful to an end-user.
    Lee Mairs
    Sent: Monday, December 30, 2002 7:10 AM
    Subject: [noparse][[/noparse]basicstamps] Lead Acid Battery Desulfators
    > doubt.
    uces_charging_unit.html
    edited 2002-12-31 02:20
    From the article, it is not an end user product.
    There are already pleanty of those on the market. Of course they ar
    not using the term desufate as that would turn up the DIY lists on an
    internet search.
    http://www.vdcelectronics.com/press_room.htm
    Any smart shop who moved a lot of batteries would use this stuff.
    farm/tractor supply, large truck centers, rental places, the list
    goes on. There are dozens if not hundreds of places that would
    benefit from such a unit.
    I see pleanty of markets for such a unit. how about your marina that
    will store your boat battery over the winter ? By spring your
    battery would be better than it was at the end of the season and the
    fee would make everybody happy.
    This technology will change the way we think about car batteries.
    Not that lead acid will be around all that much longer. Fuel cells
    will make lead acid look like buggy whips in 50 years. heck, my cell
    phone uses a NiMH battery. That's nickel metal hydride, the hydride
    being the hydrogene part that is part of the fuel cell technology.
    http://popularmechanics.mondosearch.com/cgi-bin/MsmGo.exe?
    grab_id=67647455&EXTRA_ARG=&CFGNAME=MssFind%
    2Ecfg&host_id=1&page_id=5932&query=fuel+cell&hiword=FUEL+CELL+CELLS+FU
    ELING+FUELS+FUELED+CELLING+FUELER+FUELERS+FUELIN+FUELIE+CELLO+FUELA+CE
    LLES+
    sorry for the long url.
    Dave
    --- In basicstamps@yahoogroups.com, "Lee Mairs \(SAG\)" <lmairs@s...>
    form if
    costly)
    stores
    hard to see
    > Lee Mairs
    > From: "Don Denhardt" <dondenhardt@y...>
    of lead
    remaining
    > > doubt.
    introd
    edited 2002-12-31 07:03
    Hi Lee,
    It is a pulse charger. If the rise time of the pulse is fast enough and
    the voltage spike double the battery voltage, it will desulfate a
    battery. There are some types of sulfate formations in a battery that
    will not clean up when recharging.
    Sulfates do form even if you attempt to keep a battery fully charged,
    unless you have it connected to a small charger to keep them at float
    voltages 24/7. New batteries at the wholesale and retail level will
    sulfate as they sit on the shelf and self discharge. The new battery
    you typically purchase takes from 2 to 5 days of pulse conditioning to
    bring it up to full power.
    There had been some previous discussion about desulfators and some found
    it difficult to believe that you could keep a starter battery functional
    for 20 to 70 years.
    There are many end users that could benefit from desulfating their
    batteries as some folks have many (car, boat, garden tractor,
    motorcycle, etc...). Recovery rates are about 1 day per pound of
    starter battery for batteries that have failed due to sulfation.
    Other end users that live off grid and depend upon large expensive deep
    discharge battery banks to store their wind or photovoltaic generated
    power have chronically undercharged banks which will sulfate up fairly
    rapidly. They may have anywhere from $500 to $5,000 invested in their
    bank which in some cases have been known to fail in as little as 1 to 2
    years.
    I got into pulsing batteries when I got sick and tired of replacing
    garden tractor and motorcycle batteries on a yearly basis. I discovered
    DIY designs at,
    The adaptation of the output stages to a BASIC Stamp to control was
    fairly easy and made for one of the most powerful desulfators on the
    planet.
    > Lee Mairs
    > > doubt.
    edited 2002-12-31 12:29
    Don -
    I have a solar powered beach house on an island off the grid near NYC. I
    just finished my 5th season on the original Trojan T105 batteries w/o
    problems. If batteries are re-charged as soon as they get down to 50%
    capacity the sulfate remains in a powdery form and is easily converted by
    the chemical action. Its folks that leave the batteries alone for months at
    a time that have the problem. Lawn tractors, boats and my Austin Healey
    fall into this category.
    I need to read up on these pulse charging schedules, but from what you said
    it sounds like a modified equalization charge using the leading edge of the
    pulse.
    Thanks for the info.
    Lee
    Sent: Tuesday, December 31, 2002 2:03 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Lead Acid Battery Desulfators
    > Hi Lee,
    > for 20 to 70 years.
    > years.
    > DIY designs at,
    > planet.
    if
    costly)
    stores
    see
    > > Lee Mairs
    lead
    remaining
    > > > doubt.
    edited 2002-12-31 16:03
    Does anone know of an inexpensive load cell, or a source of components to
    make a piezoelectric load cell?
    Sent: Monday, December 30, 2002 6:20 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Lead Acid Battery Desulfators
    > internet search.
    > LLES+
    > Dave
    > form if
    > costly)
    > stores
    > hard to see
    > > Lee Mairs
    > of lead
    > remaining
    > > > doubt.
    > introd
    edited 2002-12-31 16:23
    Hi Lee,
    You are fortunate. If NYC represents New York City, your location is
    helping. Self discharging and sulfation formation rates increase in a
    non-linear fashion in response to temperature increases. Folks that
    live in warmer climates do not fare as well. I hear from many in warmer
    climes that only 1 to 2 years max from their bank.
    But even your bank will fall prey to sulfation buildup eventually.
    Yours will simply take a tad longer than others. Especially if you are
    only taking them down to a 50% state of charge. Check the SG of the
    cells for variance to insure your bank is healthy.
    If you have any lost capacity on your bank (cell SG variation), I
    believe Morning Star PWM charge controllers will assist in bringing them
    back.
    Batteries that are left alone generally fall victim to electrolyte
    stratification (acid settles to the bottom of the case) and sulfation.
    Batteries require periodic gassing in order to stir up the electrolyte
    and keep it well mixed.
    But if the day ever comes that your bank begins to fail, a Stamp pulser
    will revive it quickly.
    Another simple desulfation technique is to use the Stamp as a pulse
    charging controller. Merely take an FET and connect in series with a
    battery that is connected to a voltage source that is at least double to
    triple the battery voltage. Pulse the battery (turn on the FET) with
    10uSec pulses. OR using thermistors to monitor FET temps allow the
    pulse width to increase until the FET is 20DegF warmer than ambient.
    You should not overcharge the battery with small pulse duration pulses.
    > Don -
    > pulse.
    > Lee
    > > Hi Lee,
    > > for 20 to 70 years.
    > > years.
    > > DIY designs at,
    > > planet.
    > if
    > costly)
    > stores
    > see
    > > > Lee Mairs
    > lead
    > remaining
    > > > > doubt.
    edited 2002-12-31 16:39
    Lee
    I would have to disagree with you about service life on batteries that
    are lightly loaded and recharged.
    If you have ever replaced a car battery that has given less than 20
    years service, you have just invalidated any theory regarding the
    success of a charging system alone keeping a battery sulfate free.
    > Don -
    > pulse.
    > Lee
    > > Hi Lee,
    > > for 20 to 70 years.
    > > years.
    > > DIY designs at,
    > > planet.
    > if
    > costly)
    > stores
    > see
    > > > Lee Mairs
    > lead
    > remaining
    > > > > doubt.
    edited 2003-01-01 17:07
    I have read that deep cycle batteries will benefit most from being kept at
    full charge. As such
    I keep a small solar panel on my boat for the deep cycle battery, but
    nothing on the starting battery.
    This leaves me wondering if a symbiosis between the two batteries (a common
    marine arrangement) could
    be derived - if one battery could be used to pulse the other at night and
    re-charge itself during the
    daylight hours...
    edited 2003-01-01 18:17
    Hi Chris,
    Perhaps I've introduced some confusion along the way.
    There are two methods of pulsing a battery with a fast rising pulse to
    desulfate them.
    The original method is pulse charging. This is where the batt is
    subjected to voltages much higher than may be found in automotive
    chargers. The voltages used and the duration of the pulse vary between
    manufacturers and the charge regimen involved. This kind of rules out
    using one battery to pulse another with. Unless you want to go through
    the unneeded complexity of building up a pulse transformer.
    The second method is to use inductive flyback. These devices are simply
    known as dedicated desulfators or pulsers. This is the concept being
    exploited by many pulser manufacturers and by us at the DIY website.
    Although not shown, Stamps make excellent controllers for the process
    and allow you to ride the racers edge of inductor saturation and really
    thunder out some pulses (IF you are monitoring component temps with
    thermistors [noparse]:)[/noparse]
    The inductive flyback created from an inductor pair that when the
    current through the inductors is shutoff, an inductive spike is created
    that is at least double the battery voltage. This method simply uses
    power from the battery being conditioned to operate. Normally the
    current draw is in the 0.050A range, more if you are using a Stamp to
    control FET conduction time and monitor component temperatures. For
    batteries in daily cyclic use (alternative energy systems, automotive,
    etc...), there is no need to bother with making up the power consumed as
    the current draw is light and the charging systems will make up the
    loss.
    Batteries being conditioned "Offline" require the use of a very small
    trickle charger to make up the power lost using a pulser and to recharge
    the newly exposed plate area as the battery is being cleaned up.
    You could hang pulsers on both of your batteries provided that coming
    from the solar panel both batteries are isolated by diodes.
    As starter batteries clean up quickly, another option for you is to
    simply hang a pulser on the starter battery one month out of the year
    and leave it connected to the deep discharge types for the remainder.
    You may want to include the disposition of your batteries in your Will.
    This assumes that the boat is being used at least once a month in order
    that the charging system can gas the batteries to keep the electrolyte
    mixed. Failure to do this leaves you with stratified electrolyte batts
    and the beginnings of many problems that are difficult to treat.
    > daylight hours...
    edited 2003-01-01 18:33
    Ooooooops forgot to mention, starter or deep discharge flooded cell
    batteries have the same requirements.
    Both types benefit from being held (floated) at a full charge. Floating
    a batt is where only enough energy is given to a battery to overcome
    self-discharging losses. Float voltages depend on ambient air or
    battery temperatures, battery type, sulfuric acid blend and plate
    chemistry.
    Both need to be periodically gassed to prevent electrolyte
    stratification.
    > daylight hours...
    edited 2003-01-01 18:58
    Interesting,
    I have a circuit that takes in your lower voltage and doubles it then
    pulses.
    all analog, quad op amp one P-MOSFET, couple status LED's. not hard
    to convert to a Stamp for monitoring or control.
    it's in ExpressPCB currently. let me know if you might want to look
    at it or maybe go in to get one of the boards.
    I just completed it, and am not fixed on the design. improvements
    are welcome in case you want.
    Dave
    --- In basicstamps@yahoogroups.com, "Chris Loiacono \(E-mail\)"
    kept at
    but
    (a common
    night and
    > daylight hours...
    edited 2003-01-01 19:27
    Hi Dave,
    The pulsers we use, I believe, has it's origins in DC to DC conversion.
    Buck and Boost????? Common circuit I am given to understand.
    As a pulser we simply try to get close to inductor saturation without
    damage to get max pulse out.
    The battery voltages can vary whether conditioning offline or online as
    they are cycled or as battery voltage rises in response to conditioning.
    With the varying voltages FET conduction time has to be closely
    controlled to avoid clouds of black smoke and and the odor of smoldering
    or burning polyolefin [noparse]:)[/noparse]
    Would love to see what you came up with though. Might induce new
    directions.
    Although right now I am up to my A-- in alligators as I got swamped with
    orders. I hope to have my backlog cleared out today so I can actually
    do some new work with a pulse charging circuit I have in mind.
    "Dave Mucha " wrote:
    > Interesting,
    > pulses.
    > Dave
    > kept at
    > but
    > (a common
    > night and
    > > daylight hours...
    edited 2003-01-01 20:06
    I've uploaded one of my chicken scratching schematics in the "Photos"
    area. See if it looks familiar.
    > Interesting,
    > pulses.
    > Dave
    > kept at
    > but
    > (a common
    > night and
    > > daylight hours...
    Oooooops forgot to mention that in that poorly drawn schematic, the
    heavy lines are the pulse path. I beef them up on the circuit board
    with desolder braid to lower the inductive loss on the board.
    > > Interesting,
    > > pulses.
    > > Dave
    > > kept at
    > > but
    > > (a common
    > > night and
    > > > daylight hours...
