BS2 If -Then Project
Hello
I am working through a project that uses the If-Then statement to
decide which routine to run. The If -then statement looks at which
pin input is high and which is low, and makes a decision as to which
routine to run. Once the routine has been completed, the program
then goes back to the If-then to see what to do next.
What I would like it to do is go through each routine once only.
That is, if the program sees the output from the If-Then statement
hasn't changed, the program loops the If-Then until it does see a
change.
At present it goes through the routine until the end of its task,
goes back to the If-Then seeing that it is still the same value and
runs the same routine again. (this could cause damage).
I have been looking through the BS2 commands and haven't come across
something that I recognise as helpful. To me, the idea would be to
record the If-Then result and when the program came back it could
compare the old result with the new result - if equal it would keep
looping - if different then it would move on. Of course after the
old result has been used, it is written over by the new result etc.
If someone could help with a hint it would be greatly appreciated.
Thanks Kim
change.
Thanks Kim
pin_state VAR WORD
pin_mask CON %0011010111001010 'or whatever
awaitChange:
IF INS & pin_mask = pin_state THEN awaitChange
pin_state = INS & pin_mask
'followed by routine selection logic
This checks for changes among all 16 I/O pins. If you have only a
few pins to check, you could use a byte- or nib-wide version with
INL/INH or INA/INB/INC/IND. The purpose of pin_mask is to limit
which pins are considered for input changes within the selected I/O
pin subset--may not be necessary depending on which pins count.
Steve
On 29 Dec 02 at 12:52, krcnz krcnz@y... wrote:
> Hello
> then goes back to the If-then to see what to do next. What I would
> like it to do is go through each routine once only. That is, if the
> program sees the output from the If-Then statement hasn't changed,
> the program loops the If-Then until it does see a change...
