Most reliable relay?
Hi All,
I am working on a temperature minder/ backup heater/ overheat over-ride/ for
my aquarium. In normal operation, the Stamp will monitor the temp and
override the heater if required, or turn on the backup heater. In case of
the Stamp failing, I want to have the heater revert to it's independent
operation. So my plan is to have a relay held or latched closed by the
Stamp, then if the Stamp dies, the relay will open and allow the heater to
resume independent operation. So my question is, what is the most rock solid
reliable relay I can use? Assuming the Stamp doesn't fail, the relay will be
in continuous operation for years, and of course with an aquarium,
relaibility is paramount.
Thanks!
Jonathan
Thanks!
Jonathan
will plug into an 8-pin DIP. I have been using them for my model train under
very severe conditions, and have had no problems. Contacts are rated at 1
amp, but with them wired in parallel it will handle 2 amps.
By sever service I mean this - when I start one of my trains up, the relay
will pulse at 20ms intervals for over a thousand times. This happens
everytime I start or stop the train. Relay sounds like a buzzer!!
Sid Weaver
W4EKQ
Port Richey, FL
I don't think I'd worry yourself too much about this aspect of your
project. As long as you pick out a relay that has contacts rated
above the amount of amps you will switch with it, you should be
fine. The most common relay failure I have seen is an open coil, in
which case the relay will not pick up at all. Second would be that
the relay picks up but the contacts do not close due to some
obstruction, such as dirt. It's possible that you could
actually 'weld' the contacts closed if you try to switch excessive
amounts of current. I have seen this only on very large relays such
as those used for industrial crane control. In that application you
are switching very high amounts of current for hundreds (if not
thousands) of iterations in an 8 hour period. Your relays also have
some amount of spring tension on the contacts which force them
apart. The tension is set so that the closing coil can overcome the
spring tension and close the contacts, but enough that the contacts
are pushed apart quickly when the coil drops out.
Ron
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@m...> wrote:
> Hi All,
ride/ for
and
case of
independent
the
heater to
rock solid
relay will be
> Thanks!
> Jonathan
any name brand unit. get one that is low coil wattage so you are not
heating it up too much, power it for the proper voltage and current
rating.
Life of coils is measured in number of closures, not life of coil, so
your infrequent coil closure is not going to effect the life.
The relay Sid listed is small, very unobtrusive and has a closure
rating of like a million closures. Hard to beat that.
Also, the minature unit will have a low power drain meaning low
heat. also good for longer life.
Dave
> Hi All,
ride/ for
and
case of
independent
the
heater to
rock solid
relay will be
> Thanks!
> Jonathan
It is very likely that the Stamp may get "glitched" and your program
stops executing while the relay is still picked.
At the very least you should consider adding a "I'm alive" indicator
such as a slowly blinking LED under software control. If the LED
stops blinking you will know that your program has stopped. I would
also suggest adding several buttons which will initiate failure
events so that you can verify from time to time that all will go as
planned.
Hal
