About transistors — Parallax Forums
About transistors
edited 2002-12-27 23:12 in General Discussion
If I want to control high current by using transistors,let's say
5a,how much curren do I need to give from the PIN,any formular for
this calcualtion?
Thank you.
    edited 2002-12-27 15:56
    Hi Bao,
    I hope someone will make sure I am putting this correctly, but you
    need to find the Hfe for that unit.
    take the total current thru the transistor in your case 5Amps.
    assuming 12 volts as 5A at 5V is a lot of transformer.
    figure your total amps as the supplied amps less the load. for
    instance a relay coil has resistance and will use slighty less. just
    calculate for ohms law.
    but, for a simple start, assume 5 amps.
    divide the total current thru the transistor by the Hfe of the
    transistor. that is the current needed to turn on the transistor.
    assume a Darlingotn with an Hfe of 1,000.
    5 Amps divided by 1,000hfe = 5 mA
    5/1000 = 5mA
    If you had a high power transistor on hand, but it has an hfe of 50
    then 5/50=100mA. you could use that transistor AND drive IT with a
    pn2222. that 100mA needed to drive the primary transistor from the
    2222 would be 100/50 = 2mA (50 being the hfe for the 2222) The high
    power transistor would use the power supply current and not draw it
    from the Stamp.
    This is called a Darlington pair, one transistor driving another.
    Maybe someone will post how to select a MOSFET ?
    Dave
    --- In basicstamps@yahoogroups.com, "baosheng_zhu <ted616@v...>"
    > this calcualtion?
    > Thank you.
    edited 2002-12-27 16:26
    In a message dated 12/27/2002 7:58:01 AM Pacific Standard Time,
    davemucha@j... writes:
    > Hi Bao,
    > 5/1000 = 5mA
    > from the Stamp.
    > Dave
    Your analysis of how to calc required current using HFE is correct.
    There are many logic level mosfets that will also do the job, such as a
    IRL540N(36A). Here is one supplier of them;
    http://www.glitchbuster.com
    edited 2002-12-27 17:55
    Thank you,just a small question,what is hfe?
    --- In basicstamps@yahoogroups.com, "Dave Mucha <davemucha@j...>"
    <davemucha@j...> wrote:
    > Hi Bao,
    just
    > 5/1000 = 5mA
    a
    the
    high
    it
    > from the Stamp.
    > Dave
    for
    > > this calcualtion?
    > > Thank you.
    edited 2002-12-27 18:05
    Hi Randy,
    is the selection of a MOSFET done exactly the same way ?
    I was not sure if the MOSFET uses hfe for the gain ?
    Dave
    > > Hi Bao,
    you
    just
    > > 5/1000 = 5mA
    50
    a
    the
    high
    it
    > > from the Stamp.
    > > Dave
    as a
    edited 2002-12-27 18:20
    simply put it is gain. or what the divosor is. Just the listing to
    let you do the math.
    Dave
    > > Hi Bao,
    you
    > just
    > > 5/1000 = 5mA
    50
    > a
    > the
    > high
    > it
    > > from the Stamp.
    > > Dave
    say
    > for
    > > > this calcualtion?
    > > > Thank you.
    edited 2002-12-27 20:05
    In a message dated 12/27/2002 9:56:32 AM Pacific Standard Time,
    ted616@v... writes:
    > >Hi Bao,
    > just
    > >5/1000 = 5mA
    > a
    > the
    > high
    > it
    > >from the Stamp.
    > >Dave
    HFE is a transistor paramater that describes the current gain of the
    transistor. For example if a transistor has an HFE of 100 then the current
    into the base lead will be amplified by a factor of 100 for the collector
    current.
    Typically a user knows what the collector current will be (the load current).
    Divide the load current by hfe to get the bas current. Once you know the
    required base current, you select the correct size resistor that will yield
    the desired base current.
    Example: Load current is one amp. Transistor HFE is 100. 5 volts will drive
    the base.
    1/100 = 10 ma
    5 v / 10 ma = 500 ohms which is your value for a base resistor.
    This works most of the time, but to be more precise you need to subtract the
    forward biased base emitter diode drop (~0.7v) for the 5v drive....
    4.3 / .01 430 ohms......
    Hi Dave (and everyone)...
    The MOSFETS are selected by a different concept, and are generally easier.
    Traditional "BJT" transistors are generally thought of as current
    amplifiers, so "hfe" comes into play.... How much input current do I need to
    control the load current and have the transistor "saturated" so it is fully
    on?
    With the MOSFETS, you don't have any appreciable steady input current once
    the gate is charged. You can think of the gate as a small capacitor. That
    is simplified, but good enough for what we're doing here. We need to apply
    enough voltage to the gate to turn the transistor fully on, which achieves
    minimum resistance between the "drain" and "source" for the load current.
    As with any switch, the lower the resistance, the better.
    The IRF510 (or IRF511), which is sometimes suggested for Stamp circuits,
    does not fully turn on with a 5V signal at the gate. It can work if you
    aren't pushing the device to the limit, but you always have more resistance
    to your load current than if it was fully turned on (which would require >5V
    gate voltage. That is why I really like (and sell) the logic voltage
    MOSFETS which do fully turn on with a 5V signal. With it fully turned on,
    you have lower resistance which translates to more power delivered to your
    load, and therefore less power turned into heat in your transistor. That
    may mean not needing a heat sink, or needing a smaller one than you would
    otherwise.
    Darlingtons, for example, by their nature have a "one diode" voltage drop
    built in. So even when a Darlington is fully turned on you have that
    voltage drop, which causes power loss to your load (and heating of the
    transistor). Now if you are controlling LEDs and would have a current
    limiting resistor anyway, maybe it isn't a big deal. But if you are
    controlling motors, or other devices that you want to receive full power
    from your supply, the extra loss in a Darlington doesn't make me too happy.
    You can instead select a MOSFET with a current rating and "on resistance"
    value that will result in low power loss in the transistor.
    The gate capacitance isn't a big deal unless you need to duty-cycle the
    MOSFET at a high frequency. If that is the case, you may need to add some
    additional circuitry between the Stamp pin and the MOSFET gate. For slower
    switching, that is generally unnecessary. For example, in the
    Microcontroller Application Cookbook, Matt Gilliland shows the MOSFET gates
    connected directly to the Stamp pins. I usually prefer to add a 50 to 100
    ohm resistor in series near the gate, which is suggested in some data sheets
    to reduce the chance of oscillation.
    When you consider that the IRL520N costs only 68 cents, is easily turned on
    fully by a Stamp pin, can switch 10A continuous and up to 35A pulsed, and is
    a "no brainer" connection to the Stamp I/O pin, it's pretty nice. If you
    need to handle more current, or want an even lower on resistance, the
    IRL530N and IRL540N will do the trick. Just pull one out and plug in the
    "bigger" one -- no "hfe" to worry about.
    Randy
    > Hi Randy,
    > Dave
