controlling LEDs — Parallax Forums
controlling LEDs
edited 2002-12-28 15:26 in General Discussion
I want to control a lot of LEDs (the kind that come with the parallax robot
curriculum, not display terminals). I want to be able to have about 10 of
hopefully up to 200 LEDs be on at once and I'd like to be able to select
those 10 using the Stamp. Do I need a special board to control those LEDs?
If so, does anyone know of one?
thanks
bob
    edited 2002-12-27 08:52
    You don't need a special board, just chips and power. Go to google and
    search for "bs2 led", you'll likely find several examples. The hard part is
    power. Each LED will take around 10ma, adds up real fast!
    Sent: Thursday, December 26, 2002 10:35 PM
    Subject: [noparse][[/noparse]basicstamps] controlling LEDs
    robot
    LEDs?
    > thanks
    > bob
    edited 2002-12-27 09:01
    Bob...
    No special board needed, just properly connected transistors between the
    Stamp and the LEDs. Are you planning to run the LEDs from 5V or perhaps a
    9V or 12V supply? If using 5V you can connect groups of 2 common LEDs in
    series with a current limiting resistor. With 9V or 12V supplies, you can
    connect several LEDs in series (along with the current limiting resistor)
    and control several of these "chains" with an inexpensive PN2222 NPN
    transistor. Or use a IRL520N MOSFET and control a zillion LEDs with one
    Stamp pin!
    When you say "10 of... 200 LEDs" does that mean you will have 20 independent
    groups of 10 LEDs? If so, do you plan to use an IC to expand the number of
    I/O pins available from the Stamp?
    Randy
    www.glitchbuster.com
    robot
    LEDs?
    > thanks
    > bob
    edited 2002-12-27 14:27
    Hi Bob,
    You just need power. use a trasnsitor. A pn2222 will yeild 200 ma
    so at 10mA per led, that is lots of lights. TO-92, and it will work
    directly from a Stamp Pin.
    Assume your pn2222 has an hfe of 50, and you want 200ma.
    you are powering with 12 volts ? with this much power, I assume you
    are not using batteries ? 500 led's at 10mA each = 1/2 amp.
    To look at the current draw,
    10mA for the led, 20 LED's per transistor.
    200ma/hfe50=4ma to drive the transistor into saturation. The Stamp
    can put that into 10 transistors.
    You could put the pn2222 into a Darlingto pair with a something more
    powerful, but that is much more work.
    One ULN2003 Darlington chip will control 7 channels at 500mA per
    channel.
    DIP14 or the ULN2803 with 8 channels. both under a buck.
    for the ULN200x the hfe is 1,000 so you can drive 7 channels with
    50led's/channel with less power from the stamp than one pn2222 needs
    to control 50 led's
    IF you want individual chips, you can use the single TIP120's but the
    cost is up to like over 80 cents each. For that money, Randy at
    Glitchbuster.com can offer MOSFET's.
    I didn't look at the numbers for the MOSFET, but outpt power goes way
    up and input power is still really low.
    Controlling 10 circuits with 500 LED's on a circuit is simple with
    the Stamp. Controlling 500 seperate LED's such as a moving sign is
    considderably more complicated.
    If you are thinking that route, you need to considder speed as the
    serial connection will slow things down.
    Dave
    --- In basicstamps@yahoogroups.com, "Randy Jones" <randyjones@w...>
    wrote:
    > Bob...
    between the
    perhaps a
    LEDs in
    you can
    resistor)
    with one
    > Stamp pin!
    independent
    number of
    > Randy
    > From: <eclecticrr@A...>
    parallax
    > robot
    about 10 of
    select
    those
    > LEDs?
    > > thanks
    > > bob
    Subject and
    edited 2002-12-27 16:20
    In a message dated 12/27/2002 12:53:43 AM Pacific Standard Time,
    pmeloy@s... writes:
    In fact, 10 LEDs at once @ 10 ma each (100 ma) is too much for the stamp to
    handle. To drastically reduce the current needed by the stamp, make the stamp
    turn on a transistor, (like a 2n3904) and have the transistor in turn ground
    the stamp.
    If you need assitance on the transistor hook up (emitter follower is
    simplest), write back.
    You might want to look at the Allegro serial input latched drivers;
    http://www.allegromicro.com/sf/5832/
