sorting numbers in an array
Hi all: I want to sort an array of numbers and find the largest number in
the array. I then want to know which cell of the array contained such a number.
I found some code to do this in Qbasic, but the code uses conventional
if-then statments which cannot be done with the Stamp. I tried converting it
to the Stamps IF statments but made a hash of things.
My ultimate goal is to use it on a robot with a Devantech sensor. I want to
take 5 readings in an arc facing forward, and find the largest value. I then
can turn the robot to face that largest opening.
for example If I got the values 12, 45, 16, 8, 97 I want to return 97 and
the array position. I than will know that the 97 is in the farthest right
position (or value5 of array) and I can turn the robot that direction.
It is the darn sorting routine that is giving me fits. I am a poor
programmer at best.
Could anybody please send me a sorting routine to do this?
Thankyou all very much.
Happy Holidays: Visit my Christmas webpage at
http://mntnweb.com/xmas.htm
Very respectfully, your obedient servant.
Kerry
Admin@M...
WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1575
programmer at best.
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1575
without sorting the array. Like this:
maxDist = 0
maxPos = 6
Find_Max:
FOR idx = 0 TO 4
IF (sonar(idx) <= maxDist) THEN Skip_Val
maxDist = sonar(idx)
maxPos = idx
Skip_Val:
NEXT
BTW ... it's been a long time coming, but PBASIC 2.5 is scheduled to be
released next month. Yes, it actually exists [noparse][[/noparse]in final stages of development
and testing]. The search routine from above looks like this in PBASIC 2.5:
Find_Max:
FOR idx = 0 TO 4
IF (sonar(idx) > maxDist) THEN
maxPos = idx
ELSE
' no else required here!
ENDIF
NEXT
PBASIC 2.5 also includes DO-LOOP and SELECT-CASE. The best part is that it
is compatible with the BS2 modules you have today -- no upgrades are
required!
See my article in the January issue of Nuts & Volts magazine for details.
-- Jon Williams
-- Parallax
In a message dated 12/21/2002 6:15:53 PM Central Standard Time,
admin@m... writes:
> number.
> it
> then
> programmer at best.
> Kerry
> Admin@M...
> Kerry Barlow
> p.o. box 21
> kirkwood ny
> 13795
> 607-775-1575
I have routines that might help you out posted at:
http://www.emesys.com/BS2math5.htm
and choose the link to "median, maximum, minimum, mode and frequency".
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
>such a number.
>programmer at best.
>Kerry
>Admin@M...
>Kerry Barlow
>p.o. box 21
>kirkwood ny
>13795
>607-775-1575
> required!
Woooohoooo!
I sure will - love your articles in N&V.
Michael Burr
branch routine in the wrong place and the < symbol pointing the wrong way,
but my old tired brain just could not leap the final hurdle on its own.
Thankyou very much for the speedy responses.
I too look forward to Pbasic 2.5
-Kerry
At 07:49 PM 12/21/02 EST, you wrote:
>If you only need to know the largest value and position, you can do it
> maxDist = 0
> maxPos = 6
>Find_Max:
> FOR idx = 0 TO 4
> maxPos = idx
>Skip_Val:
> NEXT
>Find_Max:
> FOR idx = 0 TO 4
> maxPos = idx
> ELSE
> ENDIF
> NEXT
>required!
>-- Jon Williams
>-- Parallax
>admin@m... writes:
>> number.
>> it
>> then
>> programmer at best.
>> Kerry
>> Admin@M...
>> Kerry Barlow
>> p.o. box 21
>> kirkwood ny
>> 13795
>> 607-775-1575
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1575
