Conveting ASCI numbers
Archiver
I am getting serial information via the SERIN commands into my BS2
from my DVD7400 Pionneer. When asking for the frame numbers, I get
the numbers in a series of byte, one for each number. to read the
data, I had to make an array byte (serData(7))and then build the
string byte by byte. The problem is that my frame number is now a
string and I can not do any math manipulation on it. I need to
multiply it, divide it etc. Any idea of how to do this conversion?
Many thanks,
Al
Many thanks,
Al
us here can and will help you out. Essentially, though, you can get the
decimal value of an ASCII digit by subracting "0" (decimal 48) from it.
-- Jon Williams
-- Parallax
In a message dated 12/21/2002 12:20:17 AM Central Standard Time,
brownstamp@y... writes:
> Many thanks,
> Al
V=0
For i=0 to 7
v=v*10
v=v+a(i)-"0"
Next i
You want to start at the "left" and work to the right. Of course, you
could go backwards, stop on a terminating character, etc. The answer is
in v.
Hope that helps.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: brownstamp <brownstamp@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=h7ITyrDMceLEVa8ybVDfjNmaucEiR2QSYt9CoQPdbj6verfFO0j_2q3xm_vbZ-gC2ywDcFzkm2-F9g]brownstamp@y...[/url
> Sent: Saturday, December 21, 2002 12:18 AM
> Subject: [noparse][[/noparse]basicstamps] Conveting ASCI numbers
> Many thanks,
> Al
> from the same email address that you subscribed. Text in the
I send the DVD player a status request in the form:
serOut outPin,baud,[noparse][[/noparse]"?F",cr].
I then get the return data via:
serData var byte(7)
serin inPin,baud, [noparse][[/noparse]STR serData\7]
debug str serData
what I get is a string with showing the frame no. in ASCI
for "0054773" for example.
I want to convert that into a real number. I sort of understand
what Al suggested and I am about to try it out, but would like to
also get your opinion. I am doing some very fast searching for
frame numbers and would really like to have as little delay as
possible in my code.
many thanks for staying so late on a Friday night answering yet
another novice's questions.
Al Najjar
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> If you provide more details on how the data ends up in your
string, many of
get the
from it.
> -- Jon Williams
> -- Parallax
BS2
get
the
a
conversion?
> > Many thanks,
> > Al
minutes, seconds, frames? You may want to watch your player's display when
you make the request so you can compare what it says to what you're getting.
That will give you an idea of how you'll do your parsing later.
-- Jon Williams
-- Parallax
In a message dated 12/21/2002 12:45:36 AM Central Standard Time,
the number I am getting through the serial port to the BS2
is "0012345" when I look on the screen of the TV, the frame number
is 12345.
I didn't understand (and I tried the little script from AL W.) to
subtract "0" from the actual ASCI digit but that gives nothing.
Al
> What do those digits represent? Are they broken down into track,
hours,
display when
you're getting.
> -- Jon Williams
> -- Parallax
to
that says v*10 to (v<<3)+(v<<1) which is the same as (v*8)+(v*2) =v*10
but should be faster.
However, you number will be too big for a single 16-bit integer. You
probably need to convert to 3 digit "prefix" number and then a 4 digit
"range" number. That's easy enough:
V0=0
V1=0
For i=0 to 2
V0=(v0<<3)+(v0<<1) ' v0=v0*10
V0=serData(i)-"0"+V0
Next
For i=3 to 7
V1=(v1<<3)+(v1<<1)
V1=serData(i)-"0"+V1
Next
Now V0 would equal 5 and V1 would equal 4773. Since you know all of your
numbers will be between $30 and $39, it might be faster to replace
serData(i)-"0" with serData(i).Nib0. That might be faster, but only
timing will tell for sure.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: brownstamp <brownstamp@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FDtCvPjHRoWZUHLx0MDYnnFghyT0kss6BGt67JkKsEsHqUwBsYe0suJTiCW4xExNf4UG3n6bJbLr4Q]brownstamp@y...[/url
> Sent: Saturday, December 21, 2002 12:45 AM
> Subject: [noparse][[/noparse]basicstamps] Re: Conveting ASCI numbers
> Thanks Jon and Al, always great help!
> serData var byte(7)
> debug str serData
> Al Najjar
> string, many of
> get the
> from it.
> > -- Jon Williams
> > -- Parallax
> BS2
> get
> the
> a
> conversion?
> > > Many thanks,
> > > Al
get. If you get 30 then you have ASCII digits and serdata(0)-$30 (or
-"0") will give you 0, 1, 2, etc. If you get 01 then they are not ASCII
and you simply omit the -"0" and you should be good to go.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
> From: brownstamp <brownstamp@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UhlVRk2Gu3a7kk78F-OajaYki5aMyxwRbS3Hfj1PAtDEe5siftjP0veLabQNG49HuI5lpXN0E3OkKq_SAA]brownstamp@y...[/url
> Sent: Saturday, December 21, 2002 9:10 AM
> Subject: [noparse][[/noparse]JUNK] [noparse][[/noparse]basicstamps] Re: Conveting ASCI numbers
> these numbers represent the current frame number on the DVD. So if
> is 12345.
> Al
> hours,
> display when
> you're getting.
> > -- Jon Williams
> > -- Parallax
> > > what I get is a string with showing the frame no. in ASCI for
> to
Al Najjar
--- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
> What gives you nothing? Try: debug hex serdata(0) and tell us what
you
(or
ASCII
> Al Williams
> AWC
microcontroller
> > From: brownstamp <brownstamp@y...> [noparse][[/noparse]mailto:brownstamp@y...]
if
number
> > is 12345.
> > Al
track,
> > hours,
> > display when
> > you're getting.
> > > -- Jon Williams
> > > -- Parallax
Time,
for
understand
like
> > to
for
as
