SERIN troubles!
I am having weird trouble with SERIN. I have non with SEROUT by the
way! Here is the problem:
I am using a Pioneer DVD7400 with RS232. From Hyper Terminal, I can
send commands (open carriage, play frame etc) and can get
information back such as the current fram # etc.
From the BS2, I send commands to the DVD with no trouble at all
(however commands are slower to execute than through H-terminal).
The trouble is with receiving the information.
With H-Terminal, when I request current frame #, I send the unit ?F
<cr> and I get back 0000500 indicating frame 500. When I do this
from the BS2 I use the following code:
serData Var word
serout 0,16468,[noparse][[/noparse]"?F",cr]
pause 200 (I tried longer and shorter delays with no luck)
serin 1,16468,[noparse][[/noparse]serData]
debug serData.
What I get is a long pause, then a single number like a 0 on the
terminal window. If I send the command once more, the BS2 editor
freezes and then I have to force it to shut down.
Any idea of what's happening and how I can get it to accept the data
from the DVD? Is the fact there are many leading zeros is what
confusing the stamp?
Al Najjar
serData Var word
debug serData.
Al Najjar
0000, the largest word you could receive is 65535 so 0000500
will not fit into a word size var. What is the largest
number you could receive. also remove the pause command.
Sent: December 20, 2002 6:48 AM
Subject: [noparse][[/noparse]basicstamps] SERIN troubles!
SEROUT by the
Terminal, I can
at all
H-terminal).
the unit ?F
do this
> serData Var word
with no luck)
> debug serData.
on the
editor
accept the data
what
> Al Najjar
> from the same email address that you subscribed. Text in
the Subject and Body of the message will be ignored.
come with the Serin. Waiting for 0000 is fine but my frame number
can very well get up to 9999999 with a long DVD. How can I get the
large a value? Also, would that be a string or a number. So let's
say serData is now = 500, can I take that value and divide it by 2?
Al
--- In basicstamps@yahoogroups.com, "Larry Gaminde" <lgaminde@t...>
wrote:
> I would try using the wait modifier and wait for 00, or
> From: <brownstamp@y...>
> SEROUT by the
> Terminal, I can
> at all
> H-terminal).
> the unit ?F
> do this
> > serData Var word
> with no luck)
> > debug serData.
> on the
> editor
> accept the data
> what
> > Al Najjar
serString using a byte you could use the nib variable
instead and pick out your seven digits.
or you could use
n1 var nib
through
n7 var nib
serin 1,16468,[noparse][[/noparse]n1,n2,n3,n4,n5,n6,n7]
larry
Sent: December 20, 2002 7:06 AM
Subject: [noparse][[/noparse]basicstamps] Re: SERIN troubles!
> Thanks! I really need to better understand all the
modifiers that
frame number
I get the
So let's
it by 2?
> Al
<lgaminde@t...>
0000500
> > SEROUT by the
> > Terminal, I can
get
trouble
> > at all
> > H-terminal).
send
> > the unit ?F
When I
> > do this
> > > serData Var word
> > with no luck)
> > > debug serData.
a 0
> > on the
BS2
> > editor
> > accept the data
zeros is
> > what
> > > Al Najjar
in
I tried both the solution on page 512 using the STR with the array
variable as well as your solution of n1,n2,n3 etc with no luck.. The
stamp still lock up and nothing comes out'
Is there any other solutions or insights? If you don't want to read
all of the threads, here is my problem:
serData Var word
debug serData.
wrote:
> On page 312 of the 1.9 manual it shows how to use the
> or you could use
> n1 var nib
> through
> n7 var nib
> larry
> modifiers that
> frame number
> I get the
> So let's
> it by 2?
> > Al
> <lgaminde@t...>
> 0000500
> > > SEROUT by the
> > > Terminal, I can
> get
> trouble
> > > at all
> > > H-terminal).
> send
> > > the unit ?F
> When I
> > > do this
> > > > serData Var word
> > > with no luck)
> > > > debug serData.
> a 0
> > > on the
> BS2
> > > editor
> > > accept the data
> zeros is
> > > what
> > > > Al Najjar
> in
Sent: Friday, December 20, 2002 1:18 PM
> Thanks Larry,
> serData Var word
> debug serData.
> > or you could use
> > n1 var nib
> > through
> > n7 var nib
> > larry
> > modifiers that
> > frame number
> > I get the
> > So let's
> > it by 2?
> > > Al
> > <lgaminde@t...>
> > 0000500
> > > > SEROUT by the
> > > > Terminal, I can
> > get
> > trouble
> > > > at all
> > > > H-terminal).
> > send
> > > > the unit ?F
> > When I
> > > > do this
> > > > > serData Var word
> > > > with no luck)
> > > > > debug serData.
> > a 0
> > > > on the
> > BS2
> > > > editor
> > > > accept the data
> > zeros is
> > > > what
> > > > > Al Najjar
> > in
--- In basicstamps@yahoogroups.com, Mike Blier <w6ffc@p...> wrote:
> Which flavor of the BS2 are u using?
> > Thanks Larry,
array
The
read
the
can
unit ?F
> > serData Var word
> > debug serData.
data
<lgaminde@t...>
> > > or you could use
> > > n1 var nib
> > > through
> > > n7 var nib
> > > larry
> > > modifiers that
> > > frame number
> > > I get the
> > > So let's
> > > it by 2?
> > > > Al
> > > <lgaminde@t...>
> > > 0000500
> > > > > SEROUT by the
> > > > > Terminal, I can
> > > get
> > > trouble
> > > > > at all
> > > > > H-terminal).
> > > send
> > > > > the unit ?F
> > > When I
> > > > > do this
> > > > > > serData Var word
> > > > > with no luck)
> > > > > > debug serData.
> > > a 0
> > > > > on the
> > > BS2
> > > > > editor
> > > > > accept the data
> > > zeros is
> > > > > what
> > > > > > Al Najjar
> > > in
Subject and
Just for grins why don't you try 84 for the baudmode value in case the
data is non-inverted. This brings up another point. Is the data from your
DVD machine "true" RS232 levels? (+- 12-15 volts??) If so are you recieving
the data from the DVD through something like a MAX232? Perhaps the data
FROM the DVD is TTL?? (It matters)
If you don't have the current manual (version 2.0c) go to the website
and download it. Look on page 277 at the note under the baud rate table
about the possibility of a read problem at 9600 baud. If all the things
above are ok then (if you can) try lowering the DVD baud rate to say 2400
and see if that helps. It will at least give a clue to the problem..
Mike B.
Sent: Friday, December 20, 2002 2:28 PM
> BS2!
> > > Thanks Larry,
> array
> The
> read
> the
> can
> unit ?F
> > > serData Var word
> > > debug serData.
> data
> <lgaminde@t...>
> > > > or you could use
> > > > n1 var nib
> > > > through
> > > > n7 var nib
> > > > larry
> > > > modifiers that
> > > > frame number
> > > > I get the
> > > > So let's
> > > > it by 2?
> > > > > Al
> > > > <lgaminde@t...>
> > > > 0000500
> > > > > > SEROUT by the
> > > > > > Terminal, I can
> > > > get
> > > > trouble
> > > > > > at all
> > > > > > H-terminal).
> > > > send
> > > > > > the unit ?F
> > > > When I
> > > > > > do this
> > > > > > > serData Var word
> > > > > > with no luck)
> > > > > > > debug serData.
> > > > a 0
> > > > > > on the
> > > > BS2
> > > > > > editor
> > > > > > accept the data
> > > > zeros is
> > > > > > what
> > > > > > > Al Najjar
> > > > in
> Subject and
the numbers I was getting from the DVD are a byte for each
character. Thanks for your help
Al
> Ok, I'll assume you mean the plain BS2 and not the E, SX or P
versions.
case the
from your
recieving
the data
website
table
things
say 2400
problem..
> Mike B.
> > BS2!
> > > > Thanks Larry,
> > array
luck..
> > The
to
> > read
by
> > the
Terminal, I
> > can
all
terminal).
> > unit ?F
this
> > > > serData Var word
> > > > debug serData.
the
editor
the
> > data
what
> > <lgaminde@t...>
> > > > > or you could use
> > > > > n1 var nib
> > > > > through
> > > > > n7 var nib
> > > > > larry
> > > > > modifiers that
> > > > > frame number
> > > > > I get the
> > > > > So let's
divide
> > > > > it by 2?
> > > > > > Al
> > > > > <lgaminde@t...>
> > > > > 0000500
command.
with
> > > > > > > SEROUT by the
> > > > > > > Terminal, I can
> > > > > get
> > > > > trouble
> > > > > > > at all
> > > > > > > H-terminal).
> > > > > send
> > > > > > > the unit ?F
> > > > > When I
> > > > > > > do this
> > > > > > > > serData Var word
delays
> > > > > > > with no luck)
> > > > > > > > debug serData.
> > > > > a 0
> > > > > > > on the
the
> > > > > BS2
> > > > > > > editor
> > > > > > > accept the data
> > > > > zeros is
> > > > > > > what
> > > > > > > > Al Najjar
Text
> > > > > in
> > Subject and
Subject and
b var word
serout 0,16468,[noparse][[/noparse]"?F,cr]
serin 1,16468,1000,[noparse][[/noparse]dec b]
the 1000 in milliseconds is the timeout or the time that the pin will listen for
the response from the DVD player.
Page 311 of the 1.9 manual describes the DEC numeric modifier among others.
I hope this is of some help to you.
Good Luck and Happy Holidays!!
Deneb
From: brownstamp <brownstamp@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BVoW3YXJD9tS9LEPNnGCRhQUC3fe6jCVQCqzxXn4UcGjpDhh2EOZmycsWbXAh_rjdXfUrhkkSUpYTeYwCw]brownstamp@y...[/url
Sent: Friday, December 20, 2002 6:48 AM
serData Var word
debug serData.
Al Najjar
from the same email address that you subscribed. Text in the Subject and Body
