Inputs from bs2-ic does not respond to the pr
Thomas-
I don't see a problem with your code. Do you have a pullup resistor
on I/O 2 so that it's not floating when low is not asserted? What
happens when you connect I/O 2 to +5 volts instead of your control
signal?
Steve
On 19 Dec 02 at 19:15, th_sak th_sak@y... wrote:
> THE PROGRAM I HAVE DOANLOADEDE TO THE BS2 IS:...
signal?
Steve
