Pause For Microsec
Hi Every1,
I'm using BS2 for my school project. As my project is based on a time
critical application, I need to have time delays in terms of
microseconds.
Luckily, there's a "PAUSE" command for all BS but this command can
only support for miliseconds. I even tried to do like this just to
get a delay of 500 mircosec "PAUSE 0.5" but it is not acceptable by
the Editor. :-(
Is there any other way where I can use other commands that can
support microseconds?
Yes, I have tried "PULSOUT" (can support microsec) but it can only
produce a pulse not a time delay that i wanted.
PCTSP
microseconds.
the Editor. :-(
PCTSP
PAUSE lower than 1 ms is just plain tough. That said, you can do a PAUSE 0
which will give you about 100 microseconds. That's about the best we can do
with the BASIC Stamp.
If you really need that much precision, you could switch to assembly and use
the SX directly ... that will give you complete control. Tougher to write
code though.
-- Jon Williams
-- Parallax
In a message dated 12/19/2002 11:16:31 AM Central Standard Time,
pctsp@y... writes:
> Hi Every1,
> microseconds.
> the Editor. :-(
> Thanks,
> PCTSP
use
> code though.
Is there some kind of PBasic firmware on the Stamp you need to overwrite to
do this, or can you simply download Assembly?
Robert
micro-controller and program like a assembly freak.. Oh boy, can't
use BS...:-(
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> Remember, you're working with an interpreter, not a compiler -- so
getting a
PAUSE 0
we can do
assembly and use
to write
> code though.
> -- Jon Williams
> -- Parallax
> pctsp@y... writes:
> > Hi Every1,
time
> > microseconds.
can
to
by
> > the Editor. :-(
only
> > Thanks,
> > PCTSP
like making a pin high then immeadiately low.
ie...put an oscope on pin 0 for example. then send the commands to make pin 0
high then low. Measure the time of the high pulse. Based on this time to go
high then low, you can stack up several commands to get close to the delay
time you want.
cannot reprogram the Stamp interpreter.
-- Jon Williams
-- Parallax
In a message dated 12/19/2002 11:39:21 AM Central Standard Time,
uavscience@f... writes:
heard that it works well and is farily easy to use -- and has short delays
like what you need.
-- Jon Williams
-- Parallax
In a message dated 12/19/2002 11:40:54 AM Central Standard Time,
pctsp@y... writes:
> Thanks for the advice. In that case, I may need to use a hard-core
> use BS...:-(
different architecture, just some added hardware. Maxim has a
selection of programmable and fixed delay lines.
http://para.maximic.com/compare.aspFam=ProgDel&Tree=Timers&HP=Timers.c
fm&ln=
Jason
> You might want to look into SXWiz (BASIC compiler for SX micros).
We've
delays
> like what you need.
> -- Jon Williams
> -- Parallax
> pctsp@y... writes:
core
can't
> > use BS...:-(
How dose one acquire the Sxwiz. . That would mean that it is not
nesesary to buy
Micro labs Pic Basic Pro. Any comments ?
You could use just a plain old PIC. Cheap to write code, cheap to program,
especially if you need such accurate timing critically. If you're
programming in assembly (which is not that difficult) you don't need Pic
basic or any tools other than what Microchip provides for free.
The programming hardware, if you don't want to make it urself, should be
able to be had for less than US$40, and programming software is free
depending on which PIC you choose.
With a 20MHz crystal a PIC can give you up to 200ns resolution using the
noop command.
HTH.
Mos.
84 AE86, 90 ST185GrpA, 91 MX83Gr, Sydney, Oz.
On Thu, 19 Dec 2002, Lawrence C. Windrem wrote:
> Hey
> nesesary to buy
Where do i get info abt Sxwiz? Am I able to get it from Parrllax?
PCTSP
--- In basicstamps@yahoogroups.com, Mos <mos@s...> wrote:
> Hi,
program,
need Pic
should be
using the
> noop command.
> HTH.
> Mos.
> > Hey
not
> > nesesary to buy
HREF="www.sxwiz.com">www.sxwiz.com</A>.
-- Jon Williams
-- Parallax
In a message dated 12/20/2002 12:10:52 AM Central Standard Time,
pctsp@y... writes:
