I don`t find a timer regirter into BS2p40
I need a information about the registers, where i can find nformation
about TIMER or Cycle to program my clock and Date..... Because i need
a internal signal with 1 sec or 1msec to programing my specific
application (Big Clock and Date with 7-segment (Very big)24 led per 7-
segment)...
If you have a program for similary applocation... I appreciate that
you send my by email or you will tell me about what book to read....
Note:
I red the STAMP BASIC BOOK and I didn`t find this information and It
is impossible this chip don`t have this TIMER...
I appreciate your prompt response
Best Regards
Ing Damian Trujillo G.
Venezuela, Caracas
segment)...
Note:
Best Regards
Venezuela, Caracas
external components. Not completely true - you can use the PAUSE statement
to generate a delay, but then you have to make sure all the various paths
through your program are the same length (in terms of instruction timing)
so that the delay plus the instruction timings are a constant. The to
calibrate the whole thing, you need access to a frequency counter/timer so
you can measure the period of the loop, and adjust the PAUSE delay until
you come up with a 1 second period for the loop. Messy indeed.
If you look on the Microchip web site, you will find application notes for
the Stamp. Appnote 20 describes how to use a 32768 hz watch crystal and a
divider chip to generate accurate time intervals, such as 1 second. This
works - I've done it.
Larry
>segment)...
>Note:
>Best Regards
>Venezuela, Caracas
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Larry Bradley
Orleans (Ottawa), Ontario, CANADA
Since the BASIC Stamp interpreter controls all the internal registers, your
best bet is to use an off-chip RTC like the DS1302 or the PCF8583. Both will
save you the trouble of synthesizing the time and date. You can find lots of
demo code for each at our web site.
Happy Holidays.
-- Jon Williams
-- Parallax
In a message dated 12/18/2002 10:54:56 AM Central Standard Time,
dtrujillo_riese@c... writes:
> segment)...
> Note:
> Best Regards
> Venezuela, Caracas
code I came up with. Though I wouldn't actually use it but it should get you
started Sounds like I will be able to read your clock from where I stand.
Keep us posted.
seconds var byte
minutes var byte
hours var byte
days var byte
curhr var byte
curmin var byte
gosub update
for seconds = 0 to 60
if seconds = 60 then zerosec
if minutes = 60 then zeromin
if curmin = 60 then zerocurmin
if curhr = 24 then zerocurhr
pause 928 'calibrate here. last time i ran this
'program it lost 3 minutes in 2 hours
debug home, ? seconds, ? minutes, ? hours, ? days, cr, "Time is now ", dec
curhr,":",dec2 curmin
next
zerosec:
seconds = 0
debug cls
minutes = minutes + 1
curmin = curmin + 1
return
zeromin:
minutes = 0
hours = hours + 1
if hours = 24 then zerohrs
return
zerohrs:
hours = 0
days = days + 1
return
update:
if seconds + minutes + hours + days = 0 then currentime
return
currentime:
curmin = 8 'put current minutes here
curhr = 10
return
zerocurhr:
curhr = curhr - 24 'put current hour here
return
zerocurmin:
curmin = curmin - 60
curhr = curhr + 1
return
