SV: [basicstamps] liqiud level sensor using a DS2405 — Parallax Forums
edited 2002-12-15 19:54 in General Discussion
Greetings!
I would say that it depends on how pure the water is.
Pure water is a lousy conductor...
Also, it's not always advisable to use electrisity near water.
There's no way you could use a simple flotation device, then?
(A piece of foam, connected to a microswitch which connects or deconnects a
DS2401 to the 1-wire bus)
It's much simpler to measure...
(Either the chip is there or it isn't :-)
Trygve
Opprinnelig melding
Fra: uriwimi6 <uriwimi6@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aPQEIo6NN_Pn-VPzkPuqPDJ3WOpCFfBFoSyGRm35WrSfbVB-Of3dAQQAKri0HEFi1n6Q_cPXH8-t0LWV]uriwimi6@y...[/url
Sendt: 15. desember 2002 19:44
Til: basicstamps@yahoogroups.com
Emne: [noparse][[/noparse]basicstamps] liqiud level sensor using a DS2405
I was wondering if anybody on the list can tell me if the circuit
I've concocted will work. I uploaded to the photo section as
Ds2405_liq.
Kevin M.
    What is the liquid you are using?
    I built a bilge pump controller for my sailboat using a Stamp. It is
    basically a water level sensor. The water in this case is lake or river
    water - even tap water works.
    The sensor consists of two stainless steel screws about 1 inch apart (the
    probes), connected to two Stamp pins.
    The Stamp sets one pin as input, the other as output. It then puts a high
    on the output pin, and checks to see if the input pin is high. If so, there
    is water!. I found that tap water has enough conductivity such that 5 volts
    from a stamp output pin through the water to the input will cause the input
    pin to turn on.
    One of the problem of using direct current on probes in water is that you
    can actually cause electroplating to occur. Alternating current is better.
    So the code in the Stamp alternates the input and output pins each time
    through the testing loop, so that one pin has 1 +ve voltage on it one time,
    and the other pin has it the next time.
    If you are interested in pursuing this approach, let me know and I'll dig
    up the schematic and code for you.
    Larry
    At 07:55 PM 12/15/2002 +0100, you wrote:
    >Greetings!
    >Trygve
    Opprinnelig melding
    >Fra: uriwimi6 <uriwimi6@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Q7w7FBR2l2zMOcUINwPngg4q4SOdiAOb5X0N5TbfwmauD0FPUHiECzv39ZF23FRFloIAYE535IvLjFU]uriwimi6@y...[/url
    >Hi,
    >Ds2405_liq.
    >Thanks
    >Kevin M.
    Larry Bradley
    Orleans (Ottawa), Ontario, CANADA
