Master Reset
I would like to do an automatic MASTER RESET 2 seconds after power
has been applied to the STAMP. I would like to do it with software
and a jumper.
I am thinking of taking an unused output (#12) and connecting it to
the MASTER RESET pin on the STAMP. My assumption is that output #12
can sink the current of the MASTER RESET input when its a 0.
I would program the STAMP as follows:
OUT12 = 1 (This is in my setup initialization)
PAUSE 2000 (ALLOW power stabilization of unit STAMP is controlling)
OUT12 = 0
PAUSE 100 (100 MS)
OUT12 = 1
Can this direct wraparound from an OUTPUT to the MASTER RESET be done?
Jay
Direct is pcb4u@e...
and a jumper.
OUT12 = 0
PAUSE 100 (100 MS)
OUT12 = 1
Jay
The notion of resetting the Stamp by driving RESET low from an I/O
pin is valid. However...
Stamp manuals advise not to drive RESET high. It's not necessary,
since it's pulled high on the Stamp PCB anyhow. In any event, note
that this statement will have no effect unless I/O 12 was earlier set
to output. If you do nothing to I/O 12 after a reset, it will be an
input and the Stamp's pullup resistor will hold RESET high unless
and until something drives it low.
> OUT12 = 0
Consider using "LOW 12" instead. That sets the pin to output, low.
At that point, the Stamp will be reset and execution will resume back
at the start with I/O 12 (and all other I/O pins) returned to the
input condition by the Stamp's reset logic. As a result, the
follow-on statements will never execute:
> PAUSE 100 (100 MS)
> OUT12 = 1
Steve
I found a way to do that project that will work for ALL radios and no need
for hardware band info from the radio..'
73 - W6FFC
Sent: Saturday, December 14, 2002 6:45 PM
Subject: [noparse][[/noparse]basicstamps] Master Reset
> and a jumper.
> OUT12 = 0
> PAUSE 100 (100 MS)
> OUT12 = 1
> Thanks
> Jay
around an I/O I guess it will work per the other response.
Lets see....(1) You use a manual switch (2) Use frequency synthesis
(3) dont get on the air.
Havent been on 220 since the truck with the radio is in AZ. My son
should be completing his entire degree by Xmas (all academics done,
just flight). He has his multi-engine instrument rating, now going
for commercial rating.
--- In basicstamps@yahoogroups.com, Mike Blier <w6ffc@p...> wrote:
> Still fooling with that antenna switchbox Jay?
and no need
> 73 - W6FFC
> From: <pcb4u@y...>
> > and a jumper.
to
#12
controlling)
> > OUT12 = 0
> > PAUSE 100 (100 MS)
> > OUT12 = 1
done?
> > Thanks
> > Jay
Subject and
I miss something in your explanation?
If I set 12 to be an output (dirs=%0011111111111111) during
initialization, then set 0ut12=0 you say the chip will reset. But
doesn't that look like a never ending loop if the code goes to the
top line??????
I would like to process as follows:
POWER ON TO STAMP AND EXTERNAL EQUIPMENT
WAIT 2 SECONDS FOR STABILIZATION
RESET STAMP (SOFTWARE VERSION OF RESET BUTTON)
EXECUTE PROGRAM
APPLY EXTERNAL POWER
BEGIN STAMP CODE
SERDATA VAR BYTE(4)
FREQ VAR WORD
dirs=%0011111111111111 'P1-P13 OUTPUT,P14 AND P15 INPUTS
PAUSE 2000
out1=0
out2=0
out3=0
out4=0
out5=0
out6=0
out7=0
out8=0
out9=0
out10=0
out11=0
out12=0 'RESET STAMP
out13=0
END STAMP CODE
On the reset, would it begin at the top line of the code, thus
creating a loop? Or would it continue executing the code following
the line of code "out13=0"?????
Thanks for your help
Jay
--- In basicstamps@yahoogroups.com, "S Parkis" <parkiss@e...> wrote:
> Jay-
set
controlling)
> > OUT12 = 0
low.
back
> > PAUSE 100 (100 MS)
> > OUT12 = 1
> Regards,
> Steve
sample the RF and measure the frequency then switch accordianly. See the
W8ZR (QST featureed article, "The EZ tuner, this year.
http://www.w8zr.net/eztuner/index.htm )home page for the VERY simple circuit
and listing. Maybe $10 in parts plus the Stamp..
73 - Mike
Sent: Sunday, December 15, 2002 11:54 AM
Subject: [noparse][[/noparse]basicstamps] Re: Master Reset
> I got it working. I just have to do a RESET each time. By wrapping
> and no need
> > 73 - W6FFC
> > From: <pcb4u@y...>
> > > and a jumper.
> to
> #12
> controlling)
> > > OUT12 = 0
> > > PAUSE 100 (100 MS)
> > > OUT12 = 1
> done?
> > > Thanks
> > > Jay
> Subject and
I only use 3 wires (RX, TX and ground) from my TS950 to get the
frequency data, run some serial stripping of the data in the STAMP
and let the STAMP tell me where I'm at. Voila, 9 control lines come
out of my control box (STAMP chip plus an NTE2018 driver) to turn on
the the right relay (and LED indicator in the control box) in the
relay box. I designed and had a pc board built by one of those over
night operations I found on the Web.
I need not transmit. As soon as I change bands on the 950, the relay
for that band closes (and the other relay that was on drops off). Its
quite fast...slowest part being the 15-20 milliseconds it takes to
close the relay.
The hardest part was the relays for the switching box. I am using the
relays that Array Solution uses in their 6 PACK antenna control box.
They are 3PDT, 12VDC type which Array Solutions tell me can handle
2KW. They don't appear to be anything special. They are open framed
and aren't marked so I can't find out where to get more. I need to
find a second source for a PC mounted relay (no socket, stright into
board). I like the idea about a 3PDT as all 3 poles on each relay are
wired in parallel, thus dividing the current by 1/3 for each contact.
My box covers all 9 bands (160-10). For the WARC bands, which is the
A3WS plus a 30 meter kit [noparse][[/noparse]1 feed], I diode "OR'd" the 30, 17 and 12
meter NTE 2018 driver outputs to control only one relay in the relay
box.
> Nope, very simple circuit that uses two decade counters and some
diodes to
See the
simple circuit
> 73 - Mike
> From: <pcb4u@y...>
synthesis
done,
> > and no need
> > > 73 - W6FFC
> > > From: <pcb4u@y...>
power
software
> > > > and a jumper.
it
> > to
output
> > #12
> > controlling)
> > > > OUT12 = 0
> > > > PAUSE 100 (100 MS)
> > > > OUT12 = 1
be
> > done?
> > > > Thanks
> > > > Jay
> > Subject and
Subject and
> Thanks for the input. I am trying to figure out something here...did
> top line??????
Absolutely.
> EXECUTE PROGRAM
BEGIN STAMP CODE
> SERDATA VAR BYTE(4)
> FREQ VAR WORD
> PAUSE 2000
> out1=0
> out2=0
> out3=0
> out4=0
> out5=0
> out6=0
> out7=0
> out8=0
> out9=0
> out10=0
> out11=0
> out13=0
END STAMP CODE
Following assertion of RESET, your Stamp would immediately go
through its own reset logic prior to restarting your program. That's
why all the I/O pins would return to the input mode, your program
would start again at the first statement, and the statements after
the reset would never execute. You can't control how the Stamp
resets when you use the RESET pin, you can only enjoy the ride.
Perhaps you could explain what you mean by "RESET STAMP (SOFTWARE
VERSION OF RESET BUTTON)" or what you want to accomplish via a
reset and someone could suggest an alternate approach.
Steve
What I want to do is to apply DC power to the STAMP chip and to the
external equipment allowing the external equipment to stabilize prior
to issuing the serial data (from the STAMP) to the external
equipment.
Maybe what I should do is just PAUSE the STAMP code long enough for
the external equipment to stabilize in the first line of STAMP code
(PAUSE 5000). Then I could then execute the serial command from the
STAMP chip to the external equipment knowing everyone is in a known
state and has stabilized.
This would end the "what state am I in" scenario after power is
applied.
here...did
> > top line??????
> Absolutely.
> > EXECUTE PROGRAM
BEGIN STAMP CODE
> > SERDATA VAR BYTE(4)
> > FREQ VAR WORD
> > PAUSE 2000
> > out1=0
> > out2=0
> > out3=0
> > out4=0
> > out5=0
> > out6=0
> > out7=0
> > out8=0
> > out9=0
> > out10=0
> > out11=0
> > out13=0
END STAMP CODE
That's
> Regards,
> Steve
instead of a forced reset.
Sent: Monday, December 16, 2002 2:14 PM
> Thanks for sticking with me.
> equipment.
> applied.
> here...did
> > > top line??????
> > Absolutely.
> > > EXECUTE PROGRAM
BEGIN STAMP CODE
> > > SERDATA VAR BYTE(4)
> > > FREQ VAR WORD
> > > PAUSE 2000
> > > out1=0
> > > out2=0
> > > out3=0
> > > out4=0
> > > out5=0
> > > out6=0
> > > out7=0
> > > out8=0
> > > out9=0
> > > out10=0
> > > out11=0
> > > out13=0
END STAMP CODE
> That's
> > Regards,
> > Steve
wired in parallel, thus dividing the current by 1/3 for each contact."
This statement will be true only if all three contacts open and close in a
synchronous state. In reality the contacts are chattering in an asynchronous
mode for 1 to 3 milliseconds each time the relay is operated or released.
