New guy with troubles. Need help. — Parallax Forums
edited 2002-12-17 03:00 in General Discussion
Just got my BOE with a BS2 stamp. Installed the Editior V1.33, on my Winbook J4
running XP Pro with a Belkin USB to serial adapter plugged in as COM5. It talks
to my Palm Pilot so I'm fairly sure it works.
Type in the Hello World program but the editor doesn't recognize the BS2 stamp.
When I hit run I get the window that says:
Download Progress
Port Status - Device Type - Version - Loopback - Echo
COM5 blank blank YES YES
When I hit Run, the Belkin serial port LEDs blink several times, so I know the
editor is talking to the serial port.
Could this thing be DOA out of the box? Wrong type serial cable provided?
What do I do next?
Lee Mairs
Northern VA
    edited 2002-12-14 03:21
    If you're going use the same port as you use for your Palm, you have to
    disable your hot sync software so the Stamp editor can use that port.
    We use the Bafo USB-to-Serial cables at Parallax with no problems.
    It is very unlikely that your Stamp is DOA. We test every unit before it
    goes out. Not that it couldn't be bad, but your problem is likely with the
    hot sync software preventing the editor for using that port, or you have a
    USB adaptor that doesn't work with the Stamp (we're not just
    sending/receiving serial data).
    -- Jon Williams
    -- Parallax
    In a message dated 12/13/2002 8:58:15 PM Central Standard Time,
    lmairs@s... writes:
    > Winbook J4 running XP Pro with a Belkin USB to serial adapter plugged in as
    > COM5. It talks to my Palm Pilot so I'm fairly sure it works.
    > stamp. When I hit run I get the window that says:
    > Download Progress
    > the editor is talking to the serial port.
    > What do I do next?
    > Lee Mairs
    > Northern VA
    edited 2002-12-15 19:01
    Jon is right about the palm hot sync programs but I see below that you are
    using the Belkin adapter. I believe I've see several post that say the
    Belkin is not compatible with the stamp stuff. Someone else please speak up
    on this. What adapters are some of you using that do work and with what
    configurations (equipment)
    From: jonwms@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=sWV8eUhfzwcaXfx18EpPdOka0Scba3El07oQbzX-3h772xVOCiRQlXR7pN9zKuy3zmQ8yR-hcE8]jonwms@a...[/url
    Sent: Friday, December 13, 2002 10:22 PM
    Subject: Re: [noparse][[/noparse]basicstamps] New guy with troubles. Need help.
    -- Jon Williams
    -- Parallax
    lmairs@s... writes:
    as
    > Download Progress
    > What do I do next?
    > Lee Mairs
    > Northern VA
    edited 2002-12-15 19:49
    Thanks for the info!
    The Palm Hot sink has to be set manually on my XP environment as I use a
    bunch of different stuff, so that isn't the problem. I'm sure it isn't the
    stamp either since I tried a BS2-SX module also.
    I'll try and find a Bafo USB-to-Serial cable adapter. A D-Link DSB-S25
    also doesn't work, but that is probably a lack of Win XP driver problem.
    I really appreciate the help!
    Lee
    Sent: Sunday, December 15, 2002 2:01 PM
    Subject: RE: [noparse][[/noparse]basicstamps] New guy with troubles. Need help.
    up
    > From: jonwms@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aZ0fHyp5g791HET1wIRBNNVJnP4mj33TzjnYaJpyoRi7b8cEgtu2oMmT-7ACI-cEdfDvQhqrfbv1]jonwms@a...[/url
    the
    > -- Jon Williams
    > -- Parallax
    > lmairs@s... writes:
    > as
    > > Download Progress
    know
    provided?
    > > What do I do next?
    > > Lee Mairs
    > > Northern VA
    edited 2002-12-15 20:42
    What brand of USB adapter do you have at the mo'?
    I found that I couldn't get any Belkins to work, and most Keyspans. I
    couldn't get a hold of the USA-19 that Parallax says works, as my work place
    wanted me to buy it outright with no chance of return - which I wasn't going
    to fall for.
    So, in the end, I did a bit of research, and came across FTDI, and ended up
    *making* my own adapter.
    It works perfectly under Mac OS 9.2.2, and Windows 98 (real and Virtual PC).
    I haven't tested it under XP yet. However, the FTDI solution supports all
    the RS232 lines (which I found was the basic issue - at least for me - with
    the Belkins and the Keyspans that I had access to).
    So, if it isn't something else holding up your serial port, maybe try the
    FTDI solution (http://www.ftdichip.com/). They have a link on their front
    page to my site that will lead you to my adapter...
    cheers,
    Ben Lennard
    *ACSE, ACCE
    *National Certificate in Electronic Engineering
    *Diploma in Electronic and Software Engineering
    "To the optimist, the glass is half full. To the pessimist, the glass is
    half empty. To the engineer, the glass is twice as big as it needs to be."
    No animals were harmed in the transmission of this email, although the
    Dog next door is living on borrowed time, let me tell you! Those of you
    with an overwhelming fear of the unknown will be gratified to learn that
    there is no hidden message revealed by reading this warning backwards.
    > From: "Lee Mairs" <lmairs@s...>
    > Organization: SAG Corporation
    > Reply-To: basicstamps@yahoogroups.com
    > Date: Sun, 15 Dec 2002 14:49:54 -0500
    > Lee
    > From: "Sadler Porter" <porter.sadler@s...>
    > up
    >> From: jonwms@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yK4iiF6n_kBQ77Y28fpcVv2o0eCbpzW3PNlBh542eDmOCOc2h_7CQVeCj3eLkcDuIx-pEg]jonwms@a...[/url
    > the
    >> -- Jon Williams
    >> -- Parallax
    >> lmairs@s... writes:
    >> as
    >>> Download Progress
    > know
    > provided?
    >>> What do I do next?
    >>> Lee Mairs
    >>> Northern VA
    edited 2002-12-16 12:01
    The USA-19 works for me(Tecra/W2K).
    > place wanted me to buy it outright with no chance of return - which I
    > wasn't going to fall for.
    Dontronics has these chips along with info and modules here;
    http://www.dontronics.com/dlp.html
    He is in AU but is easy to order from(and the USD is worth almost 2x AUD).
    > ended up *making* my own adapter.
    > Virtual PC).
    > all the RS232 lines (which I found was the basic issue - at least for
    > me - with the Belkins and the Keyspans that I had access to).
    > the FTDI solution (http://www.ftdichip.com/). They have a link on
    > their front page to my site that will lead you to my adapter...
    > cheers,
    edited 2002-12-16 13:27
    Thanks Mike. Appreciate the info.
    Lee
    Sent: Monday, December 16, 2002 7:01 AM
    Subject: [noparse][[/noparse]basicstamps] Re: New guy with troubles. Need help.
    > > Virtual PC).
    > > cheers,
    edited 2002-12-16 23:14
    This morning I purchased an IOGEAR Model GUC232A-A and it works fine with my
    USB-only laptop running XP. Found it a bit pricey ($39.95 at Micro Center) but
    I got it immedialely. TigerDirect.com had the BAFO adapter for $19.95 but
    refused to ship via USPS to my POB in WV. They cancelled the order, leavng me
    to fight Paypal for a refund...
    Lee Mairs
    > > Virtual PC).
    > > cheers,
    I can second the reoomendation for this IOGear model. BUT -- for use
    with Windows XP, I had to download their latest drivers, because the
    driver in the box wouldn't recognize their USB chip.
    Dennis
    From: Lee Mairs <lmairs@s...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3kmOO7OhTMJtL2xNM1dAkvdHDVerTmuMchhFPl702uJVcy5RRHxAL0OkiNWYJ8mAbAz7eO_Bink]lmairs@s...[/url
    Sent: Monday, December 16, 2002 3:15 PM
    with my USB-only laptop running XP. Found it a bit pricey ($39.95 at
    Micro Center) but I got it immedialely. TigerDirect.com had the BAFO
    adapter for $19.95 but refused to ship via USPS to my POB in WV. They
    cancelled the order, leavng me to fight Paypal for a refund... Lee Mairs
    > > I couldn't get a hold of the USA-19 that Parallax says works, as my
    > > work place wanted me to buy it outright with no chance of return -
    > > which I wasn't going to fall for.
    > AUD).
    > > Virtual PC).
    > > supports all the RS232 lines (which I found was the basic issue - at
    > > least for me - with the Belkins and the Keyspans that I had access
    > > to).
    > > try the FTDI solution (http://www.ftdichip.com/). They have a link
    > > on their front page to my site that will lead you to my adapter...
    > > cheers,
