1 year timer for furnace filters ( beyond reasonable)
Archiver
Since CFM monitoring is much more high tech than most do on this
list, monitoring motor amps is a fair approach. if the belt breaks,
the amps will change. The blower wheel undoubtely had 'forward
curved' fan blades. these use more power as they move more air, but
offer resistance to the motor.
Also. motor hours will offer a decent reflection of furnace use, but
not humidifier use. for that you need to monitor gallons of water.
This is easier still, the solenoid on the humidifier will be on or
off. just tie in to that signal.
A better unit would monitor humidity of the heated air, and also
humidity after the humidifier air was fully mixed with the air
stream. a dirty filter would have a lower RH as it would not
transfer moisture as effectivly.
A still better unit would monitor total water useage. in my
experiance, it is the particulate in the water that clogs the filter
and not any airborne particulate.
and Rodent, a slightly more simple calender monitoring would be to
use a sensor to monitor the tides. the higher pull from the moons
proximity occurs daily and a sensor would not be effected by either
weather or eclipses. I am not sure how this would be effecte by
leap years.
and still another feature would be to monitor the lenght of the days
and nights. the spring and autum equnoxes have equal days and
nights. the Sumer and winter solstace have the longest day and
longest night respectivly. even if weather was bad, you could
program to monitor the days to pin point those 4 days, even by
monitoring the days preceeding and following and comparing day
lenghts.
Dave
wondering if there are any hibernating animals that have a predicable
calendar routine ?
--- In basicstamps@yahoogroups.com, Peter Deutsch <pdeutsch@e...>
wrote:
> Tracy Allen wrote:
> > Hi Greg,
> > Maybe you could use a photocell pointed at the sky. Get the right
> > day-night sensitivity, count to 364 (or 365). You could use a
BASIC
> > Stamp 1 or 2 to do the counting. Give it something else to do
that
> > the same time, say, to remind you when to pay taxes and when to
put
> > out the trash. You could do it with a simple counter, but
decoding
> > the number 365 would take a handful of additional chips.
> Ahhh, but you'd have to put in additional circuitry to account for
> predicted eclipses in your region, and maybe extra circuitry to
provide
> an "unexpected eclipse" button, as well. After all, if some
absolutely
> humongous but so far unplotted celestial body gets between us and
the
> sun, this circuit will fail. If you really wanted to do this right,
> you'd throw in a GPS and try to shoehorn in a celestial navigation
> program. Based upon your measured location, you could account for
known
> eclipses at your location and prompt the user (maybe via email,
maybe
> via a companion onboard web site?) when you experience one of those
> unexplained celestial phenomena...
> Seriously, if you wanted this project to actually have value,
shouldn't
> it provide a count of how many hours the fan has run? Even hetter,
how
> many cubic feet of air have passed through the filter? Throw in some
> sensing to determine actual particulate pollution and you should
> *really* be able to judge filter state...
> - peterd
> > -- Tracy
> > >Greetings Stampers
> > >I've been lurking a long time and learning a lot.
> > >I'm ready to build a project for my furnace to remind me to
change
> > >the 1-year filter on my humidifier.
> > >I'd like to have a simple circuit that I could reset with a
> > >pushbutton that simply sounds a buzzer/flashes an LED after 1
year.
> > >I've been scouring Google, but I can't find anything to steer me
in
> > >the right direction.
> > >Any ideas ??
> > >Thanks a lot
> > >Greg
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the
Subject and Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
> Peter Deutsch pdeutsch@g...
> Gydig Software
> "Time will end all of my troubles, but I don't
> always approve of time's methods..."
leap years.
lenghts.
Dave
calendar routine ?
wrote:
> Tracy Allen wrote:
> > Hi Greg,
BASIC
that
put
decoding
provide
absolutely
the
known
maybe
shouldn't
how
> - peterd
> > -- Tracy
> > >Greetings Stampers
change
year.
in
> > >Any ideas ??
> > >Thanks a lot
> > >Greg
> Gydig Software
The water is purified through RO and pH balanced, the filter/evap pad are
changed annually to prevent excessive bacterial growth.
I considered an impellor flow meter, but the bacterial growth is more of an
atmospheric exposure factor.
So far my best guess is to use a serial RTC like the DS1305, has anyone had
experience with these animals ?
You guys are great, I really enjoyed the replies.
A coworker suggested an organo-geek solution:- Grow wheatgrass that
interrupts a laser at a predetermined height above the grass based on growth
tables for a year ;-)
Greg
"Are you still wasting your time with spam?...
There is a solution!"
Protected by GIANT Company's Spam Inspector
The most powerful anti-spam software available.
http://www.giantcompany.com
Sent: Friday, December 13, 2002 4:23 PM
Subject: [noparse][[/noparse]basicstamps] Re: 1 year timer for furnace filters ( beyond
reasonable)
> leap years.
> lenghts.
> Dave
> calendar routine ?
> wrote:
> > Tracy Allen wrote:
> > > Hi Greg,
> BASIC
> that
> put
> decoding
> provide
> absolutely
> the
> known
> maybe
> shouldn't
> how
> > - peterd
> > > -- Tracy
> > > >Greetings Stampers
> change
> year.
> in
> > > >Any ideas ??
> > > >Thanks a lot
> > > >Greg
> > Gydig Software
I love it, but now you're back to all sorts of environmental sensors, as
growth will vary according to amount of light, temperature, moisture in
the soil, etc (unless of course you grow it hydroponically, which means
you're liable to attract the attention of your friendly local law
enforcement folks... ;-)
Maybe what you can do is some sort of differential circuit arrangement,
in which you have two crops, one in your furnance and one in the open to
act as a control. This would give you a sort of organic OpAmp circuit -
what would matter here is not the specific height, but the difference
between the two crop heights, which in turn would indicate internal
furnace state.
And if you can build an organic opamp, this would seem to open the field
to a whole variety of organic computing elements. Kudos to the first
organic FlipFlop, and if you build an adder you can have that counter
that kicked this thread off.
And finally, imagine the first Turing-complete garden. Yes, you grow it,
then try to get it to past the Turing test...
- peterd (who only occasionally talks to
his plants, who in turn rarely answer...)
Gydig Software
If you used Kentucky Bluegrass it reaches an average height of about
8 inches and spreads out.
Zoysia reaches a height of about 4 inches although seed stems extend
to almost 12 inches.
Saw Palmetto extend over 5 feet for the blades and over 8 feet for
the seed stems.
Bamboo tops 16 feet.
Did he offer any tech data sheets on cailbartion ?
seems that matching the 66% of maximum groth would put the sensor in
the sweet spot for sensitivity. and higher resoultion would be had
by higher growing varieties.
Puts new meaning in the concept of cross-polinating scientific fields.
Dave
(I'm not expecting www.findchips.com to add www.findweeds.com all to
soon)
--- In basicstamps@yahoogroups.com, "Greg Reyneke" <greg@i...> wrote:
> The filter is an evaporator cartridge assembly.
pad are
more of an
anyone had
on growth
> Greg
> From: <davemucha@j...>
> reasonable)
breaks,
but
but
water.
filter
either
> > leap years.
days
> > lenghts.
> > Dave
predicable
> > calendar routine ?
> > wrote:
> > > Tracy Allen wrote:
> > > > Hi Greg,
right
> > BASIC
> > that
to
> > put
> > decoding
for
> > provide
> > absolutely
and
> > the
right,
navigation
for
> > known
> > maybe
those
> > shouldn't
hetter,
> > how
some
> > > - peterd
> > > > -- Tracy
> > > > >Greetings Stampers
> > change
> > year.
steer me
> > in
> > > > >Any ideas ??
> > > > >Thanks a lot
> > > > >Greg
> > > Gydig Software
Subject and
wrote:
> g'day,
that
based on growth
sensors, as
moisture in
means
arrangement,
open to
circuit -
difference
> furnace state.
field
counter
grow it,
> Gydig Software
greener somewhere else eh?
(I know, BAD!)
Sent: Friday, December 13, 2002 7:02 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: 1 year timer for furnace filters ( beyond
reasonable)
an
had
growth
> Greg
> reasonable)
> > leap years.
> > lenghts.
> > Dave
> > calendar routine ?
> > wrote:
> > > Tracy Allen wrote:
> > > > Hi Greg,
> > BASIC
> > that
> > put
> > decoding
> > provide
> > absolutely
> > the
> > known
> > maybe
> > shouldn't
> > how
> > > - peterd
> > > > -- Tracy
> > > > >Greetings Stampers
> > change
> > year.
> > in
> > > > >Any ideas ??
> > > > >Thanks a lot
> > > > >Greg
> > > Gydig Software
and
growth.
There are some examples for the DS1302 in the Volume 1 Nuts & Volts book --
column #33 and #34.
I've done the 4060 timer/oscillator example in column #11 for a countdown
timer, and bought pieces for the DS1302, but haven't done much with them
yet.
> Oh sure, everyone gives suggestions but you're always thinking the grass
is
> (I know, BAD!)
are
> an
> had
> growth
alignment
is complete, should it be a year before it's aligned again?
Leroy
Sent: Sunday, December 15, 2002 10:02 AM
reasonable)
: Oh sure, everyone gives suggestions but you're always thinking the grass is
: greener somewhere else eh?
: (I know, BAD!)
: From: "Greg Reyneke" <greg@i...>
: To: <basicstamps@yahoogroups.com>
: Sent: Friday, December 13, 2002 7:02 PM
: Subject: Re: [noparse][[/noparse]basicstamps] Re: 1 year timer for furnace filters ( beyond
: reasonable)
: > The filter is an evaporator cartridge assembly.
: > The water is purified through RO and pH balanced, the filter/evap pad are
: > changed annually to prevent excessive bacterial growth.
: > I considered an impellor flow meter, but the bacterial growth is more of
: an
: > atmospheric exposure factor.
: > So far my best guess is to use a serial RTC like the DS1305, has anyone
: had
: > experience with these animals ?
: > You guys are great, I really enjoyed the replies.
: > A coworker suggested an organo-geek solution:- Grow wheatgrass that
: > interrupts a laser at a predetermined height above the grass based on
: growth
: > tables for a year ;-)
: > Greg
: > "Are you still wasting your time with spam?...
: > There is a solution!"
: > Protected by GIANT Company's Spam Inspector
: > The most powerful anti-spam software available.
: > http://www.giantcompany.com
: > From: <davemucha@j...>
: > To: <basicstamps@yahoogroups.com>
: > Sent: Friday, December 13, 2002 4:23 PM
: > Subject: [noparse][[/noparse]basicstamps] Re: 1 year timer for furnace filters ( beyond
: > reasonable)
: > > Since CFM monitoring is much more high tech than most do on this
: > > list, monitoring motor amps is a fair approach. if the belt breaks,
: > > the amps will change. The blower wheel undoubtely had 'forward
: > > curved' fan blades. these use more power as they move more air, but
: > > offer resistance to the motor.
: > > Also. motor hours will offer a decent reflection of furnace use, but
: > > not humidifier use. for that you need to monitor gallons of water.
: > > This is easier still, the solenoid on the humidifier will be on or
: > > off. just tie in to that signal.
: > > A better unit would monitor humidity of the heated air, and also
: > > humidity after the humidifier air was fully mixed with the air
: > > stream. a dirty filter would have a lower RH as it would not
: > > transfer moisture as effectivly.
: > > A still better unit would monitor total water useage. in my
: > > experiance, it is the particulate in the water that clogs the filter
: > > and not any airborne particulate.
: > > and Rodent, a slightly more simple calender monitoring would be to
: > > use a sensor to monitor the tides. the higher pull from the moons
: > > proximity occurs daily and a sensor would not be effected by either
: > > weather or eclipses. I am not sure how this would be effecte by
: > > leap years.
: > > and still another feature would be to monitor the lenght of the days
: > > and nights. the spring and autum equnoxes have equal days and
: > > nights. the Sumer and winter solstace have the longest day and
: > > longest night respectivly. even if weather was bad, you could
: > > program to monitor the days to pin point those 4 days, even by
: > > monitoring the days preceeding and following and comparing day
: > > lenghts.
: > > Dave
: > > wondering if there are any hibernating animals that have a predicable
: > > calendar routine ?
: > > --- In basicstamps@yahoogroups.com, Peter Deutsch <pdeutsch@e...>
: > > wrote:
: > > > Tracy Allen wrote:
: > > > > Hi Greg,
: > > > > Maybe you could use a photocell pointed at the sky. Get the right
: > > > > day-night sensitivity, count to 364 (or 365). You could use a
: > > BASIC
: > > > > Stamp 1 or 2 to do the counting. Give it something else to do
: > > that
: > > > > the same time, say, to remind you when to pay taxes and when to
: > > put
: > > > > out the trash. You could do it with a simple counter, but
: > > decoding
: > > > > the number 365 would take a handful of additional chips.
: > > > Ahhh, but you'd have to put in additional circuitry to account for
: > > > predicted eclipses in your region, and maybe extra circuitry to
: > > provide
: > > > an "unexpected eclipse" button, as well. After all, if some
: > > absolutely
: > > > humongous but so far unplotted celestial body gets between us and
: > > the
: > > > sun, this circuit will fail. If you really wanted to do this right,
: > > > you'd throw in a GPS and try to shoehorn in a celestial navigation
: > > > program. Based upon your measured location, you could account for
: > > known
: > > > eclipses at your location and prompt the user (maybe via email,
: > > maybe
: > > > via a companion onboard web site?) when you experience one of those
: > > > unexplained celestial phenomena...
: > > > Seriously, if you wanted this project to actually have value,
: > > shouldn't
: > > > it provide a count of how many hours the fan has run? Even hetter,
: > > how
: > > > many cubic feet of air have passed through the filter? Throw in some
: > > > sensing to determine actual particulate pollution and you should
: > > > *really* be able to judge filter state...
: > > > - peterd
: > > > > -- Tracy
: > > > > >Greetings Stampers
: > > > > >I've been lurking a long time and learning a lot.
: > > > > >I'm ready to build a project for my furnace to remind me to
: > > change
: > > > > >the 1-year filter on my humidifier.
: > > > > >I'd like to have a simple circuit that I could reset with a
: > > > > >pushbutton that simply sounds a buzzer/flashes an LED after 1
: > > year.
: > > > > >I've been scouring Google, but I can't find anything to steer me
: > > in
: > > > > >the right direction.
: > > > > >Any ideas ??
: > > > > >Thanks a lot
: > > > > >Greg
: > > > > To UNSUBSCRIBE, just send mail to:
: > > > > basicstamps-unsubscribe@yahoogroups.com
: > > > > from the same email address that you subscribed. Text in the
: > > Subject and Body of the message will be ignored.
: > > > > Your use of Yahoo! Groups is subject to
: > > http://docs.yahoo.com/info/terms/
: > > > Peter Deutsch pdeutsch@g...
: > > > Gydig Software
: > > > "Time will end all of my troubles, but I don't
: > > > always approve of time's methods..."
: > > To UNSUBSCRIBE, just send mail to:
: > > basicstamps-unsubscribe@yahoogroups.com
: > > from the same email address that you subscribed. Text in the Subject
: and
: > Body of the message will be ignored.
: > > Your use of Yahoo! Groups is subject to
: http://docs.yahoo.com/info/terms/
: > To UNSUBSCRIBE, just send mail to:
: > basicstamps-unsubscribe@yahoogroups.com
: > from the same email address that you subscribed. Text in the Subject and
: Body of the message will be ignored.
: > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
: To UNSUBSCRIBE, just send mail to:
: basicstamps-unsubscribe@yahoogroups.com
: from the same email address that you subscribed. Text in the Subject and Body
of the
: Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
