Generate Squarewave Using BS2
Archiver
Hi Frenzs,
I'm currently having problem generating a square wave with a 50% duty
cycle using the "PULSOUT" command.
With reference to BS Mannual Ver 2.0, page 244, it states that
there's pulse glitches. Is there any way to avoid this problem. Any
otheer commands to 50% duty cycle?
In deep ****
pctsp
In deep ****
pctsp
oscilator circuit seems to possible. I haven't gotten to that part
as yet, so I haven't thought it all the way thru.
In my case, I'm also looking to adjust the duty cycle as well as the
frequency.
I am very interested in this thread.
I wonder if Don's desulfator circuit would benefit from an adjustable
pulse rate and duty cycle ?
Dave
--- In basicstamps@yahoogroups.com, "pctsp <pctsp@y...>" <pctsp@y...>
wrote:
> Hi Frenzs,
duty
> In deep ****
> pctsp
desired frequency. The first pulse sets the FF and the next clears
it. Perfectly 50-50.
Paul
--- In basicstamps@yahoogroups.com, "Dave Mucha <davemucha@j...>"
<davemucha@j...> wrote:
> I'm looking at a similar problem. The idea of feeding an external
the
> frequency.
adjustable
> Dave
<pctsp@y...>
> wrote:
> > Hi Frenzs,
> duty
Any
> > In deep ****
> > pctsp
> Simply tie the stamp output to a D-type flip flop at twice the
> Paul
> the
> >frequency.
> adjustable
> >Dave
> <pctsp@y...>
> >wrote:
> >>Hi Frenzs,
> >duty
> Any
> >>In deep ****
> >>pctsp
Thanks for the informative suggestion. I'm currently using the D-
Flip-Flop to fulfil my objective. However there's another problem.
My Flip-flop does not produce the output correctly. I'm using a clock
frequency of 20Khz. Is it because of this frequency, that i'm facing
this problem.
All connection of the D Flip-Flop throughly checked.
D Flip-Flop Used : DM74LS574N
Thanks again,
octsp
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> Agree 100%. I have "squared" many of pulse trains using a D FF.
clears
> > Paul
external
part
> > the
> > >frequency.
> > adjustable
> > >Dave
> > <pctsp@y...>
> > >wrote:
> > >>Hi Frenzs,
50%
> > >duty
> > Any
> > >>In deep ****
> > >>pctsp
apply the square wave that you have to the Clock input of the flip flop to
make it divide by 2. If you have the flip flop connected in this manner it
should work fine up into Mhz range.
You should probably disabe the Clear and Set inputs also ijust to make sure
noise isn't triggering these.
And a big fat OOOPPPPS!!!!!!!!!!! A "D" FF is not the correct device.
Use a "JK" FF, a 74LS76 and tie the J and K inputs high through 10k ohms.
There is also a device called a TOGGLE FF, I can't find the number right
now..
The toggle FF does not have the J & K inputs, just a clock in and output.
Email me personally with a tel number if you need clarification
Sorry for the mix up....A "D" FF will definately NOT work!!!!!!!!!! SORRY
I guarantee the 74LS76 will do what you want, 20khz input and 10kHz output!!
azeasi@a... writes:
> You have to connect the Q bar output to the D input of the flip flop and
Really? I never have done it that way. Sounds good though. There are also
Toggle FF or you can use a JK, tie JK high, although there is more hook up
using the JK.
For the D flip-flop or the JK flip-flop, be sure you connect your
pulse to the _clock_ input, not the data input.
For the D flip-flop, connect the Q' output back to the D
(data) input. Use the Q output as your square wave source.
For the JK flip-flop, pull the J and K inputs high as smartdim wrote.
Why this works:
Characteristic equation for D flip-flop: Q(t+1) = D
If D = Q'(t), Q(t+1) = Q'(t)
Characteristic equation for JK flip-flop: Q(t+1) = JQ'(t) + K'Q(t)
If J = K = 1, Q(t+1) = 1Q'(t) + 0Q(t) = Q'(t)
Steve
have built many circuits using a D Flip Flop wired as I stated in the last
posting. It is a very common way to produce a divide by 2 circuit which will
give you exactly a 50% duty cycle at 1/2 the input frequency.
azeasi@a... writes:
> I have to disagree with your statement that a D flip flop will not work. I
> will
My bad!!!
I later learned that you put the Qbar output to the D input and get the
divide by two function..I did not know that previously, now I do!!!!!!!!!!!!
Didn't want to come off sounding like an idiot, but too late for that!
None the less, I learned something today,,,,,
Previously I had used either a Toggle FF or a JK FF and tie J&K high. Next
time I need a 50% duty cycle I will certainly use a D FF.
