simple pinout question — Parallax Forums
edited 2002-12-10 23:23 in General Discussion
If I have "HIGH 8" in my code, I know that it sets pin 8 to high, but on the
hardware side of things, is pin 8 equal to "P8" or is the "8th pin down from
the top left," which would correspond to "P3."
-- Kyle S.
Sent: Tuesday, December 10, 2002 12:11 PM
Subject: [noparse][[/noparse]basicstamps] OT - Max232
> Of topic but still relevant.
> I've seen a circuit using the Max232 and brings all four lines (TX, rx,
cts,
> & ???) from a standard 9 pin d-sub to a 5 or 6 pint post connector for
easy
> bread boarding. No the problem, I cannot find it. Anybody know a site
> where that is located.
> [noparse][[/noparse]Non-text portions of this message have been removed]
    edited 2002-12-10 18:22
    In a message dated 12/10/2002 12:58:54 Eastern Standard Time,
    KamaolaKid@g... writes:
    8 is pin 8.
    Sid Weaver
    W4EKQ
    Port Richey, FL
    edited 2002-12-10 18:23
    Sorry - should have said pin 8 = P8.
    edited 2002-12-10 18:33
    Thanks.
    -- Kyle S.
    Sent: Tuesday, December 10, 2002 1:23 PM
    Subject: Re: [noparse][[/noparse]basicstamps] simple pinout question
    the
    from
    If you say HIGH8 in your code, physical pin 13 on the BS2, labeled P8 will
    go high. Page 10 of the current Stamp manual has a good diagram showing this
    relationship. When working on a project I make an enlarged copy of this
    diagram and make notes as to which pin I am using for what.
    the
    from
