dual PWM on a BS2p24
Archiver
I can get a PWM to work for one motor through a SN754410 H-Bridge
(wired for dual full H-Bridge). it seems to work but I need to get 2
PWM out of this chip. I've tried very simple code. little more than
just trying to run 2 PWM commands through 2 different pinouts. If
that happens then the signal out is all on for both pins. I feel that
I don't understand the actual function by which this chip creates PWM
signals and that I'm either barking up the wrong chip or I'm just
using it incorrectly. Hopefully I'm coding it wrong otherwise I think
I'll just return the damn thing and use an HC11 despite programming
in assembly. I mean having the direction bits set for 2 motors
through the bridge works fine. How do I send 2 seperate PWM signals
out of the BS2p24? Any help would be greatly appreciated.
for. The site is listed on the Parrallax web site as AWC Electronics.
Also see my mesage #26716.
More on this beastie: Not a true PWM generator like Al's PAK's. One
channel, just a little 8 pin device. It reads a servo pulse from a
radio rx (~1-2 ms) and puts out:
- hi/lo signal to control a direction relay;
- a single pulse, from short to ~20 ms, to control the FET for speed.
Since Rx pulses are ~20 ms apart, this gives approx 0-100% duty cycle
on the FET.
But can be interfaced with a Stamp if customization is desired.
Requires you to read Rx pulse, do some processing, and send out your
own (modified) pulse, all before the next Rx pulse comes along.
In my case, I'll read 2 Rx channels, and control 3 ESC's/motors
independently depending on XY stick position.
PM
2
that
PWM
think
