how to progam a 8 to 1 multiplexer
hey
this is kristof from Belgium and I'm in my senior year electronics
and I have to make a work about The BS1. I want to make a robot with
sensors, remote control and 2 DC-motors the first 2 take 6 pins and
becaus of that I use a 8 to 1 multiplexer.
the only problem is program it.
so if you can help me any help is welcome
thanks
kristof van laecke
thanks
kristof van laecke
--- In basicstamps@yahoogroups.com, "kristofvanlaecke"
<luc.vanlaecke@s...> wrote:
> hey
with
and
> thanks
> kristof van laecke
from the stamp.
The general idea is as follows:
Three binary lines can give you 8 different combinations, and that is what
will allow you to select one of 8 lines.
If you use for example a MC14512, and tie pins Inhibit and Disable low, then
using three control lines you can select one of 8 inputs to show up at the
output, Z.
Inputs A B C....Output Z (X0 through X7)
000...X0
001...X1
010...X2
011...X3
etc
111...X7
Ken
smartdim@a... writes:
> output, Z.
> 000...X0
> 001...X1
> 010...X2
> 011...X3
> etc
> 111...X7
> Ken
Please let me clarify....as the above does not read correctly......
A, B & C are control lines. X0 through X8 are the inputs, Z is the output.
Depending on the binary combination on the control lines ABC, it will give
you one of the inputs X0 ~ X7 on the output, Z.
(I should proof read my posts before hitting send!!!!!!)
Ken
