Pic programing, where to start ?
Hey guys.
I've been thinking about making the switch to pic programing.
I need more reliability and cheaper chips.
The problem, Where to start ?
so many pic types/programmers/books/sites.
Any recommendations ?
Reading list ?
Pointers ?
Shachar Weis
holopoint@r...
Reading list ?
Pointers ?
Shachar Weis
holopoint@r...
programmer and software. It works like a charm.
If you are coming from Stamps, there is a Basic compiler from
MicroEngineering Labs (www.melabs.com) that is
Stamp compatible - there are two, actually - PicBasic for $100 and PicBasic
Pro for $250. Picbasic supports the Stamp I language and features, while
the Pro version supports the BS2 language and features. Both have some
extensions.
For example, the Pro version has commands to support the A/D converters,
USARTs, I2C, etc on the PIC 16F877 series chips.
I have both (just got the Pro version - looking to sell the standard version).
I've been putting together a rather large 16F877 project - it is about 1300
lines of PicBasic code at present, and even uses the floating point package
that MEL provides.
I've not played with any of the "C" compilers yet - I really hate "C" as a
programming language.
Also on Wouter's site, above, you can find his JAL compiler. JAL (Just
Another Language) is a Pascal-like language for the PICs - I've played with
it a bit.
And of course, there is always assembler.
As to chips - check the Microchip site (www.microchip.com) for all the gory
details. The 16F628 is a good basic chip with no A/D or UARTs, etc. But
cheap and very useful
The 16F877 is a 40 pin chip with 8 channels of 10 bit A/D, comparators,
UART, I2C/SPI - if you really want to learn all the things that can be
done, that's the chip (or it's smaller 28 pin relative the 16F876). The
'877 has 8k oc program code memory and about 380 bytes of data memory (RAM)
- you can do a lot with it.
Have fun!
Larry
At 03:02 PM 12/3/2002 +0000, you wrote:
>Hey guys.
>Reading list ?
>Pointers ?
>Thanks,
>Shachar Weis
>holopoint@r...
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Larry Bradley
Orleans (Ottawa), Ontario, CANADA
They do PIC programming.
rat_ring@yahoogroups.com
"holopoint.rm" <holopoint@r...> wrote:Hey guys.
Reading list ?
Pointers ?
Shachar Weis
holopoint@r...
from the same email address that you subscribed. Text in the Subject and Body of
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now
inputs ADC ??
Speed ?
Pin counts etc
Then find a chip that will do that an a little more.
then find what is needed for that chip. typically, everything less
can be done on smaller chips, but if you try to go up in features,
you may find your software/programmer also need to be upgraded.
Dave
--- In basicstamps@y..., "holopoint.rm" <holopoint@r...> wrote:
> Hey guys.
> Reading list ?
> Pointers ?
> Thanks,
> Shachar Weis
> holopoint@r...
