H-Bridge in India ( was Re: 1 ADC to 2 B2SX''s
Hi Lana,
I can offer a suggestion to search for H-Bridge chips (Allegro) and H-
Bridge circuits to see what will fit your needs. Search this list
for a lot of information.
then find out what parts you can get easily, locally.
If you have any ability to make a circuit, an H-bridge is not all
that complicated.
As for encoders, there has been a lot of talk of them on here as
well. Encoders are a little tricky as if you want high resolution
you need a lot of counts per revolution. and if you move fast you
may need an intrupeter chip to handle the speed.
OF course there are a few different styles. one will only let you
know that you are moving, another will also tell you direction. yet
another will tell you exactly where you are.
Hope this helps.
Dave
--- In basicstamps@y..., lana lana <lana18102001@y...> wrote:
> Dear sir
> I live in ISRAEL, ARE THERE A VENDORS IN ISRAEL FOR H-BREDGE DRIVER
BOARD (FOR MOTOR 250 WATT, 24V DC)?, OR 150WATT ,24V,DC.
> I WANT :.
> 3 H- BRIDGE DRIVER BOARD FOR FIVE (5) MOTORS 250WATT ,24V DC.
> i am looking for a vonder,agent,in ISRAEL ,send me his address or E-
mail please,i have a project to do.
> I WILL BE THANKFULL IF YOU SEND ME A SCHEMATIC DESIGN FOR DRIVER
BOARD OF TWO (2) DC MOTORS[noparse][[/noparse] rotate in 2 directions
together,brack,speed control , possipility one motor rotate and
second stop, using encoder to count RPM .] bestregards
> THANKS
> LANA
> Dave Mucha <davemucha@j...> wrote: Hi Jonathan,
> what about sending serial out from your 1st unit to the second
unit.
> it would be able to see the current value all the time and if you
> chose to take your second unit off line, it would not interupt your
> lead unit.
> you could use a jumper to tell the program to look to the TLC or to
> look to the BS2. change the jumper and presto ! second unit would
> take control.
> Dave
> --- In basicstamps@y..., "Jonathan Peakall" wrote:
> > Hi All,
> > I made a hot tub controller on my BOE. I am now setting up a
> permanent
> > controller with a B2SX OEM module. I want to have the permanent
> controller
> > run the tub, and have the BOE running in parallel so that it
> *thinks* that
> > it is running the hot tub. This way I can add new features and
play
> with my
> > solar heating setup in simulation without disrupting the
operation
> of the
> > tub. The problem is I only have one LTC1298 ADC. So, can I run
the
> ADC off
> > the permanent controller, and send the output to the BOE? Of
> course, I can
> > get another ADC, but I want to play with it *now* ;-)
> > Thanks,
> > Jonathan Peakall
> basicstamps-unsubscribe@y...
> from the same email address that you subscribed. Text in the
Subject and Body of the message will be ignored.
> Do you Yahoo!?
> Yahoo! Mail Plus - Powerful. Affordable. Sign up now
> [noparse][[/noparse]Non-text portions of this message have been removed]
that complicated.
Hope this helps.
Dave
> Dear sir
> I WANT :.
> THANKS
> LANA
unit.
> lead unit.
> take control.
> Dave
> > Hi All,
> permanent
> controller
> *thinks* that
play
> with my
operation
> of the
the
> ADC off
> course, I can
> > Thanks,
> > Jonathan Peakall
> Do you Yahoo!?
