1 ADC to 2 B2SX''s
Dave,
> what about sending serial out from your 1st unit to the second unit.
> it would be able to see the current value all the time and if you
> chose to take your second unit off line, it would not interupt your
> lead unit.
That sounds like a good idea. I have the pins to spare, so that is no
problem. I had hoped to have them run independently, but this idea should
work.
> you could use a jumper to tell the program to look to the TLC or to
> look to the BS2. change the jumper and presto ! second unit would
> take control.
Not exactly sure what you mean here. Can you explain in detail?
Thanks for the reply!
Jonathan Peakall
> lead unit.
work.
> take control.
Jonathan Peakall
