Random number / Branch
Hello all, I need some help.
I am quite new to the basic stamp world, I am writting a program to
select and activate two different pin base on a random number. I
have a list of different cases, such as case 1: will make pin 0 and
1 high for a certain amount of time, then make them low again, then
I generate another random number, say 3, case 3: makes pin 0 and 3
high for an amount of time then make them low and so on as you will
see in the attached program below. the main problem I have is that
when the numbers are generated, the selection that is supposed to be
made is not made, meaning the pin I want to be high are not
necessarily the ones that are high and also they stay high. I know
that their might be a better way to do this. any help will be
greatly appreciated. thanks in advance
'{$STAMP BS2} 'STAMP directive (specifies
a BS2)
'SOUT = serial out: 1 connects to pcserialport RX pin for prograing
'SIN = Serial in: 2 connects to pc serial port TX pin for programing
'ATTN Atteention: 3 connects to PC serial Port DTR pin for programing
'VSS: system groung: 4 connects to pc serial port GND for programing
'P0-P15General purpose I/O pins
'VDD = 5 volts DC input/output (21)
'RES = Reset input/ouput: goes low when power supply is less than
approxemately 4.2 volt,
'causing the basic stamp to reset
'VSS = System ground: connects to to power supply's ground (GND)
terminal
'VIN = Unregulated power in: axxepsts 6 - 60 VDC which is internally
regulated for 5 volts.
'INPUT 7 ' Make I/O pin 7 an
input.
'OUT7 = 0 ' Write 0 to output
latch.
Elect1 con 0 ' Make I/O pin 0 an
output.
Elect2 con 1 ' Make I/O pin 1 an
output.
Elect3 con 2 ' Make I/O pin 2 an
output.
Elect4 con 3 ' Make I/O pin 3 an
output.
Elect5 con 4 ' Make I/O pin 4 an
output.
Elect6 con 5 ' Make I/O pin 5 an
output.
Elect7 con 6 ' Make I/O pin 6 an
output.
'POLARITY con 7 ' Make I/O
pin 1 an output.
'OUTPUT 7 ' Make I/O pin 7 an
output.
RNDWORD VAR WORD
RND1 VAR WORD
'RANDOM NumGen
LOOP:
RANDOM rndword
RND1 = rndword/13555 MIN 1 'GEGNERATE A RAND # BETWEEN 1 AND 7,
1 AND 8 WITH 7555
'RND1 = RNDWORD.LOWnIB(0) * %0111
debug? RND1
BRANCH RND1, [noparse][[/noparse]Case1,Case2,Case3,Case4,Case5]
', Loop6, Loop7, Loop8]
PAUSE 10000
'goto loop
Case1:
HIGH 0
'PAUSE 10000
HIGH 1
PAUSE 10000
LOW 0
LOW1
GOTO LOOP
Case2:
HIGH 0
'PAUSE 10000
HIGH 2
PAUSE 10000
LOW 0
LOW 2
GOTO LOOP
Case3:
HIGH 0
'PAUSE 10000
HIGH 3
PAUSE 10000
LOW 0
LOW3
GOTO LOOP
Case4:
HIGH 0
'PAUSE 10000
HIGH 4
PAUSE 10000
low 0
low14
GOTO LOOP
Case5:
HIGH 0
'PAUSE 10000
HIGH 5
PAUSE 10000
low 0
low5
GOTO LOOP
a BS2)
terminal
input.
latch.
output.
output.
output.
output.
output.
output.
output.
pin 1 an output.
output.
RNDWORD VAR WORD
RND1 VAR WORD
'RANDOM NumGen
LOOP:
RANDOM rndword
1 AND 8 WITH 7555
debug? RND1
PAUSE 10000
'goto loop
Case1:
HIGH 0
'PAUSE 10000
HIGH 1
PAUSE 10000
LOW 0
LOW1
GOTO LOOP
Case2:
HIGH 0
'PAUSE 10000
HIGH 2
PAUSE 10000
LOW 0
LOW 2
GOTO LOOP
Case3:
HIGH 0
'PAUSE 10000
HIGH 3
PAUSE 10000
LOW 0
LOW3
GOTO LOOP
Case4:
HIGH 0
'PAUSE 10000
HIGH 4
PAUSE 10000
low 0
low14
GOTO LOOP
Case5:
HIGH 0
'PAUSE 10000
HIGH 5
PAUSE 10000
low 0
low5
GOTO LOOP
Sine debugs are the only way to watch program flow and state in a
stamp I expect to see a lot of them, you need to know how things are
working. Comment them out once things work, but they should be there!
Second I see a lot of duplicate code. dupe code is BAD. Your caseX
statements are the culprits...
You wrote a bunch of these
> Case1:
> HIGH 0
> 'PAUSE 10000
> HIGH 1
> PAUSE 10000
> LOW 0
> LOW1
> GOTO LOOP
I'd write
Case1:
DEBUG "Case1": CR
High 0
High 1
GOTO LOOP
Then put this at the top of Loop...
LOOP:
DEBUG "LOOP", CR
PAUSE 10000
FOR out = 0 to 5
Low out
NEXT
Then you need to make sure rand1 is doing what you think it is doing,
it's probably not...
be
(specifies
> a BS2)
programing
> terminal
internally
> input.
> latch.
pin 0 an
> output.
pin 1 an
> output.
pin 2 an
> output.
pin 3 an
> output.
pin 4 an
> output.
pin 5 an
> output.
pin 6 an
> output.
> 'POLARITY con 7 '
Make I/O
> pin 1 an output.
> output.
> RNDWORD VAR WORD
> RND1 VAR WORD
> 'RANDOM NumGen
> LOOP:
> RANDOM rndword
7,
> 1 AND 8 WITH 7555
> debug? RND1
> PAUSE 10000
> 'goto loop
> Case1:
> HIGH 0
> 'PAUSE 10000
> HIGH 1
> PAUSE 10000
> LOW 0
> LOW1
> GOTO LOOP
> Case2:
> HIGH 0
> 'PAUSE 10000
> HIGH 2
> PAUSE 10000
> LOW 0
> LOW 2
> GOTO LOOP
> Case3:
> HIGH 0
> 'PAUSE 10000
> HIGH 3
> PAUSE 10000
> LOW 0
> LOW3
> GOTO LOOP
> Case4:
> HIGH 0
> 'PAUSE 10000
> HIGH 4
> PAUSE 10000
> low 0
> low14
> GOTO LOOP
> Case5:
> HIGH 0
> 'PAUSE 10000
> HIGH 5
> PAUSE 10000
> low 0
> low5
> GOTO LOOP
