ir remote
Archiver
I plan to control many lights in my car using a BS2sx. I would like
to use my sony PDA as the remote for the system. Does anyone know of
a schematic that I could use to have the stamp recieve the data from
my PDA.
Thanks in advance!
Chris Brown
my PDA.
Thanks in advance!
Chris Brown
It is designed to decode popular RC-5 [noparse][[/noparse]a Philips protocol] remote signals.
The kit comes with code and schematics. One of the examples is an RC-5 key
code explorer which will let you get your PDA setup adjusted and tell you the
values of each key code [noparse][[/noparse]RC-5 uses two bytes: one for "system" the other for
"key"].
The connections are easy: One pin from the BASIC Stamp to the device [noparse][[/noparse]it also
needs +5v and ground] is all it takes. You'll use SEROUT to send commands to
the device and SERIN to get information back. It also has a buffer so that
it can receive IR codes while the Stamp is busy doing other things.
Note that IR interference can be problem in outside environments. Our device
is "smart" [noparse][[/noparse]has an onboard micro] and won't decode incorrectly, it may just
reject all signals if there is too much ambient IR. This should be
considered in your application -- you may need to shield the IR receiver from
possible sources of interference for proper performance.
-- Jon Williams
In a message dated 11/30/02 10:20:25 AM Central Standard Time,
rball80@h... writes:
> to use my Sony PDA as the remote for the system. Does anyone know of
> my PDA.
> Thanks in advance!
> Chris Brown
