Low cost water valve? Where to buy... — Parallax Forums
edited 2002-11-27 13:20 in General Discussion
I want to build a 'dancing fountian' where the stamp turns water jets
on and off in time to music or just in interesting sequences.
The code and electronics are simple but the water valves get spendy.
Has anyone found cheap solenid valves?
I've thought about inground sprinkler valves but they are kinda slow
TIA
    edited 2002-11-26 03:11
    Depends on the flow of water you want, the available pressure to
    shoot the water. In your case you may be able to live with cheap
    homemade leaky valves,,,valves are expensive due to thier
    reliablility and sealing capacity,,but you don't quite need all that.
    For example,,,Toilet float/lever valves seal against city pressure,
    about 30psi,,,you could take a cheap soleniod by itself and
    mechanically hook it up to the lever of the toiled valve,,,using the
    a cheap solenoid that does not have much force action in conjunction
    with a lever arm ,,may produce the action you want for a cheap
    price,,,but the valve assembly may be leaky,,but that should not
    bother you if all this is in a pool....
    Ray
    jets
    > TIA
    edited 2002-11-26 04:22
    How cheap? I've found $80 valves ; I helped a frieind use the BS2 and a
    couple of solenoid valves to control a hydrolysis chamber which collected
    H / O in separate chambers, then ignited them. If you find extremely
    cheap valves, I'd be pretty interested, since I've had interest for a
    while in microprocessor-controlled LP burns.
    > TIA
    Sean T. Lamont, Chief Mad Scientist |-- lamont@a...
    Zen Chemical Productions |-- http://www.zenchemical.com
    Fabricators of Unnecessary Amazement
    edited 2002-11-26 06:02
    ASCO makes a good line of solenoid valves, the 8210G2 is 1/2" NPT Normally
    Closed
    Sent: Monday, November 25, 2002 9:22 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Low cost water valve? Where to buy...
    > > TIA
    edited 2002-11-26 14:34
    I've used central heating hot water valves for this job. They are cheap and
    easily obtainable from plumbing suppliers. They last for years.
    However you need to power mains to the unit - so that usually involves a
    seperate main relay.
    Whatever you use, don't forget you need semething (like a power FET) to
    switch the solenoid and a relay to protect the semiconductor from the back
    emf when you switch.
    There are lots of postings here regarding switching relays and solenoids
    Tony Wells
    Sent: Tuesday, November 26, 2002 2:58 AM
    Subject: [noparse][[/noparse]basicstamps] Low cost water valve? Where to buy...
    > TIA
    edited 2002-11-26 14:44
    Oh, I also forgot, you can also recover a used water cut-off solenoid from
    scrap automatic washing machines.
    Someone on the list might have an old washing machine in their back yard
    they can send you...
    Be carefull with electricity and water - they don't mix well!
    Tony
    Sent: Tuesday, November 26, 2002 2:34 PM
    and
    > Regards,
    > Tony Wells
    > From: "kvasilak" <my427v8@h...>
    > > TIA
    and
    edited 2002-11-26 15:43
    Electronics goldmine has a liquid shutoff valve for a buck.
    http://sales.goldmine-elec.com/prodinfo.asp?prodid=3051
    Jason
    Normally
    > Closed
    > From: "Sean T. Lamont .lost." <lamont@a...>
    > To: <basicstamps@y...>
    and a
    collected
    extremely
    for a
    water jets
    spendy.
    slow
    > > > TIA
    > > > basicstamps-unsubscribe@y...
    Subject
    Subject and
    edited 2002-11-26 16:17
    McMaster Carr has some 1/4"-3/8" valves for $38 and some 1/8" valves for $17.
    Both are pretty good and are available in DC or AC versions.
    http://www.mcmaster.com/ Goto page process control then solenoid valves then
    page 375. Grainger also has some for $60 or so.
    Sent: Monday, November 25, 2002 8:22 PM
    > TIA
    edited 2002-11-26 17:13
    Try you local Appliance part store for a dish washer's valve.
    tony.wells@a... wrote:Oh, I also forgot, you can also recover a used
    Tony
    To:
    and
    > Regards,
    > Tony Wells
    > From: "kvasilak"
    > To:
    > > TIA
    and
    from the same email address that you subscribed. Text in the Subject and Body of
    Do you Yahoo!?
    Yahoo! Mail Plus - Powerful. Affordable. Sign up now
    edited 2002-11-26 17:42
    You guys have some great ideas!
    Electronic gold mine is new to me and the washer valve idea is gotta
    be cheap...
    yard
    > Regards,
    > Tony
    > From:
    > To:
    cheap
    > and
    involves a
    FET) to
    the back
    solenoids
    > > Regards,
    > > Tony Wells
    > > From: "kvasilak"
    > > To:
    water jets
    spendy.
    slow
    > > > TIA
    Subject
    > and
    Subject and Body of the message will be ignored.
    > Do you Yahoo!?
    edited 2002-11-26 19:47
    Why do you need the FET? I switched a 12V solenoid using a small reed
    relay and a stamp on the +5 control voltage. Have I done a bad thing?
    > Regards,
    > Tony Wells
    > > TIA
    Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
    Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
    email: lamont@a... WWW: http://www.serv.net
    "Do not fear mistakes, There Are None" - Miles Davis
    edited 2002-11-26 21:22
    Sean Asked:
    Well Sean,
    The max current sink on a pin is 25mA and source is 20mA. Also generally
    (except for the DS-IC)the max sink on ALL pins is 50mA and sink of 40mA.
    (The above is an abstract from the Stamp FAQ) at:
    http://www.parallax.com/Downloads/Documentation/BASIC%20Stamp%20Frequently%2
    0Asked%20Questions.pdf
    So if you pick your relay * very carefully* it may well not exceed the
    20/25mA limit on a pin. However you may well exceed the overall limit if you
    are driving other things such as LEDs. For switching mains current, think in
    terms of switching 100mA or more.
    I got lazy once and tried switching directly a small 5v reed relay, and it
    was just on the limit both for the pin and on overall pin consumption. After
    about a month of use, the relay stopped operating - the IO pin died. I
    rewired the relay to a spare port, and guess what, the whole stamp died
    after a week.
    Also, did you remember your back-EMF diode?? Otherwise, expect your pin to
    die sooner or later.
    Lastly, you don't *need* a FET, any suitable transistor will do - they are
    just cheap and handy and extremely robust, and I love them.
    Lastly, Lastly, Lastly. For those using processors capable of switching at
    speeds in the MHz region - possibly the Javelin is fast enough - and
    certainly the Rabbit RCM2000/3000 series - there is a little known issue
    when switching at high speeds. At MHz speeds the gate capacitance of a FET
    attached to an IO port puts a significant load on the port. The use of FETs
    with high gate capacitance can cause significant loading on the IO pins.
    Tony
    Sent: Tuesday, November 26, 2002 7:47 PM
    and
    back
    > > Regards,
    > > Tony Wells
    > > > TIA
    and
    edited 2002-11-26 21:25
    Folks, apologies - there is a serious flaw in my previous email.
    I said:
    "and a relay to protect the semiconductor from the back emf when you
    switch"
    I meant to say:
    "and a *DIODE* to protect the semiconductor from the back emf when you
    switch"
    Sorry.
    Tony
    Sent: Tuesday, November 26, 2002 2:44 PM
    > Regards,
    > Tony
    > From: <tony.wells@a...>
    > and
    back
    > > Regards,
    > > Tony Wells
    > > > TIA
    > and
    edited 2002-11-27 00:28
    I am surprised that the first question was not "what Cv ?" the flow
    coefficent determins valve size.
    There are a bunch of valve makers, some use white metal bodies, some
    aluminum, plasitc, brass and stainless.
    Once yo uget into the larger valve sizes, they use a pressure assist
    from the pressure supply. That is to say that the solenoid only
    opens a tiny port and that lets the water pressure in and onto a
    large diaphram. That diaphram then opens the main valve. This is
    MUCH cheaper to manufacture than a valve that is totally controled by
    the solenoid.
    These are typically shown with the solenoid being off center of the
    valve a good bit. and as you mentioned, the process is slow enough
    to be noticable.
    Red Lion, Assco, Parker, and similar will offer multiple body
    materials.
    if you are looking for a commercial project, I highly recomned you
    buy new just for the replacemnt availabliity.
    but, for a back yard unit, washing machines offer great valves, and
    cheap, and with standard garden hose connections. and if you live in
    an upscale area, check out the town dump. used washers will abound,
    both clothes and dish. Clothes have 2 valves dish and automatic ice
    makers on refrigerators have one.
    Dave
    jets
    > TIA
    edited 2002-11-27 03:17
    Well the first one here will use whatever I can get cheap, other ones
    will have more design work. I just want something to play with at
    this point.
    flow
    some
    assist
    by
    > the solenoid.
    > to be noticable.
    > materials.
    in
    abound,
    ice
    > Dave
    > jets
    spendy.
    slow
    > > TIA
    edited 2002-11-27 03:39
    It makes sense to play with stuff on the cheap. That is what most of
    us do.
    home depot offer water valves for about $10 each, large volume, but
    as you say, noticable delay. you could add a delay in the music so
    that the signal went 1/4 second before the beat. Believe it or not,
    professional lighting for concerts have a longer dalay so they
    actually switch before the beat to get the light timed to the music.
    Dave
    ones
    > this point.
    > flow
    > some
    > assist
    is
    controled
    > by
    > > the solenoid.
    the
    enough
    > > to be noticable.
    > > materials.
    you
    and
    > in
    > abound,
    > ice
    > > Dave
    water
    > > jets
    > spendy.
    > slow
    > > > TIA
    edited 2002-11-27 05:02
    Enough with the water valve!!! this is a stamp forum!
    Also try www.allelectronics.com they sell a minitature water pump CAT# PMP-2 for
    US $3.75. Runs off 12VDC. Its a Automobile Windshield water pump.
    kvasilak <my427v8@h...> wrote:You guys have some great ideas!
    be cheap...
    yard
    > Regards,
    > Tony
    > From:
    > To:
    cheap
    > and
    involves a
    FET) to
    the back
    solenoids
    > > Regards,
    > > Tony Wells
    > > From: "kvasilak"
    > > To:
    water jets
    spendy.
    slow
    > > > TIA
    Subject
    > and
    > Do you Yahoo!?
    Do you Yahoo!?
