timer or clock function on BS2? — Parallax Forums
edited 2002-11-25 21:53 in General Discussion
I'd like to be able to periodically send data to my computer from a
BS2. In Pseudo-code, here's what I mean
kInterval con 1000 'interval between data transmission
top:
do some processing
if (interval > kInterval) then transmit data
goto top:
How do I do this? I can't seem to find a non-blocking way to make
something happen on an interval basis. SLEEP, NAP, PAUSE all cause
processing to stop. The fact that SLEEP et. al. exist implies that the
BS2 has an onboard timer, so it seems that a solution that doesn't
require external bits should be possible.
What am I overlooking?
cheers,
_murat
    edited 2002-11-25 12:31
    Well, you need to create a counter, and then increment the encounter
    every pass through the program loop, etc. When the counter is greater
    than some pre-set variable, then you transmit your data.
    This approach would be 100% accurate, as each pass through the program
    loop may take a differing amount of time, depending on what is being
    done, but you should be able to achieve granularity of a few seconds at
    worst.
    If you program is fairly small, then you make have to implement a
    time-waster, like a useless for-next loop.
    If you're not worried about processing other data while waiting to
    transmit you can do somethine like a SERIN on an usused pin, with a
    timeout of "x" seconds (whatever is appropriate for you). Since the pin
    is usused, the SERIN command will always fail after "x" seconds,
    resulting in a fairly decent "SLEEP" of many seconds.
    > top:
    > do some processing
    > goto top:
    Brian <stamp@k...>
    Our Co-Processor has a timer feature that will time in 20 ms
    increments so you won't have to stop the Stamp or waste time in delay
    loops.
    That is how we can do multi-tasking with a Stamp.
    Details are on the website. www.bluebelldesign.com
    If you only have one time to count, you can use an external timer
    chip (like a 555) and periodically check if it is done.
    Harry
    Stamp Robotics to the next level
    > top:
    > do some processing
    > goto top:
    the
    > cheers,
    > _murat
