irods
Archiver
I am not sure how to wire in a irod for object detection. I am using
BS2p and have my motor running of an Hbridge.
pin o is forward, pin 1 is backward and pin 3 is ground.
the motor is not supposed to start until an object is detected, then
follow thru the code and return to its starting point where it will
wait to begin when an object is detected.
the code I have thus far is:
'{$STAMP BS2p}
x var byte
output 2
high 2
top:
for x = 1 to 75 'length of roatation
pwm 1, x, 40 'clockwise rotation
next
pause 3000
next
pause 5000
for x = 1 to 80
pwm 0, x, 40 'ccw roatation
next
pause 2000
for x = 1 to 70
pwm 0, 200, 40
goto top:
I am using the sharp gp2d05 black wire into vss and red wire in vdd.
green wire? blue wire ?
any idea's how to finsih this wiring?????
john
'{$STAMP BS2p}
x var byte
output 2
high 2
top:
next
pause 3000
next
pause 5000
for x = 1 to 80
next
pause 2000
for x = 1 to 70
pwm 0, 200, 40
goto top:
john
<snip>
Not sure how you came by this as IRODS was discontinued quite a
while ago as SHARP stopped making the GP2D05....
The GP2D05 has a single bit output. You set a 'trigger' distance
using a tiny pot on the rear of the unit and when something comes
within range, it sets the bit LOW. You need to start the
measurement process with a pulse on the green wire. The output
comes on the blue wire.
Here is the example code we provided in the kit:
‘Measurement and Calibration Routine for IRODS using a BS2
‘P0 is connected to the voltage divider, which in turn goes to Vin
(green wire)
‘P1 is connected to Vout (blue wire)
START: High 0 ‘Make sure that Vin sees a high-low transition
Pause 3 ‘Wait for it to be seen
Low 0 ‘Begin measurement sequence
Pause 56 ‘Wait for measurement sequence to complete
If IN1=0 Then SHOW ‘If object detected, tell me
Goto START ‘No object detected, start over
SHOW: Debug “Object Detected”, cr ‘Display “Object Detected” in
debug window
Pause 5000 ‘Wait 5 seconds (remove when done calibrating)
Goto START ‘Start over
END
If you contact me off-list I can send you a PDF of the instructions
that came with IRODS.
BTW, Keep an eye on the HVW Tech. website
(http://www.HVWTech.com) for news on our new digital output
version that will connect directly to a Stamp and provide range
information in a number of formats.
Mark Hillier, VE6HVW
President, HVW Technologies Inc.
Canadian Distributors of Parallax Products and other Neat Stuff
Tel: (403)-730-8603 Fax: (403)-730-8903
See our NEW FPGA Experimenter Board
http://www.hvwtech.com/intro-fpga.htm
