vechile speed measure
Hi to all,
does anybody have idea how to measure a vechile speed without outside
sensors.
Because I need to use it on several types of car and I would like to jump
over any outside instalations. I'm already have a unit with proximity sensor
and magnet wrap installed on shaft.
I need to make a continuosly speed logger with alarm when driver drive over
speed limit which is set on unit. After 10 seconds it will write a data on
chip card.
Thanks in advanced.
Damir
sensors.
chip card.
Thanks in advanced.
Damir
Try using a GPS receiver that will acquire at least 4 sats and obtain a
velocity fix. Use one of the experiment codes that have been posted for
data loggers and just use the velocity section of the GPRMC code line from
NEMA. just a thought for a brief discussion of NEMA look here:
http://vancouver-webpages.com/peter/garmin65.nmea
mike m
Sent: Monday, November 18, 2002 6:10 PM
Subject: [noparse][[/noparse]basicstamps] vechile speed measure
> Hi to all,
> sensors.
sensor
over
> chip card.
> Thanks in advanced.
> Damir
In that case I need to made antenna pedestal because it must be used in
several different types of cars and trucks.
I already have GPS Garmin 76 with NMEA 0183 sentences.
Sent: 19. studeni 2002 01:13
Subject: Re: [noparse][[/noparse]basicstamps] vechile speed measure
> Damir,
> mike m
> From: Damir Petrinic <damir.petrinic@r...>
> > Hi to all,
> > sensors.
jump
> sensor
> over
on
> > chip card.
> > Thanks in advanced.
> > Damir
and
vehicle chassis makes a good ground plane which can be significant for good
GPS reception
mike m
Sent: Monday, November 18, 2002 8:00 PM
> I didn't mention in a last mail that I would not like to use a GPS.
> From: "M. E. M. Electronics" <memelectronics@e...>
> > Damir,
a
for
from
> > mike m
> > > Hi to all,
> > > sensors.
> jump
> > sensor
> > over
data
> on
> > > chip card.
> > > Thanks in advanced.
> > > Damir
> and
and
