shiftout question
I need to shift out eleven bits
3 address bits, then 8 data bits
Is there a way to do this using shiftout and a two digit hex number?
so in effect I need to send
a2,a1,a0,d7,d6,d5,d4,d3,d2,d1,d0
it wants to see a2 as the first bit, and I don't quite understand how to
do this
say I shiftout hex 3
msb first
this will send
0000 0011 starting left to right - most sig thru least correst
and if I were to use lstfirst
it would send
1100 0000 correct?
so is there an easy way to do this?
I need to send msbfirst, except skip of the most sig 5 bits
thanks
do this
msb first
this will send
it would send
1100 0000 correct?
thanks
SHIFTOUT p_data, p_clock, MSBFIRST, [noparse][[/noparse]a << 5 \3, d]
or,
SHIFTOUT p_data, p_clock, MSBFIRST, [noparse][[/noparse]a << 5 + d \11]
Steve
> Try this:
> or,
Correction to last line:
SHIFTOUT p_data, p_clock, MSBFIRST, [noparse][[/noparse]a << 8 + d << 5 \11]
Sorry for the confusion.
Steve
