I need help with time clock please?
Hi Group,
I would like to develop an application that carries out a function
depending on the time of day.
Can anybody give me some guidance on how to do this?
I am guessing that an external clock device is required, but beyond
that I'm lost.
FANX in advance.
Dwain.
that I'm lost.
FANX in advance.
Dwain.
real-time-clock modules. You can take it from there.
-- Jon Williams
-- Parallax
In a message dated 11/14/02 7:34:13 AM Central Standard Time,
asdfghjk@b... writes:
> Hi Group,
> that I'm lost.
> FANX in advance.
> Regards,
> Dwain.
than typing it in from acrobat reader?
Sent: Friday, November 15, 2002 12:36 AM
Subject: Re: [noparse][[/noparse]basicstamps] I need help with time clock please?
> On the Parallax web site you'll find code to access the DS1302 and PCF8583
> -- Jon Williams
> -- Parallax
> > Hi Group,
> > that I'm lost.
> > FANX in advance.
> > Regards,
> > Dwain.
You should be able to select the "text" option from the tool bar,
then use your mouse to select the text, and copy it into the clipboard. Then
you can paste it into the text editor of your choice.
From: Dwain J. Hill [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=84J_eBKcR6JCt64c54JREitOey0L9XbaNgJR52m8N60LOxcKyGRIMI_t8XbEaNw6HfUdTfjpH57SpT9_cg]asdfghjk@b...[/url
Sent: Thursday, November 14, 2002 7:14 PM
Is there anywhere that I can download the application source code rather
> -- Jon Williams
> -- Parallax
> > Hi Group,
> > that I'm lost.
> > FANX in advance.
> > Regards,
> > Dwain.
the text you want and copy it in any document you want. it is the
icon next to the zoom icon.
cheers
Serdar "Toughbeard" Aytemiz
rather
thing doesn't work [noparse]:([/noparse]
I tried the short code for the clock and it doesn't work due errors, and the
long code doesn't appear to work either.
Is the code known good code, has anybody else tried the clock application
software?
Dwain
Sent: Friday, November 15, 2002 6:49 PM
Subject: [noparse][[/noparse]basicstamps] Re: I need help with time clock please?
> Actually you can use the text select tool on Acrobat reader to select
> cheers
> rather
I dunno if the sample code on my site will help you, but I know it worked for
me... (all this assuming you're using the PCF8583...)
http://www.lennard.net.nz/ click on I2C then the RTC example...
Ypiu - oh golly my typing in bad at the mo - you should be able to work it out
from that code and the data sheet for the PCF8583...
> OK, I have assembled the gear, and cut and pasted the program, and the
damn
> software?
> Regards,
> Dwain
> From: "serdar_toughbeard" <serdar_a@k...>
> To: <basicstamps@y...>
> > cheers
> > rather
> > basicstamps-unsubscribe@y...
HOO!!!!
Sent: Friday, November 15, 2002 10:20 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: I need help with time clock please?
damn
the
> software?
> Regards,
> Dwain
> > cheers
> > rather
and
