Waiting, in a loop?
How do you guys implement a timeout loop?
I have something that has to happen in 1/2 second, but while I'm
waitin for the time to elapse I need to monitor some inputs.
This means I can't simply use Nap or sleep.
Is there a way to read the internal timebase directly?
Pause et al obviously can do it...
Please don't tell me that timed instruction loops is the only way...
And no external hardware!
FOR idx = 1 TO 100
' check and respond to inputs
PAUSE 5
NEXT
This loop will create about a half second delay unless you bust out early
based on an input.
-- Jon Williams
-- Parallax
In a message dated 11/13/02 4:52:47 PM Central Standard Time,
my427v8@h... writes:
just one path through the loop (and even then). For long periods of time
you can do something like this:
Tdelay con 750 ' found emperically
Loop:
Gosub task1
Gosub task2
Gosub task3
loopdelay=loopdelay+1
if loopdelay<Tdelay then Loop
loopdelay=0
' Do your "every so often task"
goto Loop
task1:
loopdelay=loopdelay+5
' do some stuff here
if <some thing> then task1out
loopdelay=loopdelay+3
' do some more stuff
task1out:
return
etc.
I know you said no external hardware, but a big RC circuit is useful
here. Say you have a 100K resistor from 5V to pin 0 and a 100uF cap from
pin 0 to ground. You could say:
' discharge capacitor
Gosub Cycle
Loop:
if in0=1 then itstime
' do my "normal" tasks
goto Loop
'here is my every so often task
itstime:
Debug "Tick",13
gosub Cycle
goto Loop
Cycle: ' discharge cap and return to input
LOW 0
PAUSE 1
INPUT 0
RETURN
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: kvasilak [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wxOhVt98L-bdqs05hdSEJVPRNJMN4vZlon-wCWWCBSLprTmcKwwKz2NY-19AJ8p0xq705cmYDlHjAq4]my427v8@h...[/url
> Sent: Wednesday, November 13, 2002 4:51 PM
> Subject: [noparse][[/noparse]JUNK] [noparse][[/noparse]basicstamps] Waiting, in a loop?
> way... And no external hardware!
> from the same email address that you subscribed. Text in the
actually pretty cool. It could easily be calibrated and is
independant of the program.
Thanks guys, this stamp thing is a real exersize in minimalism!
( where's my C++ LOL )
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> Well, it is hard to estimate the time through a loop unless there is
time
> Loop:
> Gosub task1
> Gosub task2
> Gosub task3
> loopdelay=0
> goto Loop
> task1:
> task1out:
> return
> etc.
from
> Gosub Cycle
> Loop:
> goto Loop
> itstime:
> Debug "Tick",13
> gosub Cycle
> goto Loop
> LOW 0
> PAUSE 1
> INPUT 0
> RETURN
> Al Williams
> AWC
> > From: kvasilak [noparse][[/noparse]mailto:my427v8@h...]
> > To: basicstamps@y...
> > basicstamps-unsubscribe@y...
