Numbers with Decimal Points
Hi All...thanks to all for answering my questions. I have another
question:
My BASIC manual says it cannot handle decimal point entries. I am
writing an application which would need a number with a decimal point
entered from the keyboard and then compared later to an actual
measured value. Anyone have any ideas on how to program this ?
Thanks for all you help...JB
question:
>question:
Lets say you need 2 decimal places. Then in your program, work with
100* all th e values.
number you could easily write code to read the integer part, store it,
and then store the fractional part. So 5.25 might be x0=5 and x1=250,
for example.
However, doing any sort of math like that is likely to be frustrating.
You can sometimes "scale" things to work out. So, for example,
converting F to C is:
F=1.8*C+32
You could write this as:
F = (18*C)/10+32
Further, supposed you wanted the answer to 1/10 of a degree. You could
write:
F = 18*C+320
So if you temp (C) was 100, the answer would be 2120. You could even
say:
Fint = F/10 ' Fint = 212
Ffrac = F%10 ' Ffrac = 0
Of course, another answer is to use one of our math coprocessors like
the PAK-I, II, or IX (see http://www.al-williasm.com/pak1.htm for
details). These give you 32-bit floating point math with all the
operations you'd expect.
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
> From: jbrobertsman [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SKV0qRb-SP24ipjEP3RGpjJtjSQChxvrMjiWVBDeuYIkjGGdP8aSVqucP8C3IsOYB0NKEZNogtqh_5oZYlz7]JBRobertsman@a...[/url
> Sent: Wednesday, November 13, 2002 9:04 AM
> Subject: [noparse][[/noparse]JUNK] [noparse][[/noparse]basicstamps] Numbers with Decimal Points
> question:
> from the same email address that you subscribed. Text in the
All I want to do is be able to enter a decimal point number from the
keyboard into the BS2 and store it. The stored number will then be
compared to an actual measured value. I am a unsure the best way to
program this functionality. Do you have any ideas ?
Thanks...JB
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> It depends on exactly what you need to do. If you just need to
store the
it,
x1=250,
> for example.
frustrating.
> F=1.8*C+32
> F = (18*C)/10+32
could
> write:
> F = 18*C+320
> say:
like
> Al Williams
> AWC
> > From: jbrobertsman [noparse][[/noparse]mailto:JBRobertsman@a...]
> > To: basicstamps@y...
> > question:
point
> > basicstamps-unsubscribe@y...
I just wrote a reply to Al's response on what I want to do. If after
reading it you have any ideas, I would surely appreciate it ? I am
not a pro programmer and am learning everyday
Thanks...JB
> >question:
point
with
>Thanks...JB
Here's a starter. The serin command gets two values, xi and xf,
before and after the decimal point. The Stamp treats the decimal
point as a terminator for data entry. Then xi and xf are combined to
make one bigger number (your value *100). That is used for the
comparison. The demo also shows one way to print out the "measured"
value with a decimal point.
xi var byte ' integer part, hundreds
xf var byte ' fractional part, hundredths
xx var word ' whole thing, *100
y con 1234 ' for comparison
loop:
debug "enter a number xx.xx> "
serin 16,$54,[noparse][[/noparse]dec xi,dec xf] ' for BS2
xx = xi*100 + xf
comparison:
if xx>y then debug cr,"is greater than "
goto showy
debug cr,"is less than or equal to "
showy:
debug dec y/100,".",dec2 y,cr
goto loop
-- Tracy
other folks out on this forum I will...but don't expect it soon !!!
Thanks for everyone's help...JB
> >Al...thanks for your response
the
> >Thanks...JB
to
the "measured"
> loop:
> xx = xi*100 + xf
> comparison:
> goto showy
> showy:
> goto loop
> -- Tracy
