Begining BS2 Programming - Input Data - Double Digit Numbers
Hi All:
Sid had answered my question about how to input keyboard data and
store it in a BS2(See below). I have a new problem on the program
accepting 2 digit numbers.
When I try to input a 2 digit number and store...say 10 or 20, it
only stores the 1 digit for the value COM. It then truncates the last
digit...Any body got any ideas how I can store any number entered
from the keyboard ? Thanks..JB
> Write
> N9600 con 16468
> com bar byte
> serout 16, N9600, [noparse][[/noparse]"Enter number of waypoints", cr]
> Message will appear on debug screen
> serin 16, N9600, [noparse][[/noparse]com]
> From the keyboard, enter a number. It will be stored in the
variable "com".
> Sid Weaver
> W4EKQ
> Port Richey, FL
> [noparse][[/noparse]Non-text portions of this message have been removed]
> Write
> N9600 con 16468
> com bar byte
variable "com".
> Sid Weaver
> W4EKQ
> Port Richey, FL
and need to convert it to decimal before you can store it in a byte
variable. You could probably solve this by making COM a 2 byte array.
Robert
> Hi All:
> > Write
> > N9600 con 16468
> > com bar byte
> variable "com".
> > Sid Weaver
> > W4EKQ
> > Port Richey, FL
