Help on If-Then-Gosub
How do you go directly to a gosub from a If - Then statement?
ie If 10 > 5 Then Task1
How do you Gosub Task1 ie. If 10 > 5 Then Gosub Task1 ( Which is not
allowed )
Thanks Stuart
allowed )
Thanks Stuart
> Hi,
> Then statement?
> allowed )
Hi Stuart...
You could do something like this:
Main:
:[noparse]:o[/noparse]ther code
if 10 > 5 then Task1
:[noparse]:o[/noparse]ther code::
goto Main
Task1:
gosub TaskSub
goto wherever
TaskSub:
your subroutine here
return
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
__________________________________________________
Do you Yahoo!?
U2 on LAUNCH - Exclusive greatest hits videos
http://launch.yahoo.com/u2
not to the programme line directly after the If-Then statement, this is where
I would like to go back to. Any other thoughts, there must be some way ??
Stuart
> --- stuarttttt@a... wrote:
> > Hi,
> > Then statement?
> > allowed )
> Hi Stuart...
> Main:
> goto Main
> Task1:
> gosub TaskSub
> goto wherever
> TaskSub:
> return
> Yes but.......after the "RETURN" the program only
> takes you back to Task1 and
Well, the only other idea I have in that case, is to
put a Label after the IF THEN line, then have the
Task1 line do a GOTO that label...Depending on how
many places you need to do this in your program, it
could work.
Knight Designs
(607) 535-6777
Do you Yahoo!?
test. So instead of:
If 10>5 then Gosub Task1
Try:
If 10<=5 then NotIf1
Gosub Task1
NotIf1:
You can extend this to an else like structure:
If 10<=5 then ElseIf1
Gosub Task1
Goto NotIf1:
ElseIf1:
Gosub Task2
NotIf1:
This is the same as:
If 10>5 then Gosub Task1 Else Gosub Task2
I did a project of the month a while back that was a preprocessor that
did this among other things.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: stuarttttt@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9Kupm08Hg9baMu8-VESLvUIZFqf93Ygk9SF6AkTxmOufWjlUs8HhOU9-MJvL_LpPIwJ3ZYtdLgPUwQ]stuarttttt@a...[/url
> Sent: Tuesday, November 12, 2002 10:34 AM
> Subject: [noparse][[/noparse]JUNK] Re: [noparse][[/noparse]basicstamps] Help on If-Then-Gosub
> Yes but.......after the "RETURN" the program only takes you
> back to Task1 and
> be some way ?? Stuart
> > > Hi,
> > > Then statement?
> > > allowed )
> > Hi Stuart...
> > Main:
> > goto Main
> > Task1:
> > gosub TaskSub
> > goto wherever
> > TaskSub:
> > return
> from the same email address that you subscribed. Text in the
gosub tasktest
continue here on return
tasktest:
if 10>5 then task1
return ' not do it
task1:
'do it
return
That works well with BRANCH:
gosub tasktest
' continue here on return
tasktest:
lookdown x,>[noparse][[/noparse]0,10,57],index ' several possibilities
branch index,[noparse][[/noparse]task0,task1,task2]
return ' should never get here
task0:
'do it
return
task1:
'do it
return
task2:
'do it
return
>If I understand your question, the trick is to reverse the sense of the
>Try:
>Gosub Task1
>NotIf1:
Test the other way round, like
if 10<=5 then skipline
::gosub task:
skipline:
regards peter
Oorspronkelijk bericht
Van: stuarttttt@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_oPeXaVClca8IYSAPYpEbBqIBcguMtJlw3Y0dY4VQlvgGfnE7qinIS5kk3nyeQUFrze9kFx0_i8k]stuarttttt@a...[/url
Verzonden: dinsdag 12 november 2002 08:34
Aan: basicstamps@yahoogroups.com
Onderwerp: Re: [noparse][[/noparse]basicstamps] Help on If-Then-Gosub
Yes but.......after the "RETURN" the program only takes you back to Task1
and
where
Stuart
> > Hi,
> > Then statement?
> > allowed )
> Hi Stuart...
> Main:
> goto Main
> Task1:
> gosub TaskSub
> goto wherever
> TaskSub:
> return
