Help on ins and outs please...
I'm going through a refresher on pbasic. It's been a while. I am
trying to write a program that will control several sets of christmas
lights to "dance" in intricate patterns with a 9 minute musical piece.
The music, as it is playing, will be run through a VU type circuit,
two lines of which will be tied to two input pins of the stamp. Using
a high and low threshold on those two lines, I will be able to pick
up occasional synchronous beats from the music to re-synchronize the
program to the music and simplify programming in chunks... to be put
together at a later date.
I'm working with a BS2 at present and may have to go to the SX for
more space.
Anyway... I don't remember how to output a set of 1's and 0's to a
bank of output pins simultaneously. I would like to connect circuitry
to six output pins which will drive six individual lines of christmas
lights. I need parallel communication out. I just don't remember how!
I would like to display a six bit patterns on their respective pins,
turning on individual or multiple strands of lights.
Can anyone slap me around a bit here and jog my memory on how to do
this please?!
Thank you!
Ross
more space.
this please?!
Thank you!
Ross
high 1
low 2
low 3
high 4
high 5
high 6
It would happen serially but so flippin fast you'd never be able to tell it
wasn't parallel.
Sent: Tuesday, November 12, 2002 5:34 AM
Subject: [noparse][[/noparse]basicstamps] Help on ins and outs please...
> more space.
> this please?!
> Thank you!
> Ross
out the description in the BS2 memory map section of the manual--in the v1.9
book, its on pages 214-216.
HTH,
Daniel
> From: rossfree [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=U7akOINaMDdi-ZuQlLUoZM8cz_iQYTIzY3pjT8SX1nvXDLXKxPju9yxINPbF0e0PyJBv8QtoaCPvnIX2k7i32SA-KJ2Fmw]rfreeman@w...[/url
> Sent: Tuesday, 12 November 2002 08:34
> more space.
> this please?!
> Thank you!
> Ross
OUTL = %11110000 ;makes pins 0 ~ 3 low and 4 ~ 7 high
OUTH = %11110000 ;makes pins 8 ~ 11 low and 12 ~ 16 high
OUTA = %1111 ;makes pins - ~ 3 high
OUTB will address pins 4 ~ 7
OUTC will address pins 8 ~ 11
OUTD will address pins 12 ~ 16
This will allow you to send out one command and adress 4, 8 or even 16 pins
(uses OUTS to address all 16 pins of the BS2, but then there are no pins left
for input).
This is less typing and faster code than addressing each pin individually.
I hope this helps.
my other posting on what the commands are) you can only address a bank of 4,
8 or 16 pins at a time.
A possible solution is to do the following:
Suppose your 12 outputs are pins 0 through 11 with the first bank of LED pins
0 ~ 5, and the second bank of leds pins 6 ~ 11.
If the first two leds on the second bank (pins 6 & 7 ) are currently low and
you want to keep them that way, and alter pins 0 ~ 5, you can send the
command
OUTSL = %00xxxxxx ;where the x's are the bits you want to change (pins 0 ~
5, set to 1 or 0) and bits 6 & 7 (the leds from the second bank you don't
want to change) will remain low.
Write back if you need more clarification
smartdim@a...
I need to write a more compacted code. Spelling it out line by line
would eat the five hundred max lines I have available on the BS2.
Ross
--- In basicstamps@y..., PM <pmeloy@s...> wrote:
> Are you sure you need real parallel? If you just did
> high 1
> low 2
> low 3
> high 4
> high 5
> high 6
tell it
> wasn't parallel.
> From: "rossfree" <rfreeman@w...>
> To: <basicstamps@y...>
christmas
piece.
circuit,
Using
pick
the
put
> > more space.
circuitry
christmas
how!
pins,
do
> > this please?!
> > Thank you!
> > Ross
> > basicstamps-unsubscribe@y...
Subject and
>Ross
>> high 1
>> low 2
>> low 3
>> high 4
>> high 5
>> high 6
>tell it
>> wasn't parallel.
>christmas
>piece.
>circuit,
>Using
>pick
>the
>put
>> > more space.
>circuitry
>christmas
>how!
>pins,
>do
>> > this please?!
>> > Thank you!
>> > Ross
>Subject and
OUTH·· = %11110000 ;makes pins 8 ~ 11 low and 12 ~ 16 high
OUTA = %1111·· ;makes pins - ~ 3 high
for input).
I hope this helps.
AND
After reading your message again, to send out a parrallel set of bits, (see
command
OUTSL = %00xxxxxx· ;where the x's are the bits you want to change (pins 0 ~
smartdim@a...
Let me tell what I am trying to do and see if this jives with those
that know how to do it.
I have a nine minute musical piece. I intend to write a program that
will flash christmas lights in various patterns, each assigned to a
different segment of the musical piece.
The main trunk of the program will establish a tempo and then call
subroutines one at a time... each subroutine will produce a pattern
of flashing lights that may last from a couple of seconds to thirty
seconds or so.
It is important that the subroutine loops back to the main trunk
where a it will track through one or two IF statements. Then it will
go back to the subroutine and continue to loop.
The IF statements might suggest a total number of loops before it
progresses to the next section of the trunk, varying the tempo as
needed and then calling a new subroutine (following the next section
of the music).
If I store my lighting patterns in the subroutines, I can easily call
them later if desired without much fuss.
I intended to write the program something like this:
x var nib
y var word
z var byte
tempo var byte
loops var byte
dirH = %11111100 'only output the six most significant digits
loops = 0 'number of beats being counted
tempo = 200 'adjustable as needed for program loop time
MAIN:
gosub PATTERN1
if loops = 16 then goto SECTION2
goto main
SECTION2:
end
PATTERN1:
lookup x,[noparse][[/noparse]127,191,223,239,247,251]y
outl = y
z = z + 1
if z = tempo then x = x + 1 and z = 0 and loops = loops + 1
if x = 6 then x = 0
return
In the "lookup" statement above, I call decimal numbers which when
converted to binary will drive low one of the outputs on I/O pins 10
thru 15. I think the least significant didgets will be truncated
because they fall on I/O pins 8 and 9 which are stated as inputs. The
lookup numbers above would pattern the lights to 'chase'.
The beauty (if there is something that can be called beautiful here)
is that each of the subroutines will look very much alike except that
the lookup statements will change to drive the lights in different
patterns. This should make writing the code fairly straight forward.
Of course I do what to add in a few bells and whistles like fading
and re-synchronizing to the beat(one of my inputs). But I think I can
do it.
I don't know if I can use all of those "and's" in the "if z"
statement above.
Ok all... nail me for my mistakes. I can take it!
Ross
--- In basicstamps@y..., smartdim@a... wrote:
> OUTL = %11110000· ;makes pins 0 ~ 3 low and 4 ~ 7 high
16 pins
pins left
> for input).
individually.
> I hope this helps.
> AND
bits, (see
bank of 4,
of LED pins
currently low and
the
> command
(pins 0 ~
don't
> smartdim@a...
save the patterns and then reconstructing the light patterns from the
saved byte(s).
The code for the Toddler robot uses these DATA patterns to good
advantage. Look at the Advanced Robotics text (you can download it
from Parallax) and you will find examples. Toddler stores a repeat
count at the beginning of the table and uses an FF (255) for the end
of the particular table. You can put a length byte at the front of
the table if you need every possible pattern for the lights. Since it
is music, a repeat count might be handy in your table as well. You
can also read a given table multiple times from subroutines.
Your code can take care of the timing of reading the DATA out.
Another benefit is that is a lot easier to read and modify the
patterns from data tables than from code.
Sounds like a fun project!
Harry
www.bluebelldesign.com
--- In basicstamps@y..., "rossfree" <rfreeman@w...> wrote:
> All good feedback... and I truly appreciate it.
that
> seconds or so.
will
section
> of the music).
call
> x var nib
> y var word
> z var byte
> tempo var byte
> loops var byte
> MAIN:
> gosub PATTERN1
> goto main
> SECTION2:
> end
> PATTERN1:
> outl = y
> z = z + 1
> if x = 6 then x = 0
> return
10
The
here)
that
forward.
can
> do it.
> statement above.
> Ross
even
> 16 pins
no
> pins left
> > for input).
> individually.
> > I hope this helps.
> > AND
> bits, (see
> bank of 4,
> of LED pins
> currently low and
send
> the
> > command
change
> (pins 0 ~
you
> don't
> > smartdim@a...
