Help, New at Rev D
I just bought a Rev D starter kit. I have used micros before but I
am very green with electronics. I am trying to write a program for
the Rev D stamp. I want the stamp to measure pressures between two
input signals. I want the stamp to then find the lowest value plug
that into an equation and out put another pulse. The equation I want
it to reference has 3 variables. I want to measure pressure and two
other variables and input it into this equation simultaneously. I
then want the stamp to output the result and continue measuring
pressures until triggered again to stop measuring and output a pulse
based on the inputs. Any help is greatly appreciated. I am also
trying to measure RPM (one of my inputs) do any of you guys know what
type of sensor clips to a spark plug wire to get a pulse. The sensor
is just put on the wire; I was told it was an Inductance type
sensor. Do any of you know where to buy such a sensor?
Thanks for the help
John
Thanks for the help
John
