Battery Backup Question
We are currently finalizing an in-house security system based on the
BS2, and are left with one final obstacle to overcome...
We have a power supply rated at 12VDC which powers the unit (And a 5V
regulator for the BS2 & LCD), and we have a 12VDC Battery Pack
(Consisting of 8 AA batteries). What we are trying to do is design a
power switching circuit to switch over to battery power in the event
that main power is lost.
Anyone have any good circuits for handling this? The currently
tabled idea is to use a relay...When power is lost, it will release
and the DPDT contacts will switch over to the battery. To overcome
the switch we thought maybe a couple of capacitors.
Anyone have any ideas?
power---->|
o
circuit
D2,4001 |
battery ---->|
circuit is powered by whichever power supply has higher voltage. D1
may not be necessary, depending on the power supply.
There is a voltage drop across the diodes. For lower drop, use a
schottky diode, say 1N5817. There are circuits using transistors
that have lower drops still. Your relay scheme should work too, but
may be overkill.
-- Tracy
mentioned. But I have often used a simple diode to provide switching from one
power source to a battery pack. This also provides an easy means of keeping
a trickle charge flowing in the batteries (rechargeable).
> D1,4001
> power---->|
o
circuit
> D2,4001 |
> battery ---->|
Thanks Tracy...I've seen this idea in use before
(without the second diode). Our Power Supply is a
simple regulated 12VDC supply using an LM7812. This
does look like a better option.
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
__________________________________________________
Do you Yahoo!?
U2 on LAUNCH - Exclusive greatest hits videos
http://launch.yahoo.com/u2
> I am not sure what you would do with "a couple of
> capacitors" as you
> (rechargeable).
Well, the Capacitors would've been used as filtering
caps on the output of the relay so that while the
relay was switching from one side to the other the
caps would provide voltage.
On your reply, are you saying that if I use a Diode
that there will be voltage flowing back into my
battery pack? Because the battery pack we have is NOT
rechargeable, so this would not be ideal in this
situation...Last thing I need is a battery leak.
Knight Designs
(607) 535-6777
Do you Yahoo!?
but
> may be overkill.
One more question Tracy...Regarding Azeasi's reply, would this cause
any leakage into my battery pack? The battery pack is made up of 8
Duracell batteries...Non-Rechargeable...I myself have never tried
this design before.
volts across it when it is without commercial power, you don't have to worry
about isolation. Let the system run off battery all the time and the power
supply can charge it as required.
The schottkey diode solution is good as well and there are versions with
only .25 volts dropped across them. As the power drops from the power
supply, the diode on the battery will begin to conduct and you will never
even know power dropped (except you're sitting in a dark room <grin>)
Tim
From: ulibasic [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=A-n5S6fqmA9PBoptDkFcJPObueQdwAlKrkC0zhZv_fXP1reRLkZyuvIdPo79s47QPD3S0Dj2BhFsuHoHw6eNpzT5XyQJb6hZzuET]ulibasic@r...[/url
Sent: Monday, November 11, 2002 1:46 PM
Subject: AW: [noparse][[/noparse]basicstamps] Battery Backup Question
Hey Tracy,
do you think this will be fast enough to work without resetting when the
power is interrupted abruptly? Could this even be some kind of
brownout-prevention? Are there diodes that suit this purpose better (in
other words: faster diodes)?
Thanks, Uli
Urspr
A 1N4001 diode back biased will have a leakage current at room
temperature of about 10 nanoamps. That increases to maybe 100
nanoamps at the highest ambient temperatures you would encounter.
I have always heard that alkaline cells are safe for "leakage
charging" at that level, that is, the leakage is less than the
self-discharge rate of the battery.
To put this in perspective, if you are worried, then you could
install a 22 megaohm resistor in parallel with your reserve battery
pack. The resistor would draw a current constantly, 12 volts/22
megaohms = 55 nanoamps. Don't worry too much about the extra load.
Your 8 AA cells are rated at over one amp-hour, and it would take
almost 2 million hours, over 200 years, for the batteries to
discharge through the 22 megaohms. (They would self-discharge long
before that!!!). The resistor would sink the excess charging
current. But my point really is, you don't even need the resistor.
Schottky diodes are _muc_h more leaky in reverse, maybe 10 microamps
at room temperature. That might argue against a Schottky.
The best diode, the lowest leakage, would actually be the
base-collector junction of a transistor. The collector base junction
of NPN transistor will have a leakage of orders of magnitude lower
than the 1N4001. For example, I just pulled a 2N3904 NPN transistor
out of the drawer, and measured a reverse leakage at room
temperature, 10 volts reverse bias, of about 90 picoamps. I also
measured a big 2N3055 in a TO220 case, and that was low too, only 270
picoamps, 0.27 nanoamp.
D1
power
C E |
battery
\ />----o--o----load
|B | NPN transistor
' base connected to emitter
Vcbo > 20 volts
Ic ample for the load
I do not know exactly what level of reverse current would tolerable
for an alkaline battery. You could always add the parallel resistor
to absorb the current. Jim Higgens on this list is more of a battery
expert, and I would defer to his suggestions, if he happens to check
in on this one.
The need for diode D1 in your circuit will depend on the level of
leakage back into the power supply when the power is turned off.
Don't assume that it will be zero!
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
>but
> > may be overkill.
>this design before.
>Chris Savage
One question bugging me, if this is a critical security system, why not use
a sealed lead-acid or gel-cell rather than the alkalines? Too much
overkill? How much power is wasted by the regulator dropping the 12 volts
to 5 which becomes important when running off battery? I'm not trying to
infer which is better, just curious.
Tim
From: Tim Tapio [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yb8JqPwUVgvTgnt05rYIBrCRAgvv37LJv6zAiPH0pp51BxVyD5kBoZubIP73nMbeTC51-BEF]tim@t...[/url
Sent: Monday, November 11, 2002 4:05 PM
Subject: RE: [noparse][[/noparse]basicstamps] Battery Backup Question
One other consideration, if your power supply doesn't mind having the 12
Tim
From: ulibasic [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lmB3dS45dQoCkr1TEze7Yv2PRzdTM-KfG-E4bmq56qr4S91e6Z02QQgeBOpVJhxrSd40jCskqcNziygBAXwRorpjeDBy09guF7vj]ulibasic@r...[/url
Hey Tracy,
Thanks, Uli
Urspr
D1
power
E C |
battery ----o--< /
o----load
| |B NPN transistor
Vcbo > 20 volts
equals D2 --->|----
very low leakage
NOT....
> D1
> power
> C E |
> battery
> |B | NPN transistor
!!BACKWARDS ---|<--- !!
> Yes, there is leakage back into the battery from the
> diode.
> more of a battery
> happens to check in on this one.
Okay, well, I am going to save your message, as you
went to great lengths in this, and I am going to try
several variations as you have mentioned to see what I
get. Perhaps I should consider using Rechargeable
batteries...I never really thought that much about it
when the whole battery backup idea was mentioned.
Interestingly enough, while testing the "door-chime"
section of our system today we were subjected to a
double-shot brownout, which caused me to lose a temp
BS2 program I was in the middle of putting
in...Although it did help me test the power-fail
response of the siren and door-chime outputs.
Knight Designs
(607) 535-6777
Do you Yahoo!?
> alkalines? Too much overkill?
Well, we were trying to stick with what we have in
stock in the shop, since this is more of an
afterthought. We have surplus LCD displays, Sensors,
Buzzers, Sirens, etc. We even have a digital keypad
for Radio Shack Alarm Systems which we haven't yet
deciphered it's operation (serial interface). We
could use anything, although another consideration is
space.
The regulator is the one on the BS2 OEM board, which
is what's powering the 5V devices in this design.
Actually the only other device at 5V is the LCD
display.
Knight Designs
(607) 535-6777
Do you Yahoo!?
>Yes, there is leakage back into the battery from the diode.
> D1
> power
> C E |
> battery
> |B | NPN transistor
> Vcbo > 20 volts
>to absorb the current. Jim Higgins on this list is more of a battery
>in on this one.
I've been reading and I see very good advice being given.
I think I saw something questioning the reverse recovery time of a 1N4001.
Remembering, it will switch as soon as the voltage of the supply drops
below the voltage of the battery - about 12 volts - and that both will
still be well above the voltage the regulator needs to maintain regulation,
I don't think a 2 microsecond recovery time is a problem. That's a lot of
head room in my book.
Jim H
of EME should solve your problem!
