Diode
Need a kickback diode for a transistor I'm using to drive a solenoid.
Working voltage about 35VDC. Anyone have a part number?
Sid Weaver
W4EKQ
Port Richey, FL
Sid Weaver
W4EKQ
Port Richey, FL
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zWD_HhFA8zbS9_woWWuysUeTCLIm8AgQ2mOqjC5h9QGIoaih5x2W64LH3EUMs1eauXUjwDzIofi6]Newzed@a...[/url
Sent: Monday, November 11, 2002 9:16 AM
Subject: [noparse][[/noparse]basicstamps] Diode
Sid Weaver
W4EKQ
Port Richey, FL
Sid
it may be a solenoid, relay,or transformer ( soo what you want is tio have
the diode across the coil pointing up towards positive. anode side of the
doide to the collector of the transistor and cathode to the supply.) that if
you have a npn transistor with the emtter to gnd or common.
neil
Sent: Monday, November 11, 2002 9:15 AM
> Sid Weaver
> W4EKQ
> Port Richey, FL
