serin / wait problem...
Hello fellow stampers...
I'm using bs2sx...
I have a situaltion where I am using the serin and "wait" command to control
program flow depending on data received. If I receive "ab" I want one
option, and if I receive anything else I want another option.
The "wait" command doesnt seem to work properly if you use a timeout time
and label, as shown below...
serin serinpin,baud,1000,nodata,[noparse][[/noparse]wait ("ab"),databyte]
do something if "ab" comes in
nodata:
do something if "ab" not received after timeout period
I thought it should wait for the timeout period, and if "ab" is not
received, then go to the "nodata" label. It seems that if any data comes at
all, it will act as though "ab" has been received. The only way to get it to
go to the "nodata" label is to stop the stamp receiving data on the serin
pin.
Any thoughts would be appreciated..
Best regards, and thanks in advance if you can help,
Chris
Australind
Western Australia
I'm using bs2sx...
nodata:
pin.
Chris
Australind
Western Australia
>I'm using bs2sx...
>nodata:
>pin.
>Chris
>Australind
>Western Australia
Hi Chris -
The TIMEOUT parameter is exactly what it says it is, and no more. It's not a
"NOT FOUND" facility, although in some circumstances it may act that way.
Is there some reason why you can't just read in the data with no WAIT
parameter and check the incoming data for whatever characters you wish to
process, and loop back to the SERIN if you didn't get what you want ?
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
No, I dont have enough time to do a serin and then process the data.
I am actually reading data in from an RF tag ID system, and doing a QUICK
check to see if the RF tag is still present, by looking at the first 2
charachters in a 20 byte charachter stream.
The second byte is different if a valid RF key is in proximity of the
reader. The problem I have is that I am also counting reasonably fast pulses
(80 hz) at the same time, thats why I just wanted to have a quick look for
the "ab" that signifies an RF key is present and then get straight back to
my pulse counting routine. I have done it for now by just looking at the
byte following "a", but this is not really as secure as I would like, as
there may be another "a" elsewhere in the data stream making the next
character not the correct one to look at (I hope somehow that makes sense)
Chris
Sent: Monday, November 11, 2002 8:50 PM
Subject: Re: [noparse][[/noparse]basicstamps] serin / wait problem...
> >I'm using bs2sx...
control
> >nodata:
at
to
> >pin.
> >Chris
> >Australind
> >Western Australia
> Hi Chris -
a
> Regards,
> Bruce Bates
The timeout option is hard to use on a simple radio connection,
because of noise. The timeout counter is reset to zero with every
character that arrives. (Not the whole message) So your program
gets stuck at the SERIN instruction.
Your timeout parameter was one second. That is time for a lot of
noise to come in, also time for a lot of BS2 processing. Is the
Stamp sending something out to stimulate the RFiD response.
-- Tracy
>Hello Bruce, and thanks for the prompt reply.
>Regards,
>Chris
>From: "Bruce Bates" <bvbates@u...>
> > >I'm using bs2sx...
>control
> > >nodata:
>at
>to
> > >pin.
> > >Chris
> > >Australind
> > >Western Australia
> > Hi Chris -
>a
> > Regards,
> > Bruce Bates
>Subject and Body of the message will be ignored.
The 1 second in my example is just an example, I am actually using 50, which
is very short with bs2sx.
I think you have answered by saying that the timeout resets for each
character received.
There also is no sample in the manual for using timeout with wait, so it may
be that its just not possible.
I am happy to leave it as is, just waiting for the first character then
checking the second for now, but I will continue playing with it a bit.
Thanks for your help,
Chris
Sent: Tuesday, November 12, 2002 1:17 AM
> Hi Chris
> -- Tracy
pulses
for
to
sense)
> >Regards,
> >Chris
> > > >I'm using bs2sx...
> >control
time
> > > >nodata:
comes
> >at
get it
> >to
serin
> > > >pin.
> > > >Chris
> > > >Australind
> > > >Western Australia
> > > Hi Chris -
not
> >a
way.
to
> > > Regards,
> > > Bruce Bates
and
and
Similar headaches can come from a modem on a noisy line. A SERIN
command with a timeout can get locked up waiting for input that never
comes. I ended up using a watchdog coprocessor to monitor my modem
systems, to break in if something happens (or doesn't). I guess you
could have a coprocessor dedicated to monitor your radio input for
the presence of a tag.
-- Tracy
>Hello Tracy,
>character received.
>Chris
>From: "Tracy Allen" <tracy@e...>
>> Hi Chris
>> -- Tracy
>pulses
>for
>to
>sense)
>> >Regards,
>> >Chris
> > > > >I'm using bs2sx...
>> >control
>time
>> > > >nodata:
>comes
>> >at
>get it
>> >to
>serin
>> > > >pin.
>> > > >Chris
>> > > >Australind
>> > > >Western Australia
>> > > Hi Chris -
>not
>> >a
>way.
>to
>> > > Regards,
>> > > Bruce Bates
>and
>and
Thanks for your responses, I hadn't thought about the problems with a noisy
line affecting the "wait" command, but now I see it has potential to be a
real problem. The main problem for my situation is a small enclosure to
house the RF control unit, and my pcb with the stamp on it is only about 1"
away from it. It is smooth now just waiyting for the first vharacter, then
checking the second character so I guess the radio noise may not be such a
problem for me.
Thanks again for your reply...
Chris
Sent: Tuesday, November 12, 2002 9:19 AM
> Hi Chris,
> -- Tracy
> >Hello Tracy,
which
> >character received.
may
> >Chris
> >> Hi Chris
> >> -- Tracy
QUICK
> >pulses
> >for
back
> >to
the
as
> >sense)
> >> >Regards,
> >> >Chris
> > > > > >I'm using bs2sx...
to
> >> >control
one
timeout
> >time
> >> > > >nodata:
not
> >comes
> >> >at
> >get it
> >> >to
the
> >serin
> >> > > >pin.
> >> > > >Chris
> >> > > >Australind
> >> > > >Western Australia
> >> > > Hi Chris -
It's
> >not
> >> >a
that
> >way.
WAIT
wish
> >to
> >> > > Regards,
> >> > > Bruce Bates
Subject
> >and
Subject
> >and
and
