tokenizer (on linux, and MacOs X)
I did about the same on MacOs X. In order to use the dlopen stuff which is not
standard available in OS X I downloaded dlf.c and dlf.h from iodbc.org. But
after succesfuly compiling the software and running the stampapp application I
got:
tokenizer.shlb: not a Mach-O MH_BUNDLE file type.
So here my question to parallax, please provide us also with a Mach-O type
dynamic link library of the tokenizer, suitable for MacOs X.
Gerrit.
--- In basicstamps@y..., "rhootman" <rhootman@p...> wrote:
> I just downloaded the tokenizer tarball. I am running RedHat Linux 8.0
> I extracted the files, cd to the linux examples, read the readme.txt
> and copied the tokenizer.so file into the example directory and then
> did a make all which failed. Changed the line in the makefile CC = gcc
> to CC = g++ and everything compiled and I was able to make the
> stampapp application and run it according to the readme.txt file. Now
> I am going through the stampapp.cpp file and the Using the Tokenizer
> pdf file to see what I really need to do. When I get around to it,
> will probably just take one of the open source text editors and extend
> it to run the tokenizer and add send the tokens out a specified serial
> port. That is, if someone already hasn't done so.
> Randy Hootman
> rhootman@p...
> --- In basicstamps@y..., Gerrit Polder <polder@p...> wrote:
> > I'm just wondering, now the tokenizer is released, if anybody is
> working on
> > a mac or linux basicstamp programming tool.
> > Gerrit.
got:
Gerrit.
> Randy Hootman
> rhootman@p...
> working on
> > Gerrit.
input file. Added code to give users switches that allow the user to
specify which portion of the output that the user would want to see at
that time (ALL, INFO, EEPROM, EEPROMSIZE, COUNTS, PACKETBUFFER). Added
code to give users a switch that they can specify a file to save the
packetbuffer output to (in other words, save the tokenization of your
source code to a file). Added code to pretty up the output (8 bytes
per line with their address range). Makes the output of stampapp a
little shorter and cleaner. On linux, the resultant saved tokens of
your source code can be seen nicely formatted by using the hexdump -C
filename from the command line. When I tested my revised stampapp, the
outputted tokens file contents matched the tokens listed by Parallax
in their Tokeninzer Library paper.
I guess someone could use this file and a few other command line tools
(setserial, etc.) and configure the serial ports and then maybe
something like minicom to transfer the file. Have to follow the
Parallax Basic Stamp Programming Protocol. Haven't been successful in
manipulating the serial ports exactly correct yet. Haven't spent alot
of time on it yet. Looking for docs on serial port programming on
Linux and the HOWTOs and miniHOWTOs don't seem to have enough
information in them. Think I'll have to do some kernel diving and
maybe some kernel module programming ...
Randy Hootman
rhootman@p...
which is not standard available in OS X I downloaded dlf.c and dlf.h
from iodbc.org. But after succesfuly compiling the software and
running the stampapp application I got:
Mach-O type dynamic link library of the tokenizer, suitable for MacOs X.
> Gerrit.
> > Randy Hootman
> > rhootman@p...
> > working on
> > > Gerrit.
